		Gary.Leinberger(at)miller Guest
				 Posted: Sat Apr 06, 2019 2:05 pm    Post subject: PC680 battery |
				I just ordered another PC680 for my 912 S Europa. This one lasted almost 5 years. I have had little problem with these batteries, even when using a standard automotive battery charger that brings the battery up to about  13.5 or volts. Lately it has only been able to bring the battery up to 12.8 v and I have been having problems starting, especially when cold. But today was 65 degrees F. so I pulled it out, saw the date on it, and bit the bullet.
 Does anyone know of a charger that will charge these batteries properly - normally when cold I turn on my engine block heater and put the charger on the battery to warm it up and I have no problem. However, I did try  an Odessey battery charger and it burned up - I was lucky I didn't lose the plane. Odessey was less than helpful and basically blew me off after admitting that charger model had problems. They apparently dropped that model and brought out a new model but I  felt a tad nervous about using their charger. Any suggestions?
 Gary Leinberger
 N388SG
 Europa A237
 Lancaster, Pa., USA
 380 hours.
    From: owner-europa-list-server(at)matronics.com <owner-europa-list-server(at)matronics.com> on behalf of Europa-List Digest Server <europa-list(at)matronics.com>
  Sent: Saturday, April 6, 2019 2:34 AM
  To: Europa-List Digest List
  Subject: Europa-List Digest: 3 Msgs - 04/05/19
   CAUTION: This email originated from outside of Millersville. Do not click links or open attachments unless you recognize the sender and know the content is safe.
  Today's complete Europa-List Digest can also be found in either of the
  two Web Links listed below.  The .html file includes the Digest formatted
  and Message Navigation.  The .txt file includes the plain ASCII version
  of the Europa-List Digest and can be viewed with a generic text editor
  HTML Version:
       http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter=2019-04-05&Archive=Europa
  Text Version:
       http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter=2019-04-05&Archive=Europa
                             Europa-List Digest Archive
                       Total Messages Posted Fri 04/05/19: 3
  Today's Message Index:
       1. 01:18 AM - Re: Which battery claims should I believe?  (clivesutton)
       2. 09:24 AM - Europa Aircraft - location change  (John Wighton)
       3. 12:13 PM - Re: Which battery claims should I believe?  (JonathanMilbank)
  ________________________________  Message 1  _____________________________________
  Time: 01:18:21 AM PST US
  Subject: Re: Which battery claims should I believe?
  Hi Jonathan,
  To contribute to to your original question (which is indeed fascinating) i think
  the answer may have to do with the internal chemistries/construction of each,
  the way each Mfr interprets e.g. CCA and CA testing and their market focus.
  I believe that:
  Varley have the best Pulse Hot Cranking Amp performance because they are of sealed
  bog std lead acid construction.  But this comes at the price of life (from
  apprenticeship days i recall that the pure lead plates can buckle under continuous
  high-amperage discharge and eventually this and sulphation shorts an individual
  cell, dropping the battery voltage).
  The Odessey and the Tanya are both Absorbed Glass Mat tech - a tech which seems
  to offer a better life at the expense of lower Cold-Cranking Performance and
  capacity - a kind of compromise.  In my view this is perhaps best type suited
  to our application given the sometimes lengthy time gaps between use.  The 912S's
  higher capacity starter motor is rated at 0.9kW at 12v which translates to
  a demand of  300A for 1 sec and then 75A for the remainder to the maximum 10-second
  start cycle.  So providing the battery cabling is short and 4SWG/16mm2
  those were the reasons for my choice of the Odessey battery.
  Whilst Odessey list Aircraft use as an application, Tanya seem to list the EC680
  as predominantly a Motorcycle battery.  Even more curious is that Tanya will
  sell both batteries - with the EC680 being 20 cheaper.  Vibration durability
  perhaps?
  https://www.tayna.co.uk/industrial-batteries/odyssey/pc680/?gclid=EAIaIQobChMI7uHf9L244QIVz5TtCh17tgzhEAQYAiABEgKa3fD_BwE
  https://www.tayna.co.uk/motorcycle-batteries/enduroline/ec680/
  There is also a lot of re-badging going on in the battery world and i wonder if
  the PC680/EC680 is an example of that
  Hope it can add to the debate . . .
  http://forums.matronics.com/viewtopic.php?p=488535#488535
  ________________________________  Message 2  _____________________________________
  Time: 09:24:56 AM PST US
  Subject: Europa Aircraft - location change
  Please see the announcement by Europa.
  http://www.europa-aircraft.co.uk/news/item/europa-aircraft-is-moving
  John Wighton
  Europa XS trigear G-IPOD
  http://forums.matronics.com/viewtopic.php?p=488549#488549
  ________________________________  Message 3  _____________________________________
  Time: 12:13:16 PM PST US
  Clive, your reply is really helpful and your "re-badging" suggestion is more or
  less borne out by a man I spoke to at Tanya, although who's to say whether the
  "own brand" EC680 is of just as high a quality as the PC680. The 20 reduction
  in price might suggest cheaper components and processes.
