Eric_Kallio
Joined: 29 Jan 2006 Posts: 149 Location: Baton Rouge, LA
Posted: Fri Jul 21, 2006 6:19 am Post subject: Tail strobe light installation |
When fitting the lower rudder fairing, with the tail strobe installed, where have most of you run the wire through the Aft bulkheads of the tailcone? Didn't know if any of the later plan sections tell you where, or if any of the engineers out there figured where the least stress on the structure would be to drill the hole. Thanks.
Eric Kallio
518 Empennage fairings
jesse(at)itecusa.org Guest
Posted: Fri Jul 21, 2006 7:15 am Post subject: Tail strobe light installation |
If you pull up the Wiring Harness instructions from Tim's secure Builder's
page, they say to drill the hole right below the bottom hinge bracket, right
through the top of the tie-down support, if I am not mistaken. That's where
we did it and it seems to work great.
Jesse Saint
I-TEC, Inc.
www.itecusa.org
W: 352-465-4545
C: 352-427-0285
Rick S.
Posted: Fri Jul 21, 2006 7:22 am Post subject: Tail strobe light installation |
Eric,
I emailed the wiring harness instructions directly to you instead of posting the file. It shows where and how to do the tail strobe.
Rick S.
40185
_________________ Rick S.
RV-10
40185 |
armywrights(at)adelphia.n Guest
Posted: Fri Jul 21, 2006 1:48 pm Post subject: Tail strobe light installation |
I read something that I believe was from Van's that they drill the hole off
of centerline so you'd miss the aft tiedown. This way if you ever have to
get back inside the aft tailcone you don't have to drill the tiedown out as
well to replace parts.
Rob
#392
QB Wings
