whodja
Joined: 27 Jan 2014 Posts: 50 Location: Apex NC (near Raleigh)
Posted: Mon Feb 18, 2019 6:22 am Post subject: Wing walk |
Any recommendations for wing walk material? I have searched the archives and a few recommended the clear from ACS. How’s the durability of the
clear? Any other recommendations?
Tim Olson
Posted: Mon Feb 18, 2019 6:42 am Post subject: Wing walk |
I think they're all durable, but I've had people buy the clear who've
not been completely happy in the long run, mainly because it can
yellow and it gets dirty and looks bad then. So it's more common to
go black.
But, if someone else has a different reply, please add it. Mine is
not first hand but second hand.
On 2/18/19 8:22 AM, whodja wrote:
cooprv7(at)yahoo.com Guest
Posted: Mon Feb 18, 2019 7:21 am Post subject: Wing walk |
I like the black because in addition to not yellowing it gives people a clear image of where it is okay to step.
Marcus
go black.
bill.peyton
Joined: 19 Sep 2010 Posts: 198 Location: St. Louis, MO
Posted: Mon Feb 18, 2019 11:43 am Post subject: Re: Wing walk |
I have the vans black wing walk installed. It’s been 6 years and still looks new. It comes with the cutouts for the screws
_________________ Bill
WA0SYV
Aviation Partners, LLC |
aerosport1
Posted: Mon Feb 18, 2019 11:55 am Post subject: Wing walk |
I totally agree with Tim and Marcus.
FWIW
Geoff Combs
Aerosport Modeling & Design
| Quote: | On Feb 18, 2019, at 10:18 AM, Marcus Cooper <cooprv7(at)yahoo.com> wrote:
Marcus
> go black.
> Tim
_________________ Geoff Combs
RV-10 QB N829GW
Flying 500 hrs
40033 |
whodja
Posted: Tue Feb 19, 2019 4:04 am Post subject: Re: Wing walk |
Thanks guys!
Bob Turner
Posted: Tue Feb 19, 2019 9:01 am Post subject: Re: Wing walk |
I did the test - black on one side, clear on the other! They both work, have been durable, but, as Tim said, the clear is near impossible to clean. I’d suggest the black.
_________________ Bob Turner
RV-10 QB |
tshort
Posted: Tue Feb 19, 2019 11:59 pm Post subject: Re: Wing walk |
This is relevant to me as I need to replace the wing walk during the inspection this year. Mine is peeling off (maybe because my airplane is so fast?!? ha)
Any experience with the paint on kind?
What is the best solvent to remove the old wing walk / adhesive without paint damage?
Tim Olson
Posted: Wed Feb 20, 2019 5:38 am Post subject: Wing walk |
I removed some in the fall and just used a heat gun to heat it gently,
and then it peeled up without any paint issues. But it would be
easily possible to pull paint off rivet heads if they're covered.
That said, as long as you're reapplying, you can always paint
the rivet heads and they should stay buried. Peel towards
the center from all edges first, and that should help ensure
no paint issues.
On 2/20/2019 1:59 AM, tshort wrote:
http://forums.matronics.com/viewtopic.php?p=487706#487706
Kelly McMullen
Posted: Wed Feb 20, 2019 5:43 am Post subject: Wing walk |
If it is the self-adhesive variety, I would recommend gentle use of a heat gun....as I see Tim just suggested.
I would recommend against the brushed-on variety. I've never seen any hand-applied wing walk that looked right.
I'm not sure how paint shops put it on, but they generally do a good job.
| Quote: | | Sent from my TRS-80 Model 100 |
On Wed, Feb 20, 2019 at 1:05 AM tshort <tmshort(at)gmail.com (tmshort(at)gmail.com)> wrote:
| Quote: | --> RV10-List message posted by: "tshort" <tmshort(at)gmail.com (tmshort(at)gmail.com)>
FORUMS -
WIKI -
b Site -
-Matt Dralle, List Admin.
A&P/IA, EAA Tech Counselor
KCHD |
