		tomcostanza
				 Posted: Sat Jan 12, 2019 7:19 am    Post subject: EE needed |
				This is a non-aviation question so please forgive my blatant request for info.
 I have a solenoid rated as follows: 12VDC  29mA  4.0W (printed on the coil). I don't have any more information about it.
 I need to open it for a VERY short time (around 30ms), then let its spring close it.  If I just apply 12VDC for 30ms, it barely has time to open and I get inconsistent results.  So:
 1) Being an inductor, it's opposing the change in current in the 1st place.
 2) It barely overcomes that, and then the current goes away.
 I'm thinking I can apply much more than 12V with a proportional increase in current, since it's only for 30ms, but don't know how to figure out how much for how long.  I would very much appreciate someone giving me a non-differential equation answer if there is one.
 Give a man a fish and you feed him for a day.  Teach a man to fish and you feed him for a lifetime.
 Thanks so much.
  |  | - The Matronics AeroElectric-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  _________________ Clear Skies,
Tom Costanza
-- in year 17 of a 3 year project |
				 Posted: Sat Jan 12, 2019 8:46 am    Post subject: EE needed |
				At 09:19 AM 1/12/2019, you wrote:
   	  | Quote: | 	 		  --> AeroElectric-List message posted by: "tomcostanza" <Tom(at)CostanzaAndAssociates.com>
  I have a solenoid rated as follows: 12VDC  29mA  4.0W (printed on the coil). I don't have any more information about it. |
    29mA? That's only 0.35 watts. Could it be 290mA?
    What's the physical sized of this device. 4W dissipated
    into a small mass gets pretty hot in a hurry.
   	  | Quote: | 	 		  I need to open it for a VERY short time (around 30ms), then let its spring close it.  If I just apply 12VDC for 30ms, it barely has time to open and I get inconsistent results.  So:
  2) It barely overcomes that, and then the current goes away. |
    Yup. How critical is the timing for being 'active'?
    What are the tolerances on that 0.030 seconds?
    You could build an adjustable pulse generator that
    would be tailored to produce the pulse length needed
    to achieve the 0.030 second activation requirement.
   	  | Quote: | 	 		  | I'm thinking I can apply much more than 12V with a proportional increase in current, since it's only for 30ms, but don't know how to figure out how much for how long.  I would very much appreciate someone giving me a non-differential equation answer if there is one. |
    What voltages are available in your system.
    Inductive time constant is t=L/R. One way
    to get smaller T is increased R. We used
    to speed up response time on stepper motors
    with big resistors in winding leads . . . wastes
    a lot of POWER but for our needs, response time
    was critical, warming up the room not so much.
   	  | Quote: | 	 		  | Give a man a fish and you feed him for a day.  Teach a man to fish and you feed him for a lifetime. |
    There are also some constant current generator
    circuits that might be more attractive . . .
    but they still toss off a majority of the
    power.
    The adjustable pulse width generator might be
    the first thing to try.
  Joined: 28 Mar 2008 Posts: 1944 Location: Riley TWP Michigan
				 Posted: Sat Jan 12, 2019 8:50 am    Post subject: Re: EE needed |
				When you say open and close, I assume that you are talking about a valve or
 something, not the electrical circuit.
 You wrote "but don't know how to figure out how much for how long".  It seems
 that you are able to vary the time.  So instead of increasing the voltage, why
 not just increase the time?
  Are the current or watts correct?  Looks like something is off by a factor of 10.
 I calculate 69 volts.
 E x E = 33.3 x 12 x 12
 E = 69 volts
 Hopefully someone will correct me if wrong.
  _________________ Joe Gores |
				 Posted: Sat Jan 12, 2019 8:50 am    Post subject: EE needed |
    See   https://tinyurl.com/y92d76o4
				 Posted: Sat Jan 12, 2019 9:02 am    Post subject: Re: EE needed |
				I should have posted 69 volts maximum for 30 milliseconds.  The actual voltage
  to get the desired results can be determined by trial and error.
		tomcostanza
				 Posted: Sat Jan 12, 2019 10:01 am    Post subject: Re: EE needed |
  	  | Quote: | 	 		  29mA? That's only 0.35 watts. Could it be 290mA?
 into a small mass gets pretty hot in a hurry.  |
 I noticed that as well.  But that IS what's printed on the coil.  FYI, it's about 1"x1"x0.75"
  	  | Quote: | 	 		  How critical is the timing for being 'active'?
