COMPRESSION CHECK
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> M14PEngines-List
Snazpappy
PostPosted: Fri Aug 09, 2019 2:30 pm    Post subject: COMPRESSION CHECK Reply with quote
I need to do a compression check on my engine to find out why I am burning/blowing out excessive oil.
I was told to do a differential compression check, I was reading the M14P maintenance manual and Task Card 248 "Check Of Cylinder Compression" instructs you to check compression with a pressure gauge.
My question is, Is one way better than the other?
I am referring to M14PF-XDK on a YAK 52TW
Snazpappy
- The Matronics M14PEngines-List Email Forum -
http://www.matronics.com/Navigator?M14PEngines-List
dsavarese0812(at)bellsout
PostPosted: Fri Aug 09, 2019 3:39 pm    Post subject: COMPRESSION CHECK Reply with quote
If the manual you reference does not provide specific parameters to check the compression with a pressure gauge, then my suggestion would be to use the industry accepted differential compression test.
Dennis
On Friday, August 9, 2019, 6:33:07 PM EDT, Snazpappy <snazman1(at)hotmail.com> wrote:
--> M14PEngines-List message posted by: "Snazpappy" <snazman1(at)hotmail.com (snazman1(at)hotmail.com)>
Snazpappy
http://forums.matronics.com/viewtopic.php?p=490780#490780
http://forums.matronics.com< - NEW MATRONICS LIST WIKI -
low" target="_blank">http://wiki.matronics.com
http://www.matr====
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> M14PEngines-List All times are GMT - 8 Hours
