		jay-dub
				 Posted: Thu Feb 21, 2019 8:18 am    Post subject: Carb Diaphragm for HS-6A |
				Having had a very quiet moment while airborne the other day, it is likely we need a new carb diaphragm.
 Our maintenance organisation has a diaphragm for the AK-14P carb. We think we need a QHQ-14A for the Huosai, which I will have to acquire.
 Are they by any chance interchangeable before I email Doug S?
 Thanks.
  |  | - The Matronics Yak-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  _________________ CJ owner |
				 Posted: Thu Feb 21, 2019 10:01 am    Post subject: Carb Diaphragm for HS-6A |
				They are definitely NOT interchangeable.  Tried it many, many years ago when I was trying to adapt the manual mixture control from the Huosai carburetor to the M14 carburetor.
 Dennis
  	  | Quote: | 	 		   On Feb 21, 2019, at 11:18 AM, jay-dub <flyjnw(at)gmail.com> wrote:
  Thanks.
  CJ and Yak-52 owner
  http://forums.matronics.com/viewtopic.php?p=487724#487724
		jay-dub
				 Posted: Thu Feb 21, 2019 10:15 am    Post subject: Re: Carb Diaphragm for HS-6A |
				Thanks Dennis.
				 Posted: Thu Feb 21, 2019 12:24 pm    Post subject: Carb Diaphragm for HS-6A |
				May I ask why you think you need a carb diaphragm ??   The reason I ask is simply because when one of them tears, or fails, it does not fix itself and then you fly home.
 If all of a sudden you start running very rich , etc., etc., yes.  Or if the engine stops running... as in it totally stops running .... yes, probably.
 But if it stops in flight for a few moments and then starts running again... or something like that, it could be electrical as in mag coils.  That can often be very difficult to define.
 You probably know all this already, so ... sorry.
 Mark
		jay-dub
				 Posted: Thu Feb 21, 2019 12:35 pm    Post subject: Re: Carb Diaphragm for HS-6A |
				Hi Mark,
 Our thoughts are as follows. I was aerobatting and came off a loop to a strong smell of fuel in the cockpit. There were no engine issues at this stage. It cleared so I thought I'd carry on. The same occurred again and the engine missed but recovered so I took the hint and went home. I pulled the power back to 68/2000 and it missed twice more on the way home so I left the levers alone as it kept recovering. I recovered to the airfield from a forced landing pattern and the engine quit during the roll out as the airflow was seemingly driving the prop during the descent, so I effectively deadsticked it in. It glides much better than a -52!! Our thought is that it rich-cut as I pulled the throttle back for the descent.
 I've had a mag failure in a Yak-52 in the past which gave very similar symptoms other than there was no smell of fuel and the engine kept going after landing.
 Does that sound logical? In fairness, it will be handy to keep a diaphragm in stock anyway so I don't mind picking one up.
		richard.goode(at)russiana Guest
				 Posted: Fri Feb 22, 2019 12:36 am    Post subject: Carb Diaphragm for HS-6A |
				I agree with Mark. But if you have a diaphragm/membrane failure, then after
 the engine has been shut down, leave the fuel on and the throttle slightly
 open, and you will almost certainly get fuel dripping down through the
 carburettor. If none comes out, then I would suspect a coil failure.
 I would also make the point that, very specifically, these diaphragms (and
 there are two in each carburettor) should be replaced at a maximum of every
 six years.
 Richard
 RICHARD GOODE AEROBATICS
 Rhodds Farm, Lyonshall, Hereford, HR5 3LW, UK
 Tel:  +44 (0)1544 340120   Fax:  +44 (0)1544 340129
 e-mail: richard.goode(at)russianaeros.com
 www.russianaeros.com
 WORLD LEADERS IN RUSSIAN SPORTING AIRCRAFT & ENGINES
 In partnership with Aerometal Kft, Hungary.
		romaine_richard(at)yahoo. Guest
				 Posted: Fri Feb 22, 2019 12:59 am    Post subject: Carb Diaphragm for HS-6A |
				Not sure if it works for all symptoms described, but fuel odor in cockpit could be leaking primer due to loose knurled nut on primer plunger or worn/cut plunger o-ring under knurled nut...also causing lean issues.  Have you seen, smelled any fuel from top of plunger during priming?
 Bonus is fixes don’t come much cheaper or easier.
 Rich
		jay-dub
				 Posted: Fri Feb 22, 2019 1:16 am    Post subject: Re: Carb Diaphragm for HS-6A |
				Always happy with a cheap fix. No evidence of that at all but we’re about to do the annual while it’s grounded so we’ll give it a good look over.
		wlannon(at)shaw.ca Guest
				 Posted: Fri Feb 22, 2019 11:35 am    Post subject: Carb Diaphragm for HS-6A |
				Hi Richard;
 Is there a Russian, or other, AWD specifying a life limit for the diaphragm?
