Recommended wire gauge for battery
alec(at)alecmyers.com
PostPosted: Tue Jan 15, 2019 5:17 am    Post subject: Recommended wire gauge for battery Reply with quote
Here is a question about what gauge of wire the list would recommend for extending a battery installation on an aircraft.
Parameters are that a 24V battery needs to move from behind the baggage compartment to the firewall, for balance purposes.
The aircraft has a Lycoming O320 engine. The battery is 24V 11AH and rated at cold cranking amperage 200A. It needs to move about 5’ from its present position.
I can re-site the ground terminal (to the airframe) to the new location, but I’m unwilling to move the battery and starter contactors, as an alternative I’d prefer to run a heavy 24V wire back to the original battery position where the contactors are.
My certification engineer says he’s willing to sign off the extended unswitched and unfused power line as long as it’s properly grometted through the firewall etc.
What gauge of wire should I be considering?
Anything other considerations I’m missing?
art(at)zemon.name
PostPosted: Tue Jan 15, 2019 6:11 am    Post subject: Recommended wire gauge for battery Reply with quote
Alec,
I do understand wanting to keep the contactors in their existing positions, aft of the baggage compartment. It is a paperwork hassle to move them. Even still, I would reconsider that decision. You need BIG wire to carry the current for the starter. In my airplane with an IO-360 and the battery on the firewall, I used 4 and 6 gauge wire in the circuit from the battery through the contactors to the starter. I'll bet that you already have something BIG running from the contactor to the starter and you would want something at least that large to run from the battery's new location back to the contactor.
    -- Art Z.
On Tue, Jan 15, 2019 at 7:33 AM Alec Myers <alec(at)alecmyers.com (alec(at)alecmyers.com)> wrote:
--> AeroElectric-List message posted by: Alec Myers <alec(at)alecmyers.com (alec(at)alecmyers.com)>
https://CheerfulCurmudgeon.com/"Be kind, for everyone you meet is fighting a hard battle."
Kellym
PostPosted: Tue Jan 15, 2019 6:43 am    Post subject: Recommended wire gauge for battery Reply with quote
If I understand correctly, you currently have battery box with master
contactor and the starter contactor both behind the baggage compartment.
That implies you are running a heavy cable for the starter and a
somewhat smaller cable for the main aircraft bus, both from behind the
baggage compartment. I don't understand why the starter contactor wasn't
placed on the firewall to begin with, but okay.
Presumably anything in the tail cone that is powered is getting power
from bus on the instrument panel. I don't see any advantage of keeping
the contactors in their current location. You can use existing wire,
just shortening the cable to what is needed from the battery box on the
firewall. No new cable needed, just cutting and crimping new connectors
on existing cable. Only other wires to move are the master switch wire
and the ignition switch wire, again just making them shorter.
While you could do the calculations to the W&B for the battery move, you
would be better off just re-weighing the plane.
O
<mailto:alec(at)alecmyers.com>> wrote:
<alec(at)alecmyers.com <mailto:alec(at)alecmyers.com>>
/"Be kind, for everyone you meet is fighting a hard battle."/
Kelly McMullen
KCHD
PostPosted: Tue Jan 15, 2019 7:26 am    Post subject: Re: Recommended wire gauge for battery Reply with quote
The engine is on the front of the airplane, correct? As others have said, it is
best to move the contactors forward near the battery. Weight will be less and
safety will be increased. What is the reason for not moving the contactors, no
room, more work, regulator?
Joe Gores
PostPosted: Tue Jan 15, 2019 2:30 pm    Post subject: Recommended wire gauge for battery Reply with quote
I miswrote, and in fact the starter contactor is already on the firewall.
So I would have to move the battery contactor only, but that’s not trivial in this airplane. Also I would have to keep or install a heavy cable from the external power relay back to the battery - the external power relay, connector (through the fuselage side) and external power control relay are all colocated behind the baggage compartment.
I was really wondering what gauge of wire people use for a 24v starter...
Joe Gores
http://forums.matronics.com/viewtopic.php?p=486988#486988
Kellym
PostPosted: Wed Jan 16, 2019 6:38 am    Post subject: Recommended wire gauge for battery Reply with quote
OK, nothing wrong with having a single heavy lead back to your remote
power. The Master solenoid/contactor still should be as close as
possible to the battery. Your starter wire is not going to change. The
only wire you need to add is from the battery to the starter relay. You
can leave the existing wire from the battery and connect it to the
external power relay.
Typically 24/28V wire can be one or two number sizes smaller than 14V
wire for same current. That would likely put you at #4 or #6.
Joe Gores
Kelly McMullen
KCHD
ceengland7(at)gmail.com
PostPosted: Wed Jan 16, 2019 8:18 am    Post subject: Recommended wire gauge for battery Reply with quote
Kelly said something important: The Master solenoid/contactor still
should be as close as possible to the battery.
Is your inspector ok with having the battery's 'fat' wire running
unprotected all the way from firewall to the back of the a/c?
I know it's frustrating to get answers that aren't answers to your
question, but sometimes that's needed.
On 1/16/2019 8:36 AM, Kelly McMullen wrote:
<kellym(at)aviating.com>
You can leave the existing wire from the battery and connect it to the
> firewall.
> compartment.
> starter...
> said, it is
> less and
> contactors, no
> Joe Gores
PostPosted: Thu Jan 17, 2019 7:06 am    Post subject: Recommended wire gauge for battery Reply with quote
On closer examination, I don’t have to add any fat wires if I do move the battery contactor along with the battery. The heavy cable that currently (no pun intended) provides power forward to the engine compartment (and starter) will now be the heavy cable that feeds power from the external power connector. So it’s less work.
There are just two wires I need to add through the firewall:
1. The battery contactor coil current, which goes from the contactor coil low side in series through the external power control relay (at the old battery location), a diode and then forward to the battery master switch.
2. Permanent power to the hour meter
On Jan 16, 2019, at 11:20 AM, Charlie England <ceengland7(at)gmail.com> wrote:
Kelly said something important: The Master solenoid/contactor still should be as close as possible to the battery.
Is your inspector ok with having the battery's 'fat' wire running unprotected all the way from firewall to the back of the a/c?
I know it's frustrating to get answers that aren't answers to your question, but sometimes that's needed.
OK, nothing wrong with having a single heavy lead back to your remote power. The Master solenoid/contactor still should be as close as possible to the battery. Your starter wire is not going to change. The only wire you need to add is from the battery to the starter relay. You can leave the existing wire from the battery and connect it to the external power relay.
Typically 24/28V wire can be one or two number sizes smaller than 14V wire for same current. That would likely put you at #4 or #6.
> Joe Gores
