Mono Brake Line
rparigoris
PostPosted: Tue Jun 18, 2019 7:27 am    Post subject: Mono Brake Line Reply with quote
Hi Group
If anyone needs some Brake Line for a Mono (6mm x 4mm), I had to buy a hundred feet of it. https://www.usplastic.com/catalog/item.aspx?sku=58521
Ron Parigoris
rparigoris
PostPosted: Tue Jun 18, 2019 3:16 pm    Post subject: Re: Mono Brake Line Reply with quote
BTW in case anyone wants to know how Nylon 6 will hold up with Brake Fluid:
file:///C:/Users/Parigoris/Downloads/Gehr_Chemical_Resistance_Chart%20(4).pdf I imagine they are considering Brake Fluid to be Dot 3 or Dot 4. PA 6 is Nylon 6 which is the tube I purchased, PA 6.6 is Nylon 66. The website says working pressure is only 720psi (at) 73F,m they don't mention burtst pressure, but I can tell you it feels the same with about the same bend radius as the Black tube supplied from Europa and after tightening the nut, creates a "mush / push" pseudo crimp that looks exactly like the black supplied hose with about the same amount of torquing the nut as the supplied Black.
Note you need to copy and paste URL including (4).pdf
Ron Parigoris
