		Kellym
				 Posted: Fri Apr 26, 2019 5:41 am    Post subject: Elevator pulsation |
				Has anyone else experienced vibration/pulsation in the elevator? Most
 noticeable on runup, and in cruise on autopilot. Vibration goes away
 when power is reduced for descent.  The only play I have found so far in
 the control system is the elevator trim tab cables allow about 1/16" up
 and down movement of the tabs at the trailing edge. I can't think such
 vibration is good for the health of the mechanicals, and can only think
 it is induced by prop power pulses hitting the elevator.
 Kelly
KCHD |
		Lenny Iszak
				 Posted: Fri Apr 26, 2019 6:37 am    Post subject: Elevator pulsation |
				Mine does it too. I machined a new trim bellcrank with pressed in ball bearings to take out all the slop I can from the elevator trim. The cable still allows some slop though. Pulsing is still there. I took a slo-mo video of the stick in flight to determine the pulse rate and it was about 2Hz. Prop blade pulses are RPM/2.
 I was thinking maybe it’s an elevator balance problem. Those were the first things I painted, and it took a few tries   so they may have ended up too heavy.
 Lenny
  	  | Quote: | 	 		   On Apr 26, 2019, at 9:41 AM, Kelly McMullen <kellym(at)aviating.com> wrote:
  Has anyone else experienced vibration/pulsation in the elevator? Most noticeable on runup, and in cruise on autopilot. Vibration goes away when power is reduced for descent.  The only play I have found so far in the control system is the elevator trim tab cables allow about 1/16" up and down movement of the tabs at the trailing edge. I can't think such vibration is good for the health of the mechanicals, and can only think it is induced by prop power pulses hitting the elevator.
  Kelly
  _________________ Lenny Iszak
Palm City, FL
2014 RV-10, N311LZ - 500 hrs |
		Kellym
				 Posted: Fri Apr 26, 2019 6:51 am    Post subject: Elevator pulsation |
				Glad (I guess) to hear it isn't just my aircraft. I don't know the pulse
 rate for mine, but I have 3 bladed MT prop, so I assume it would be in
 the 700-800 rate. I have no paint, so balance is per construction plans.
 Haven't had elevator off yet to see how close it is to the specs you get
 with finish kit. My elevator counterbalance fairings don't match as well
 as I think they should, but haven't tried to get leading edge fairing to
 match up better with elevator horns.
 On 4/26/2019 7:26 AM, Lenny Iszak wrote:
  Lenny
 > Kelly
KCHD |
		Lenny Iszak
				 Posted: Fri Apr 26, 2019 7:17 am    Post subject: Elevator pulsation |
				Good point. My counterbalance fairings don’t match very well either.
 Lenny
  	  | Quote: | 	 		   On Apr 26, 2019, at 10:50 AM, Kelly McMullen <kellym(at)aviating.com> wrote:
  Glad (I guess) to hear it isn't just my aircraft. I don't know the pulse rate for mine, but I have 3 bladed MT prop, so I assume it would be in the 700-800 rate. I have no paint, so balance is per construction plans. Haven't had elevator off yet to see how close it is to the specs you get with finish kit. My elevator counterbalance fairings don't match as well as I think they should, but haven't tried to get leading edge fairing to match up better with elevator horns.
 > Lenny
 >> Kelly
Palm City, FL
		bill.peyton
  Joined: 19 Sep 2010 Posts: 198 Location: St. Louis, MO
				 Posted: Fri Apr 26, 2019 8:07 am    Post subject: Re: Elevator pulsation |
				I have never noticed the vibration, but I did not like all of the slop in the current trim actuation design.  I redesigned the trim bell crank pivot point to reduce the slop, and I use #10 castellated nuts to hold the cable ends in lieu of the pins.  I have little to no play now.
  _________________ Bill
WA0SYV
Aviation Partners, LLC |
				 Posted: Fri Apr 26, 2019 8:45 am    Post subject: Elevator pulsation |
				Kelly, FWIW I haven't never experienced any elevator pulsation (my
 Miata's stick shift pulsates but that's a different matter).  I think my
 elevator counterweight to stabilizer fitting is relatively tight if a
 bit crudely finished.
 Bill in Durham NC
 On 4/26/2019 9:41 AM, Kelly McMullen wrote:
  Kelly
		Greg McFarlane
  Joined: 12 Apr 2012 Posts: 58 Location: Albany Western Australia
				 Posted: Sat Apr 27, 2019 1:07 am    Post subject: Re: Elevator pulsation |
				JFI, ... For sure the whole horizontal tail plane shakes and buffets with high power run ups on the ground, I think the solution to that is to keep that sort of operation to the minimum required and if possible with the aircraft moving especially for prop cycling. Regarding in flight, when on AP, our RV10 and AP (TruTrac) is particularly sensitive to out of pitch trim and close attention to trim is needed (or auto trim) otherwise the AP will cycle up and down to correct the out of trim situation, in our case very easy to recognise because the aircraft starts a little nodding motion. As far as elevator pulsation is concerned generally when in flight, I’m pretty sure that a lot of that is from turbulence in and around the elevator horns and the lightening holes in the outer horizontal rib, and that will vary depending on W&B.  Others have found a marked difference if those lightening holes are taped over or otherwise blocked. From day one our RV10  (now flown 400hrs) has had all those holes blanked off with tight fitting auto rubber blanking plugs that are securely contact glued in. We’ve never experienced any elevator pulsation.  Cheers from Western Australia.
		Bob Turner
				 Posted: Sat Apr 27, 2019 7:48 am    Post subject: Re: Elevator pulsation |
				I seem to recall that Tim Olsen reported elevator pulsing on his -14?? He noted that the fiberglass fairing on the elevator horn was thicker (vertical dimension) than the matching piece on the stabilizer. He fixed that, the pulsation went away. That is, if I remember correctly.
  _________________ Bob Turner
RV-10 QB |
		Tim Olson
				 Posted: Sat Apr 27, 2019 11:21 am    Post subject: Elevator pulsation |
				That’s not too far off, Bob, as far as Internet thread memory goes.   It was somebody else with an RV 14 that had a pulsing. I just had occasional brief periods when leveling out two crews trim that the plane would change trim just slightly but very quickly.The other person that you were referring to did indeed widen or I should say heighten his stabilizer tips so that they more completely shielded the elevator from airflow. That fixed it for him. Mine are just slightly smaller than the elevator horns.  I think it is a definite case that you should try to make sure that the stabilizer tips are as big or slightly bigger than the elevator horn’s in height, but mine are not quite like that, unfortunately. But it is a fairly occasional thing for me, and you have to be paying attention to notice it. Mine is not currently fixed. Mainly because after having it painted and having those tips fiberglass in over the rivet lines, the only way to fix it is probably to tear the tips off and then repaint the stabilizer. That’s probably not going to happen. At least not for something that is barely noticeable and only occasional.But mine does not pulse up and down. It’s more like you can feel a difference when the elevator horn hits the air flow versus when it’s not As far into the airflow.
 Anyway, yeah, that’s on the -14, but I think the parts are basically very similar.
  	  | Quote: | 	 		   On Apr 27, 2019, at 10:48 AM, Bob Turner <bobturner(at)alum.rpi.edu> wrote:
  Bob Turner
  RV-10 QB
  http://forums.matronics.com/viewtopic.php?p=488983#488983