  So I "bit the bullet" and ordered the Odyssey, after having been beaten into submission
  by the overwhelming flood of testimonials in its favour. Thanks to all
  for the repeated "lashes with the Odyssey whip". I feel so much better!
  http://forums.matronics.com/viewtopic.php?p=488552#488552
  st Email Forum -
  pa-List" id="LPlnk672319" class="OWAAutoLink" previewremoved="true"> http://www.matronics.com/Navigator?Europa-List
  p;   - MATRONICS WEB FORUMS -
  k776462" class="OWAAutoLink" previewremoved="true"> http://forums.matronics.com
  p;  - NEW MATRONICS LIST WIKI -
  17856" class="OWAAutoLink" previewremoved="true"> http://wiki.matronics.com
  p; - List Contribution Web Site -
  p;                  -Matt Dralle, List Admin.
  id="LPlnk576300" class="OWAAutoLink" previewremoved="true"> http://www.matronics.com/contribution
  |  | - The Matronics Europa-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		DuaneFamly(at)aol.com Guest
				 Posted: Sat Apr 06, 2019 3:38 pm    Post subject: PC680 battery |
				Hey Gary,
  I also run the OdesseyPC 680 to start my Jabiru 3300A. And while I am in the warm city of Las Vegas, it does get very cool here during the winter’s. During that time are use a 3A battery charger made by Schumacher called the Battery Extender. I picked it up at Walmart for about $25. It has several attachment leads that you can plug into it. I have permanently attached the leads that have the ring terminals to mount right onto the battery and then I drilled a small hole through the firewall in the very corner on the passenger side and fed the cable through there. When I’m leaving the plane for a long time I set the battery charger on the floor on the passenger side plug it in and I run an extension cord in through the flap slot up through one of the access panels just in front of the “D” window. This way the charger remains inside the plane and free from tampering. If you forward me your email address I can send you pictures of the unit that I use.
 Mike Duane
 N377EA EuropaXS
 Conventional Gear
 Las Vegas, NV
 [quote] On Apr 6, 2019, at 3:04 PM, Gary Leinberger <Gary.Leinberger(at)millersville.edu> wrote:
  Gary Leinberger
  N388SG
  Europa A237
  Lancaster, Pa., USA
  380 hours.
  HTML Version:
  Text Version:
  Hi Jonathan,
		freddythek10(at)gmail.com Guest
				 Posted: Sat Apr 06, 2019 4:18 pm    Post subject: PC680 battery |
				Gary...my PC680 is very happy being charged by an EnerSys charger ...sorry I can’t give you a model #... and it’s so light that I’ve mounted it onboard.
  Gary Leinberger
  N388SG
  Europa A237
  Lancaster, Pa., USA
  380 hours.
  HTML Version:
  Text Version:
  Hi Jonathan,
				 Posted: Sun Apr 07, 2019 10:06 am    Post subject: PC680 battery |
				Gary…my EnerSys charger is a 6 amp Odyssey charger…love the “auto-maintain” function…no problems as yet...with my MPEFI (electrically dependent) engine, I carry two PC680s and can toggle between them so they’re both monitored and fully charged…I installed a male plug on underside of fuselage (a thru-hull marine fitting w/ rubber closure) to provide 110v power…mounted it behind the “D” panel in which I cut a window in order to read the LED status lights.
 Can you describe the situation when your Odyssey charger “burned up”?
 Fred
  	  | Quote: | 	 		  On Apr 6, 2019, at 5:17 PM, Fred Klein <freddythek10(at)gmail.com (freddythek10(at)gmail.com)> wrote:
				 Posted: Sun Apr 07, 2019 11:29 am    Post subject: PC680 battery |
 Gary…a bit more info: my 6 amp charger is “Model TMAX-6A-1B”…do you recall the model designation for the Odyssey charger which “burned up”?
 Fred
 Fred
		dmac7
				 Posted: Mon Apr 08, 2019 8:44 am    Post subject: Re: PC680 battery |
				Reading the spec's of the PC680 then the PC625 I was left questioning why the popularity of the PC680?  It has lower power than the PC625 by 10 to 20% in all spec's. It's also 1 kilo heavier. Maybe the shape is the reason?  I asked the Odyssey rep why the better spec's on the PC 625 his reply "The PC625 is a more efficient design"
		ptag.dev(at)talktalk.net Guest
				 Posted: Mon Apr 08, 2019 9:52 am    Post subject: PC680 battery |
				All.....
 I consider the PC680 has a particular capability of being able to give up
 its power very quickly in the start process when compared with competition.
 I originally had a Jabiru 3300 which needed a very high cranking capability
 with the six pots coming onto the compression stroke in quick succession.
 Much larger batteries proved incapable to give out the start power  quickly
 enough, so I finished up with two p680 type( sometimes known as "RED TOP"
 ).in parallel.  When I changed engines to a 914 Rotax I kept the two
 batteries employed even though I have a heavy duty rotax starter. Keeping
 the two helps with redundancy issues too.
 I suffered exhaustive times starting the 6 cylinder engine and tried even
 heavy construction batteries with no success. All started in 1999 and I am
 now on my second pair nearly twenty years later! Having used both the
 originals on emergency car and lawn mower duties since recovery from the
 aircraft.
 Bob Harrison G-PTAG.
		rehn(at)rockisland.com Guest
				 Posted: Mon Apr 08, 2019 12:44 pm    Post subject: PC680 battery |
				I’ve been using the  PC680 with great success, it will hold a charge for a very long time, they seem to last forever too. I change them out at about five years and then use them in my ATV for another five years. I have one “used” on my work bench for 12 volt testing etc and charge it about once a year. I would definitely recommend them.
 Jerry Rehn
 Mono XS, 914
 On Apr 8, 2019, at 10:13 AM, <duanefamly(at)aol.com (duanefamly(at)aol.com)> <duanefamly(at)aol.com (duanefamly(at)aol.com)> wrote:
