Bent EGT Probe Acceptable?
jdubner
PostPosted: Sat Aug 17, 2019 5:33 am    Post subject: Bent EGT Probe Acceptable? Reply with quote
Would it be permissible to bend an EGT probe as in the attached image and still receive good service from it? This is for avoiding interference with the cowl and other obstructions in a Long-EZ installation.
Joe
 Filesize:  182.31 KB
 Viewed:  5666 Time(s)
Independence, OR
racerjerry
PostPosted: Sun Aug 18, 2019 3:38 am    Post subject: Re: Bent EGT Probe Acceptable? Reply with quote
My guess is that there should be no problems. The temperature sensing thermocouple element is actually the welded junction of the two dissimilar metals that make up the thermocouple. Disturbing the stainless protective housing, especially outside the hose clamp area, SHOULD have no effect.
Jerry King
Jerry King
jdubner
PostPosted: Mon Aug 19, 2019 1:38 pm    Post subject: Re: Bent EGT Probe Acceptable? Reply with quote
Thanks, Jerry. That's what I was thinking too although I have not heard of it being done.
Independence, OR
