Need help with replacement connector pins for KT76A
jjshultz
PostPosted: Fri Dec 21, 2018 6:49 pm    Post subject: Need help with replacement connector pins for KT76A Reply with quote
Can someone help me find a source for replacement pins for a KT76A transponder connector. I'm not sure of the name of that connector, but it is a 24-pin molded plastic unit, with two rows of 12 pins, and the pins are not cylindrical but flat.
If someone has a digikey or mouser part number that would be fantastic!
Jeff
alec(at)alecmyers.com
PostPosted: Fri Dec 21, 2018 8:07 pm    Post subject: Need help with replacement connector pins for KT76A Reply with quote
The pins were discontinued by molex about a decade ago, but this guy still has stock. He’s probably the only supplier in the world, now.
https://www.mikesarcade.com/cgi-bin/store.pl?sku=CECPIN100
On Dec 21, 2018, at 21:49, jjshultz <jjshultz(at)cablemo.net (jjshultz(at)cablemo.net)> wrote:
--> AeroElectric-List message posted by: "jjshultz" <jjshultz(at)cablemo.net (jjshultz(at)cablemo.net)>
Jeff
http://forums.matronics.com/viewtopic.php?p=486480#486480
nbsp; (And Get Some AWESOME FREE Gisp; this year's Terrific Free Incentive Gifts provided
* My Pilot Store
http://www.matronics.====================================================; - MATRONICS WEB FORUM"http://forums.matronics.com">http://forums.matronics.com
http://w====================================================
PostPosted: Fri Dec 21, 2018 8:11 pm    Post subject: Need help with replacement connector pins for KT76A Reply with quote
Well, apart from the eBay merchants at $1/pin, that is....
On Dec 21, 2018, at 23:06, Alec Myers <alec(at)alecmyers.com (alec(at)alecmyers.com)> wrote:
Jeff
* My Pilot Store [url=http://www.mypilotstorenbsp;    -Matt Dralle, List Admin.</===============================================</span><br><s]http://www.matronics.====================================================;   - MATRONICS WEB FORUM"http://forums.matronics.com">http://forums.matronics.com[/url]
ceengland7(at)gmail.com
PostPosted: Sat Dec 22, 2018 7:15 am    Post subject: Need help with replacement connector pins for KT76A Reply with quote
Eewww, *those* pins. My fix, at least for experimentals, is solder, wire, and dsub connectors.
Charlie
On Dec 21, 2018, at 11:11 PM, Alec Myers <alec(at)alecmyers.com (alec(at)alecmyers.com)> wrote:
Jeff
stein(at)steinair.com
PostPosted: Sat Dec 22, 2018 1:31 pm    Post subject: Need help with replacement connector pins for KT76A Reply with quote
There’s a reason many those arcade pins are cheap. They are simply brass plated tin (which is probably fine for some wires, but not for others).  …the “real� pins are gold flashed (and silver), and as you noted discontinued long ago. Those of us who have some left do charge a lot, but that’s because they just don’t exist at the OEM level anymore.  Whenever you see a solid silver or solid gold looking pin, be aware they aren’t what you think they are.
Cheers,
Stein
From: owner-aeroelectric-list-server(at)matronics.com <owner-aeroelectric-list-server(at)matronics.com> On Behalf Of Alec Myers
Sent: Friday, December 21, 2018 10:10 PM
Subject: Re: Need help with replacement connector pins for KT76A
Jeff
< span="">nbsp; (And Get Some AWESOME FREE Gisp; this year's Terrific Free Incentive Gifts provided
* My Pilot Store [url=http://www.mypilotstorenbsp;     -Matt%20Dralle,%20List%20Admin.%3c/======================%3c/span%3e%3cbr%3e%3cs]http://www.matronics.===========================; - MATRONICS WEB FORUM"http://forums.matronics.com">http://forums.matronics.com[/url]
<="" spanp;  &nnbsp; -->="" http://w===========================
