Antenna Questions
lcottrell
PostPosted: Tue Feb 26, 2019 1:57 pm    Post subject: Antenna Questions Reply with quote
On Tue, Feb 26, 2019 at 2:43 PM slingshot003 <i2bxtn(at)gmail.com (i2bxtn(at)gmail.com)> wrote:
--> Kolb-List message posted by: "slingshot003" <i2bxtn(at)gmail.com (i2bxtn(at)gmail.com)>
No. 1: Will a handheld rubber ducky antenna suffice for airport traffic use?
Barely!
No. 2: Can an external antenna be mounted 2-3ft from the engine?
Mount your antenna on the bottom, attach it to a round alum ground plane riveted to the cross members there.
No. 3: If mounted on Lexon, does the antenna need a ground plane, & if so, how large should it be & would the ground plane need to be grounded to the air frame?
http://forums.matronics.com/viewtopic.php?p=487825#487825
The older I get, the less tolerant I am of those who are intolerant of others.
west1m
PostPosted: Tue Feb 26, 2019 6:20 pm    Post subject: Antenna Questions Reply with quote
I use a hand held using a Ram Mount with the antenna sticking through the wind shield with a rubber grommet in the windshield. It has worked real well except the wind noise. I have started using a leather mic cover with a tiny hole , this has made me more clear. But the radio itself and 8" or so antenna works well
Get Outlook for Android
From: owner-kolb-list-server(at)matronics.com <owner-kolb-list-server(at)matronics.com> on behalf of Larry Cottrell <lcottrell1020(at)gmail.com>
Sent: Tuesday, February 26, 2019 3:56:03 PM
Subject: Re: Antenna Questions
Barely!
West1m
Hastings, MN
byoungplumbing(at)gmail.c
PostPosted: Thu Feb 28, 2019 8:17 am    Post subject: Antenna Questions Reply with quote
Check with a local ham radio club.    They they have testing equipment they might think it's a unique enough project they might come out and help you for free.
To find a club maybe check with arrl.org and you should be able to find or search for a ham radio club near you
Boyd Young
