AeroElectric-List Digest: 1 Msgs - 05/28/19
ronaldcox
PostPosted: Wed May 29, 2019 10:40 am    Post subject: AeroElectric-List Digest: 1 Msgs - 05/28/19 Reply with quote
Time: 02:02:50 PM PST US
Subject: Re: Aera 660 Bare Wire Cradle Question
From: "farmrjohn" <faithvineyard(at)yahoo.com (faithvineyard(at)yahoo.com)>
Bare Wire Question, Part II.  I asked Garmin about the AWG for the wires in the
harness.  Their reply 20AWG for power and ground, and 26AWG or 28AWG for the
others.  The pins I see online at Aircraft Spruce of Steinair only show 20-24AWG
as the working range.  Are pins for the smaller wires available, and will they
work in a standard d-sub connector?  I would use either 20 or 22 for the connections
to the rest of the airplane.
http://forums.matronics.com/viewtopic.php?p=489386#489386
John,
As Bob has pointed out before here, you can use those pins for the smaller wires, or you can just wire everything with 22 gauge wire. The weight penalty will be minuscule.
If you're determined to use those tiny wires, you can just fold them over double and insert them into the pins before you crimp or solder them.
Ron
Ron Cox
Glasair Super II F/T
Under Construction at C77 - Still just about to fly!
bmwr606
PostPosted: Tue Jun 04, 2019 12:31 pm    Post subject: AeroElectric-List Digest: 1 Msgs - 05/28/19 Reply with quote
i subscribe to 3 list digests.i have not received any digests since 5/28/19.
i checked online using the subscription tool and am still subscribed to the 3 lists.
anyone know if there is a problem or what my next step might be?
thanks
scott
