		duanefamly(at)aol.com Guest
				 Posted: Wed Apr 17, 2019 6:02 am    Post subject: Europa-List: Europa Accident |
				Rick,
 This was your plane! Were you flying? Test flight? Anyway, so sorry to hear about this. Sounds like you got between a rock and a hard place trying to get back to the airport. I’m familiar with that area but not the airport in particular.
 I got a burn fuel (chemical) burn on my butt from a leaking vent line during my early hours, so I know how bad to stings. You were very lucky there was not ignition source for all that fuel.
 The picture says a lot about how hard the landing was. Put the nose gear under and behind the engine. But the engine seemed to have remained attached.
 This makes me a little leery. I am planning to join Erich Trombley this July to fly to Oshkosh. I guess I’m gonna make sure to remain over areas of easy access for rescue personnel and equipment.
 Touch base when you can.
 Mike Duane
 Las Vegas, Nevada
 Sent from Windows Mail
 Sent: â€ŽTuesday‎, ‎April‎ ‎16‎, ‎2019 ‎10‎:‎26‎ ‎PM
 To: europa-list(at)matronics.com (europa-list(at)matronics.com)
 Email           forwarded from Jabiru yahoo group.
 Any           Europa members in area?
 On test           flight near KDWA Yolo County Airport The Jabiru engine ceased           about ten minutes into the flight.  I leveled off at 3000 feet           and was cruising along and a 2950rpm when some went bang and I           lost power,  check everything over and observed that cylinder           #5 EGT  and CHT were running down.  Turned toward the           airport about 5 miles away.  Engine still running and figured           I'd make it OK .
 Turn a 2           mile final and the engine ceased!  It looked as the aiming           spot was in the center of the runway.  At 1/2 mile it started           moving towards me fast.  Looked at the MGL Odyssey and it           showed 690 feet.  Just then EFIS said I had a traffic at               6 o'clock at 300 feet.  I had to make hard decision; continue                 towards the airport with a plane under me and trees                 coming up.  I made a 90 degrees turn to the left.                  Picked the worse type on field, plowed with                       furrows straight in front of                       me.  Tricycle gear airplane.  I slipped it because                       I was too high and over did it.  Heading towards a                       weather station right in front of me.  Had to turn                       more left the back to the furrows,  about that                       time I run out of air.  Hit nose first flipped on                       my back.
 I                 was trapped in the cockpit for one hour with fuel                 running out the filler neck and leaking down to the                 center section where I was trapped.  Got first degree                 burns on my belly and down lower.  Got a helicopter ride                 to U.C. Davis.  The pilot of                           the 300 foot airplane was the first of there.                            He could not up me but the fire volunteer                           department was on there way.
 Will                           known more later, but reading this blog                                               I'm pretty sure the exhaust valve on #5                                                            failed.                                                              Will let you                                                           know more when                                                           the NTSB                                                           tearing the                                                           engine down.
 Engine G2 3300L   33a2120
 first flight  June 11. 2011
 Total Time 196.9
  Rick Stockton
 http://www.kathrynsreport.com/2019/04/europa-trigear-n120ej-accident-occurred.html
				 Posted: Wed Apr 17, 2019 6:13 am    Post subject: Europa-List: Europa Accident |
				This is the news report with one pix.
 Sent: â€ŽWednesday‎, ‎April‎ ‎17‎, ‎2019 ‎5‎:‎36‎ ‎AM
 --> Europa-List message posted by: Kingsley Hurst <kingsnjan(at)westnet.com.au>
 Very sorry to hear of your mishap Rick and do hope your injuries are not
 too significant.
 Best wishes from Down Under for a speedy recovery.
 Kingsley
 _-============================================================
 _-=          - The Europa-List Email Forum -
 _-= Use the Matronics List Features Navigator to browse
 _-= the many List utilities such as List Un/Subscription,
 _-= Archive Search & Download, 7-Day Browse, Chat, FAQ,
 _-= Photoshare, and much much more:
 _-=
 _-=   --> http://www.matronics.com/Navigator?Europa-List
 _-=
 _-=               - MATRONICS WEB FORUMS -
 _-= Same great content also available via the Web Forums!
 _-=
 _-=   --> http://forums.matronics.com
 _-=
 _-=              - NEW MATRONICS LIST WIKI -
 _-= Add some info to the Matronics Email List Wiki!
 _-=   --> http://wiki.matronics.com
 _-=             - List Contribution Web Site -
 _-=  Thank you for your generous support!
 _-=                              -Matt Dralle, List Admin.
 _-=   --> http://www.matronics.com/contribution
