draftsjust417(at)gmail.co Guest
Posted: Sat May 25, 2019 10:26 am Post subject: Yak-List: Re: Yak-List: Re: Yak-List: Re: Pitot Heater: no h |
Ah, I stand corrected - thanks-
Justin
On Sat, May 25, 2019 at 6:26 PM doug sapp <dougsappllc(at)gmail.com (dougsappllc(at)gmail.com)> wrote:
| Quote: | Justin,The heating element is located within the first 4 inches of the pitot, I doubt anyone removed it as it is integral to the pitot. If you have a 4 inch chrome pitot on the tip of the mast/tube then you have the heated pitot complete. Rather it works or not that's a different issue.
On Sat, May 25, 2019 at 5:57 AM Justin Drafts <draftsjust417(at)gmail.com (draftsjust417(at)gmail.com)> wrote:
| Quote: | Good morning,
Not too long ago, I decided to look into why my own CJ6's pitot heat wasn't working at all.
There's a small but very helpful access panel, out behind the pitot mast on underside of the right wing, for servicing & inspections.
Turns out, someone (I strongly suspect in China?) had removed the pitot head heating element altogether, and just left the wiring loose in the pitot mast.
So I just secured the wiring, and - since I only fly my CJ in day VFR - that system inop until further notice.
If your wiring is disconnected and not properly capped/secured, there may be a very minor short that shows a weak electrical discharge?
If I recall correctly, the pitot heat cockpit switch is the type with an inherent circuit breaker/fuse in the switch itself.
Such heater elements are available, so one day after all the other gremlins are dealt with, I may re-install one.
Maybe these insights help... ?
Justin Drafts
N280NC
On Sat, May 25, 2019 at 12:19 PM Rob Rowe <yak-list(at)robrowe.plus.com (yak-list(at)robrowe.plus.com)> wrote:
