My Firestar 2 Build
Goto page Previous  1, 2, 3, 4
west1m
PostPosted: Sun Mar 24, 2019 2:30 pm    Post subject: Re: My Firestar 2 Build Reply with quote
Interesting talk about muffler brackets. This is what happened to me yesterday on a short flight to Amery airport. I was already in my seat when the the guy I was chatting with asked what was wrong with my muffler. It was kind of angled a bit funny.He then helped me wire it together so it wouldn't fall off and scratch up my prop..
 Filesize:  107.99 KB
 Viewed:  8379 Time(s)
West1m
Hastings, MN
capedavis(at)yahoo.com
PostPosted: Sun Mar 24, 2019 3:19 pm    Post subject: My Firestar 2 Build Reply with quote
My shop only looks that good if I just finished cleaning for about four hours !Nice looking work
On Mar 23, 2019, at 4:29 PM, william sullivan <williamtsullivan(at)att.net> wrote:
Question- Is there much chance of the muffler mount cracking? Stainless?
Bill Sullivan
On Sat, 3/23/19, loctupdave <loctupdave(at)att.net> wrote:
I haven't posted for a while, when the
weather is below 0 or even 20 the hanger is just to dang
cold to work in.
The engine is moving on. I had to order
starter o rings thanks to the oil injection leaking over the
starter and taking out the o rings. I still need to rebuild
the carbs and install the starter. I went with the
Challenger muffler mount. Here are a couple of pics.
(http://s275.photobucket.com/user/dngspot/media/front_zpszgldaco0.jpg.html)
PostPosted: Sun Mar 24, 2019 4:36 pm    Post subject: My Firestar 2 Build Reply with quote
Funny how often that happens. Somebody discussing things that have just happened to somebody in a group, and not knowing about it.
Bill Sullivan
On Sun, 3/24/19, west1m <west1m(at)hotmail.com> wrote:
Subject: Re: My Firestar 2 Build
Date: Sunday, March 24, 2019, 6:30 PM
prop..
West1m
Hastings, MN
http://forums.matronics.com//files/broken_muffler_176.jpg
zeprep251(at)aol.com
PostPosted: Mon Mar 25, 2019 4:03 am    Post subject: My Firestar 2 Build Reply with quote
I don’t recommend isolating the exhaust system from the engine. I think it should be one with the engine,as tight and secure as you can make it.
On Mar 24, 2019, at 8:35 PM, william sullivan <williamtsullivan(at)att.net> wrote:
Bill Sullivan
prop..
West1m
Hastings, MN
Richard Pike
PostPosted: Mon Mar 25, 2019 4:57 am    Post subject: Re: My Firestar 2 Build Reply with quote
Unless your secondary goal is to get rid of vibration. Then you isolate it from the engine, keep it tight at the connections, and flexible at the mounts. Then (IMO) you have the best solution: reliability and less vibration.
The original muffler mounting on the 277 on the Firefly was set up to be tight, and it shook worse than you could imagine. We assumed it was because it was a single. Wrong. it was because the muffler was too tight.
A single cylinder engine waving that muffler back and forth 5,000 times a minute was a disaster waiting to happen. And it very nearly did: during the 45 minute ferry flight from the test field to David's hangar it broke 3 out of 4 new muffler hangars.
The first picture shows that setup with the original curlyque muffler.
The current setup is in the later pictures, there is no stress on the muffler hangars and vibration is about 90% less, and at 5500 rpm (the sweet spot for this engine) there is literally no vibration now.
The goal was to let the engine move without it also moving the muffler - or at least moving it as little as possible. So far it seems like a good plan.
Addendum: test flew the Firefly Saturday with the fan cooled 277, (the pictures show the original engine) first flight since the blackberry patch adventure last year, and it flew as nice as ever, engine ran good, but wouldn't idle right. Will be swapping the carb out today for a new one that we just happened to have. When you have a partner who has had even more U/L type airplanes over the last 30 years than you have, there seems to be no lack of spare parts...
 Filesize:  152.79 KB
 Viewed:  8346 Time(s)
 Filesize:  181.42 KB
 Filesize:  151.5 KB
Richard Pike
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
jhauck36(at)outlook.com
PostPosted: Mon Mar 25, 2019 5:20 am    Post subject: My Firestar 2 Build Reply with quote
I use rubber hanger straps, scrounged from my local muffler shop, look like they are made from conveyor belt material, for vibration isolation for other applications, but would probably work well for an exhaust hanger.
I remember many years ago when I discovered the problem of over soft Lord Mounts on my FS/447. Thrust and torque was causing the engine to get way out of line. While down at Brother Jim's in Tallahassee, Florida, one flight, I got the bright idea of using shock absorber donuts to make up some engine mounts. Jim zipped them up with the TIG welder and I flew back to Titus, Alabama. Before I got home the entire exhaust system was disintegrating from vibration. Reckon the airframe would have been next had I had a longer flight.
Vibration is some bad stuff.
Page 4 of 4
