		johnr470(at)aol.com Guest
				 Posted: Fri Mar 01, 2019 1:04 am    Post subject: Grounding to tube structures |
				Unfortunately it is already covered and in the rear of the fuselage where access is somewhat difficult.
  	  | Quote: | 	 		   On Feb 28, 2019, at 11:30 PM, AeroElectric-List Digest Server <aeroelectric-list(at)matronics.com> wrote:
  Today's complete AeroElectric-List Digest can also be found in either of the
  two Web Links listed below.  The .html file includes the Digest formatted
  and Message Navigation.  The .txt file includes the plain ASCII version
  of the AeroElectric-List Digest and can be viewed with a generic text editor
  HTML Version:
     http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 19-02-28&Archive=AeroElectric
  Text Version:
     http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 19-02-28&Archive=AeroElectric
                            AeroElectric-List Digest Archive
                      Total Messages Posted Thu 02/28/19: 4
  Today's Message Index:
      1. 06:29 AM - Grounding to tube frame structures  (John Hulls)
      2. 07:18 AM - Re: Grounding to tube frame structures  (Robert L. Nuckolls, III)
      3. 08:46 AM - Re: Static Wicks - Bonding of Flight Controls  (Robert L. Nuckolls, III)
      4. 04:34 PM - Re: Static Wicks - Bonding of Flight Controls  (jsajpf)
  ________________________________  Message 1  _____________________________________
  Time: 06:29:38 AM PST US
  Subject: Grounding to tube frame structures
  What is the best method to ground a battery located behind the baggage compartment
  to a frame tube in a fabric covered aircraft?
  ________________________________  Message 2  _____________________________________
  Time: 07:18:39 AM PST US
  From: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com>
  Subject: Re: Grounding to tube frame structures
 > baggage compartment to a frame tube in a fabric covered aircraft?
    You would like to have a gas-tight connection
    to structure . . . ideally a welded bolt-
    tab to accept the battery(-) lead.
    Is the airplane already covered?
    If not, adding the tab should be
    a relatively simple task.
  ________________________________  Message 3  _____________________________________
  Time: 08:46:36 AM PST US
  Subject: Re: Static Wicks - Bonding of Flight   Controls
  At 10:21 PM 2/27/2019, you wrote:
 > <john.friday_adis(at)sbcglobal.net>
 > Bob (et al),
 > Looking for insight into legacy Type Certificated airplane design
 > rationale for installing static wicks and bonding jumpers between
 > fixed structure and movable flight control surfaces.
    Selecting style, number and placement of
    static wicks on a TC aircraft is an arduous
    task made possible by a survey of the ship's
    natural streamer locations  . . . which
    may or may NOT be in the same locations
    for similar aircraft. We used to bolt
    static wicks to some models at Cessna . . .
    as I recall it was a kit that a customer
    could order. But I'm 99% sure there were
    no electro-static survey tools used to
    optimize the location of wicks much
    less confirm their efficacy.
 > Several E/AB designs do not specify installation of static wicks nor
 > bonding jumpers for flight control surfaces.  The particular design
 > I plan to build is among this group and reports from those with
 > years flying the design are (albeit a limited number of
 > respondents): no issues with P-static and the like.
    Then I wouldn't worry about it. P-static
    issues are rare in the OBAM aircraft world.
    We just don't spend much time cruising at
    300 knots through rain, snow or ice
    crystals.
 > I cannot attest to the types of operations, nor how frequent the
 > exposure to conditions conducive to P-Static interference, for the
 > respondents to my query.
 > Looking for input from TC house folks (Bob) regarding rules of
 > thumb, design standards, etc. regarding incorporation of static
 > wicks and bonding??
 > My experience with the subject matter is as a maintainer,
 > troubleshooting reports of symptoms of P-Static while in visible
 > moisture, required inspections after a lightning strike, routine
 > verification (inspections) of electrode-to-surface bonding values,
 > etc.  Correction of broken or degraded control surface bonding cured
 > the majority of reported faults.  Some degraded antenna bonds are
 > among the mix as well.  Design standards applicable to mitigating
 > P-Static trouble are not clear to me and my understanding of design
 > criteria/recommendations is admittedly academic (at best).
 > What say ye, the sage?!
    I wouldn't bolt any hardware to the
    airplane until experience suggests
    it might fix a demonstrated difficulty.
  ________________________________  Message 4  _____________________________________
  Time: 04:34:39 PM PST US
  Sounds like wisdom to me Bob.  Thanks for the response!
  John
  http://forums.matronics.com/viewtopic.php?p=487869#487869
		JohnCiolino(at)carolina.r Guest
				 Posted: Fri Mar 01, 2019 8:01 am    Post subject: Grounding to tube structures |
				One route to go is to use a non-insolated Adel clamp (e.g. AN742-10 in
 steel) on an interior tube. You would have to sand all the paint off the
 tube to make good contact.
 John Ciolino
 Bearhawk Patrol
		user9253
  Joined: 28 Mar 2008 Posts: 1944 Location: Riley TWP Michigan
				 Posted: Fri Mar 01, 2019 10:06 am    Post subject: Re: Grounding to tube structures |
				The airframe does not necessarily have to be grounded does it?
 Just run a separate cable from battery negative to the engine block or firewall.
 If the airframe must be grounded, is there a convenient place forward of the battery?
  _________________ Joe Gores |
				 Posted: Fri Mar 01, 2019 1:31 pm    Post subject: Grounding to tube structures |
				At 03:02 AM 3/1/2019, you wrote:
   	  | Quote: | 	 		  --> AeroElectric-List message posted by: John Hulls <johnr470(at)aol.com>
  Unfortunately it is already covered and in the rear of the fuselage where access is somewhat difficult. |
   consider running a battery(-) wire all the way
   up to the firewall ground stud.  What size
   engine and battery are we talking about?
   How much wire to get from battery to firewall?
