ELT ANTENNA
mike(at)vision499.com
PostPosted: Thu May 30, 2019 5:41 pm    Post subject: ELT ANTENNA Reply with quote
Where is a good place to locate the ELT antenna?
Mike Pienaar
mike(at)vision499.com (ike(at)vision499.com)
Home: +1 250-999-8121
Mike cell: +1 250-885-0554
1-1100 Tulip Ave, Victoria, BC, V8Z 0A2
www.avast.com [url=#DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2] [/url]
Robert Reed
PostPosted: Thu May 30, 2019 7:00 pm    Post subject: ELT ANTENNA Reply with quote
My first thought was in the damn trash can but I will resist giving my honest opinion. The ELT antenna was more trouble than all of the other antenna combined.
The obvious intent of all the ELT antennas seems to be mounting on the top of the fuselage towards the rear but for those of us building a wood or glass airplane the preferred location would be in the interior of the rear fuselage. That was my preferred location.
The interior mount poses several issues including a large ground plane size, a rather tall antenna and an connector that extends well below the mount and ground plane. Not sure which KIS you are building but the TR-4 has the added issue of rudder cables running down the middle of the rear fuselage area.
My solution was to use a shelf of fiberglass and aluminum angle frame to mount the ground plane and antenna. The frame is mounted across the rear fuselage just above the rudder cables and high enough to make cable connections without crimping the coax cable. The top of the antenna does hit the inside top but bends back without any problems.
Oh yes, I must add that it works quite well even from inside the hanger. When I had finished the installation and got ready for my inspection, I tried to arm the ELT and accidentally activated it. About ten minutes later I received a phone call. I was inside a closed metal hangar.
Bob Reed
On May 30, 2019, at 8:41 PM, <mike(at)vision499.com (mike(at)vision499.com)> <mike(at)vision499.com (mike(at)vision499.com)> wrote:
<![endif]--> <![endif]-->
Mike Pienaar
www.avast.com
GalinHdz
PostPosted: Fri May 31, 2019 3:44 am    Post subject: ELT ANTENNA Reply with quote
My solution is similar to Bob's but I attached it to the back part of the rear bulkhead. The bulkhead has a large hole, covered by a KIS Cruiser sign, for access to the rear seat belt shoulder harness connection during maintenance. This makes it simple to access the coax cable plug on the ELT antenna whenever I need to take the bulkhead off. I use a 90degree BNC connector to make easy accessing the plug.
I know it works since I also accidentally activated the ELT inside my hangar and within minutes got a call from the Air Force Search & Rescue center with the exact Lat/Lon of my position.
On Thu, May 30, 2019 at 9:42 PM <mike(at)vision499.com (mike(at)vision499.com)> wrote:
Mike Pienaar
mike(at)vision499.com (ike(at)vision499.com)[u][/u]
www.avast.com
[url=#m_-5583703127639950565_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2] [/url]
wschertz343(at)gmail.com
PostPosted: Fri May 31, 2019 5:28 am    Post subject: ELT ANTENNA Reply with quote
My solution was to mount the antenna behind the baggage bulkhead, mounted to the floor of the fuselage. It was on a bracket that elevated it enough to use a right angle connector, and the ground plane was 6 radial copper tape segments bonded to the fuselage. The one issue I had was that with the original positioning of the ELT itself, it would activate when I keyed the microphone. I had to move the box to find a location where the interference did not occur.Bill Schertz
On Fri, May 31, 2019 at 5:45 AM Galin Hernandez <galinhdz(at)gmail.com (galinhdz(at)gmail.com)> wrote:
Mike Pienaar
www.avast.com
[url=#m_-3351245362549239253_m_-5583703127639950565_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2] [/url]
Robert Reed
PostPosted: Fri May 31, 2019 7:21 am    Post subject: ELT ANTENNA Reply with quote
That’s where I ended up putting my transponder and ADSB antenna. One on each side with 12 inch square ground plane bonded to floor. Works well enough to pickup local traffic on Dynon while setting inside the hangar.
Bob Reed
On May 31, 2019, at 8:27 AM, William Schertz <wschertz343(at)gmail.com (wschertz343(at)gmail.com)> wrote:
Mike Pienaar
www.avast.com
PostPosted: Fri May 31, 2019 8:24 am    Post subject: ELT ANTENNA Reply with quote
Thanks to all with the help.
How do you join the separate strips of copper tape so that they conduct?
Just had a phone call from somebody who also had a problem with triggering his ELT but in his case it was the transponder and he had to put an attenuator on the transponder output
Off to the hangar now to see what I can do there
Thanks again
From: owner-kis-list-server(at)matronics.com <owner-kis-list-server(at)matronics.com> On Behalf Of Robert Reed
Sent: May 31, 2019 8:00 AM
To: kis-list(at)matronics.com
Subject: Re: ELT ANTENNA
Bob Reed
Bill Schertz
Mike Pienaar
www.avast.com
Robert Reed
PostPosted: Fri May 31, 2019 10:13 am    Post subject: ELT ANTENNA Reply with quote
I used very thin aluminum strips about one inch wide and a center disk of the same material. I riveted each of the strips to the center disk and fiberglass sheet. Used multi meter to confirm continuity.
I would have done similar if I had used copper tape. You can either remove the sticky from the tape or mate the top to the center. Pop rivets will ensure the contact and a quick check with multi meter will validate.
Bob Reed
On May 31, 2019, at 11:23 AM, <mike(at)vision499.com (mike(at)vision499.com)> <mike(at)vision499.com (mike(at)vision499.com)> wrote:
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} <![endif]--> <![endif]--> <![endif]-->
Thanks again
From: owner-kis-list-server(at)matronics.com (owner-kis-list-server(at)matronics.com) <owner-kis-list-server(at)matronics.com (owner-kis-list-server(at)matronics.com)> On Behalf Of Robert Reed
Subject: Re: KIS-List: ELT ANTENNA
Bob Reed
Bill Schertz
Mike Pienaar
www.avast.com
GalinHdz
PostPosted: Fri May 31, 2019 3:53 pm    Post subject: ELT ANTENNA Reply with quote
I used copper tape attached to the aluminum angle frame for the ground plane. It works great.
On Fri, May 31, 2019 at 2:14 PM Robert Reed <robertr237(at)att.net (robertr237(at)att.net)> wrote:
Bob Reed
Thanks again
Bob Reed
Bill Schertz
Mike Pienaar
www.avast.com
