Posted: Wed Nov 28, 2018 3:39 pm Post subject: Securing the aircraft |
Has anyone got a clever solution for securing the aircraft doors - for example in a strange airport overnight?
thanks
Will
William Daniell
LONGPORT
+57 310 295 0744
ward.t(at)xtra.co.nz Guest
Posted: Wed Nov 28, 2018 3:58 pm Post subject: Securing the aircraft |
Hi Will,Although I did put door locks in place, I came to the conclusion that if someone wanted to break in, they would do more damage to the aircraft as compared to what they may take. I always take my EUROPA Cover with me and use it as a deterrent and to keep the weather out. Always remove my headsets and anything else of value.
The locking device I used was flimsy and not strong enough as a deterrent and would leave me stranded if broken into with door not closing.
Tim Ward12 Waiwetu Street,
Fendalton,
Christchurch, 8052
New Zealand
ward.t(at)xtra.co.nz (ward.t(at)xtra.co.nz)
Mob +64 210640221
On 29/11/2018, at 12:38 PM, William Daniell <wdaniell.longport(at)gmail.com (wdaniell.longport(at)gmail.com)> wrote:
| Quote: | Has anyone got a clever solution for securing the aircraft doors - for example in a strange airport overnight?
thanks
Will
William Daniell
LONGPORT
+57 310 295 0744
peterz(at)zutrasoft.com Guest
Posted: Wed Nov 28, 2018 6:12 pm Post subject: Securing the aircraft |
I think the only semi effective lock would be one which uncouples the latch handles from the shoot bolts. I've not yet found such a solution but keep looking. Mine might end up being self-designed.
Pete
On Nov 28, 2018, at 6:57 PM, Tim Ward <ward.t(at)xtra.co.nz (ward.t(at)xtra.co.nz)> wrote:
| Quote: | Hi Will,Although I did put door locks in place, I came to the conclusion that if someone wanted to break in, they would do more damage to the aircraft as compared to what they may take. I always take my EUROPA Cover with me and use it as a deterrent and to keep the weather out. Always remove my headsets and anything else of value.
Fendalton,
Christchurch, 8052
New Zealand
Mob +64 210640221
thanks
Will
William Daniell
LONGPORT
+57 310 295 0744
budyerly(at)msn.com Guest
Posted: Wed Nov 28, 2018 7:11 pm Post subject: Securing the aircraft |
Door locks and photos were presented some time ago by me and others. Check the archives.
Bud Yerly
Bud Yerly
Custom Flight Creations
From: owner-europa-list-server(at)matronics.com <owner-europa-list-server(at)matronics.com> on behalf of William Daniell <wdaniell.longport(at)gmail.com>
Sent: Wednesday, November 28, 2018 6:38:34 PM
Subject: Securing the aircraft
thanks
Will
William Daniell
LONGPORT
+57 310 295 0744
Posted: Thu Nov 29, 2018 12:45 am Post subject: Securing the aircraft |
I agree. A cover is an effective disincentive to a light fingered passer by(and I think they are rare on airfields). And a lock would not stop the sort of professional thief who sets out to steal your engine. David Joyce, GXSDJ
On 2018-11-28 23:57, Tim Ward wrote: | Quote: | Hi Will, Although I did put door locks in place, I came to the conclusion that if someone wanted to break in, they would do more damage to the aircraft as compared to what they may take. I always take my EUROPA Cover with me and use it as a deterrent and to keep the weather out. Always remove my headsets and anything else of value.
Tim Tim Ward 12 Waiwetu Street,
Fendalton,
Christchurch, 8052
New Zealand
Mob +64 210640221
thanks
Will
William Daniell
LONGPORT +57 310 295 0744
Ivor
Posted: Thu Nov 29, 2018 3:26 am Post subject: Re: Securing the aircraft |
Hi what I did more from a visual point of view is added a bracket to the
Rear of the outside handle that I subsequently drilled a hole vertical down
Through both handle and bracket so a padlock could be used,
It’s a good deterrent IMO but obviously wouldn’t stop a determined toe rag
I also use a cover when left at a unattended airfield,
913.72 KB |
8818 Time(s) |
rlborger(at)mac.com Guest
Posted: Fri Nov 30, 2018 12:34 pm Post subject: Securing the aircraft |
Will,
I agree with Tim. No door locks. But when I travel I carry my cover to protect the aircraft windscreen and to deter snoopers.
Blue skies & tailwinds,Bob BorgerEuropa XS Tri, Rotax 914, Airmaster C/S Prop (130 hrs).Little Toot Sport Biplane, Lycoming Thunderbolt AEIO-320 EXP, Hercules Prop.3705 Lynchburg Dr.Corinth, TX 76208-5331Cel: 817-992-1117rlborger(at)mac.com (rlborger(at)mac.com)On Nov 28, 2018, at 5:38 PM, William Daniell <wdaniell.longport(at)gmail.com (wdaniell.longport(at)gmail.com)> wrote:
thanks
Will
William Daniell
LONGPORT+57 310 295 0744
h&jeuropa
Posted: Sat Dec 01, 2018 5:19 am Post subject: Re: Securing the aircraft |
Will,
We have door locks but they are not all that strong. Someone once said locks only keep honest people out.
The biggest deterrent are our Kennon Sun Shields. They fit inside the windows and prevent people looking to see what avionics are fitted. They make a huge difference in interior temperature. In Florida you'll find that a great feature.
In flight we use Pilot Armour Copper overhead sun screens. We have four of them that we position as needed.
Jim & Heather
Posted: Sat Dec 01, 2018 6:39 am Post subject: Securing the aircraft |
Roger that - cover it is then.
Will
William Daniell
LONGPORT
+57 310 295 0744
On Fri, Nov 30, 2018 at 3:36 PM Robert Borger <rlborger(at)mac.com (rlborger(at)mac.com)> wrote:
| Quote: | Will,
Bob Borger
3705 Lynchburg Dr.
Cel: 817-992-1117
thanks
Will
William Daniell
LONGPORT
+57 310 295 0744