 Where is the second diaphragm located?
 Thanks;
 Walt
				 Posted: Sat Feb 23, 2019 1:39 am    Post subject: Carb Diaphragm for HS-6A |
				Yes, we unfortunate Europeans are much more tightly controlled than you
 lucky guys. But categorically it is a European rule from EASA (our FAA) that
 the membranes (diaphragms) have a six year calendar life.
 It is fairly clear from the engine manual where they are, but to help I will
 ask Aerometal, our partner in Hungary, to send me photographs of the
 carburettor indicating exactly the parts that needs to be removed to change
 the membranes, and I will post it on the yak-list.
 With regards
 Richard
		Viperdoc
				 Posted: Sat Feb 23, 2019 5:46 am    Post subject: Carb Diaphragm for HS-6A |
				Did you say you had a heavy smell of fuel in the cockpit when this occurred?
 A carb diaphragm leak is not going to give you a smell of fuel in the cockpit during flight, Level or aerobatic.
 Sucking air will cause the engine to lean out and fail too.
 So places to look are for places fuel can get into the cockpit. Also a mag coil failing as Mark said will cause engine hesitation. It is quite impressive when that happens. Usually 15 to 20 min into the flight and will occurs again in 15 to 20 min if the flight continues.
 Doc
 [quote] On Feb 22, 2019, at 2:35 AM, Richard Goode <richard.goode(at)russianaeros.com> wrote:
  six years.
  Richard
  _________________ Viperdoc |
		jay-dub
				 Posted: Sat Feb 23, 2019 10:06 am    Post subject: Re: Carb Diaphragm for HS-6A |
				I’ve had coil failure in the past. This was similar other than the smell of fuel and the engine actually quit fully. Will have a look for leaks when we get it apart.
		Harv
				 Posted: Mon Feb 25, 2019 12:29 pm    Post subject: Re: Carb Diaphragm for HS-6A |
				Hi John
 I replaced the diaphragm on my CJ when we rebuilt it in 2013 and it's due again now (if we are following a 6 year life) sourced via Doug S. Check with him regarding this being the only one in the HS6's carb as I believe it is. The yak52 may have other internal diaphragms or seals as from memory that carb is also pressure (alt) sensing.
 Rgs
 Harv
		jay-dub
				 Posted: Mon Feb 25, 2019 2:11 pm    Post subject: Re: Carb Diaphragm for HS-6A |
				Doug is out of stock at the moment. Should be ok in a couple of weeks.
				 Posted: Mon Feb 25, 2019 2:57 pm    Post subject: Carb Diaphragm for HS-6A |
				Fuel smell in the cockpit could possibly be coming from a fractured
 bellows in the wobble pump?  Maybe Walt will comment on the possibility
 of that.
 Dennis
 A. Dennis Savarese
 334-546-8182 (mobile)
 www.yak-52.com
 Skype - Yakguy1
		n13472(at)aol.com Guest
				 Posted: Mon Feb 25, 2019 3:44 pm    Post subject: Carb Diaphragm for HS-6A |
				What bellows are you referring to?  is this in a CJ ?
 Tom Elliott
 CJ-6A NX63727
 777 Quartz Ave
 PMB 7004
 Sandy Valley NV.
 89019
 Cell 541-297-5497
 N13472(at)AOL.COM
				 Posted: Mon Feb 25, 2019 5:12 pm    Post subject: Carb Diaphragm for HS-6A |
				Hey Dennis;
 Can't say I recall a bellows unit in the CJ wobble pump but it is years
 since I've had one apart and I'm not getting smarter with advancing years.
 The only fuel/bellows interface I can recall is in the Harvard/T6 fuel
 control unit.  This is a combined unit containing the fuel filter, the
 wobble pump and a bellows type fuel pressure adjustment unit.  The original
 engine driven rotary fuel pump was a simple pump with no pressure adjustment
 or internal bypass so the fuel unit was necessary.  The wobble (emergency)
 pump operated in parallel to the main system unlike the CJ which is a series
 system requiring a more modern pump with internal by-pass and integral
 pressure control.
 Usual places for a wobble pump leak are:  1. the shaft packing seal, 2.
 cover gasket & 3.  fittings.  But I would also take a good look for pin-hole
 corrosion in the vent system anti-syphon loop which is located about 12" SW
 of the pilot's nose.
 Cheers;
 Walt
				 Posted: Mon Feb 25, 2019 7:21 pm    Post subject: Carb Diaphragm for HS-6A |
				Good point Harv;
 As you suggested that second diaphragm will be in the auto-mixture section
 of the M14P carb.  With the Huosai we have only one to think about.
 Walt