 What are the tolerances on that 0.030 seconds?  |
 The timing is the only thing that IS critical.  It's a project of my own design, so I can vary just about anything.
  	  | Quote: | 	 		  What voltages are available in your system.
 to get smaller T is increased R.  |
 As I said, I can vary just about anything.  But wouldn't adding a resistor in series just further reduce current and exacerbate the problem?
  	  | Quote: | 	 		  The adjustable pulse width generator might be
 the first thing to try.  |
 Again, I can vary the drive to the solenoid any way I want, and can set the pulse width to whatever I want.  But what voltage/current would I use for the pulse?
 TI makes a chip (DRV110) that does just what I want, but I suspect it's designed for longer engage/hold times.  My short t is what's screwing it up.
Tom Costanza
		tomcostanza
				 Posted: Sat Jan 12, 2019 10:09 am    Post subject: Re: EE needed |
				user9253,
 I didn't understand your calculation.
 E = 69 volts
 Where does 33.3 come from?
 If I use the 4W number:
 V = P/I = 4/0.029 = 137V
 But for how long?  Obviously 137V through a 12V coil would let the magic smoke out in very short order.
Tom Costanza
		ceengland7(at)gmail.com Guest
				 Posted: Sat Jan 12, 2019 10:14 am    Post subject: EE needed |
				On 1/12/2019 12:01 PM, tomcostanza wrote:
  Clear Skies,
  Tom Costanza
 Details would help a lot. Solenoid controlled valve, or relay? If relay,
 what voltage, current, and AC or DC?
 If it's a relay, replacing it with something solid state would simplify
 your problem by quite a bit.
		tomcostanza
				 Posted: Sat Jan 12, 2019 11:16 am    Post subject: Re: EE needed |
				Some more data points:
 I have several of these devices from 3 "manufacturers"
  	  | Code: | 	 		  Vendor     Written on device            Measured
 1              12V 2.5W                       22 ohms   440mA
 2              12V 5W                          35 ohms   320mA
 3              12V 29mA  4.0W             35 ohms   320mA
 So it seems Bob's question about "is it really 29ma" was exactly right.  The coil is sealed, so I can't even guess about the wire size.
 I guess I don't have enough info to solve this mathematically, so I'll have to do it empirically.
 Thanks to all for their input.
Tom Costanza
				 Posted: Sat Jan 12, 2019 1:54 pm    Post subject: EE needed |
    Too many unknown variables. From the time it's energized
    to the instant that full travel is realized has a lot of
    variables only slightly related to the t=L/r rise.
    Putting an adjustable pulse generator in the loop
    will let you 'dial in' a pulse width that achieves
    the desired effect.
				 Posted: Sat Jan 12, 2019 4:57 pm    Post subject: Re: EE needed |
				I assumed, maybe incorrectly, that 1 full second is the maximum amount of
 time to apply high voltage without damaging the coil.  One second divided by 30
  milliseconds equals 33.3
 Watts = E squared / R
 Power at high voltage for 33 milliseconds = power at 12 volts for 1 second
 E squared / (33.3 x R) = 12 volts squared / R
 The Rs cancel.
 Thus E squared / 33 = 12 squared
 E = 69
 Maybe my reasoning is flawed, but 69 volts will cause less smoke than 137 V.
		alec(at)alecmyers.com Guest
				 Posted: Sat Jan 12, 2019 5:05 pm    Post subject: EE needed |
				Do you think trying to activate a coil for so short a period with a timed pulse is reliably repeatable over variations in temperature etc?
 What if the supply voltage has variations?
 Or the spring in the relay changes elasticity as it ages?
 Hate to be a pooper but maybe an approach with solid state switching would be more reliable?
 On Jan 12, 2019, at 16:53, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
  	  | Quote: | 	 		     	  | Quote: |
    the desired effect.
				 Posted: Sat Jan 12, 2019 8:50 pm    Post subject: EE needed |
				At 07:05 PM 1/12/2019, you wrote:
   	  | Quote: | 	 		  Do you think trying to activate a coil for so short a period with a timed pulse is reliably repeatable over variations in temperature etc?
    Your automobile's fuel injector
    valves do it . . .
   	  | Quote: | 	 		  What if the supply voltage has variations?
  Hate to be a pooper but maybe an approach with solid state switching would be more reliable? |
    Those are some of the variables I
    cited. Fuel injected engines have
    the advantage of being able to monitor
    mixture in real time and adjust
    pulse width and timing to maintain
    design goals irrespective of a
    constellation of intervening
    variables.
    Your concerns for maintaining
    consistent solenoid behavior
    'open loop' are valid.
    But we don't know tolerance to which
    the behavior is expected. It may be
    that once the t=L/R factor is
    accounted for, the rest of them
    are operationally insignificant.
    It may be that the 'desired behavior'
    can be measured and used to close the
    loop on a variable pulse width generator.
