ARINC Wiring Shield?
art(at)zemon.name
PostPosted: Mon Aug 26, 2019 3:47 am    Post subject: ARINC Wiring Shield? Reply with quote
Folks,
I am about to integrate one of the new Garmin 175 GPS receivers into my airplane and that involves a couple of ARINC wire pairs. I am surprised to see that the MGL-to-Garmin integration guide suggests shielded twisted pair wiring. From my read of the signaling, ARINC uses a voltage differential between the wires so it should be immune to noise and not require shielding (much like the CAN bus).
Is shielding actually required (or even commonly suggested) for ARINC wire pairs?
    -- Art Z.
https://CheerfulCurmudgeon.com/Love the stranger for you yourselves were strangers in Egypt. Deut. 10:19
dj_theis
PostPosted: Tue Aug 27, 2019 5:34 am    Post subject: Re: ARINC Wiring Shield? Reply with quote
Hi Art,
I think it might be a case of “belt and suspenders” but in the industrial arena, it is not uncommon for vendors implementing CAN networks to recommend twisted + shielded cabling.
https://www.belden.com/hubfs/resources/technical/technical-data/english/773105T.pdf?hsLang=en
Granted, an airplane is not as electrically ”noisy” as a modern manufacturing site but as I expect the more learned contibutors to the forum will advocate, following the vendor’s recommended installation practices is usually good advice.
Best regards,
Dan.
Dan Theis
Scratch building Sonex #1362
Revmaster Alternator problem solved.
PostPosted: Tue Aug 27, 2019 2:29 pm    Post subject: ARINC Wiring Shield? Reply with quote
At 08:34 AM 8/27/2019, you wrote:
--> AeroElectric-List message posted by: "dj_theis" <djtheis58(at)gmail.com>
Hi Art,
Yeah . . . probably . . . but about the only way
you can buy twisted pair is under a shield. I've
probably got a few thousand feed of 2x22S . . .
how many feet do you need . . . send me a mailing
address
henador_titzoff(at)yahoo.
PostPosted: Wed Aug 28, 2019 4:34 am    Post subject: ARINC Wiring Shield? Reply with quote
"Yeah . . . probably . . . but about the only way  you can buy twisted pair is under a shield."
This is not quite true, Bob.  There are several examples of twisted wire cables that do not have shields.  The most ubiquitous example is Ethernet, also known as 10BASE-T, 100BASE-T and 1000BASE-T. These three media are basically the same but are modified slightly to accommodate faster and faster data transmission.  They are defined in the IEEE 802 standard. These 3 cables are hardly distinguishable by the naked eye except for color coded plastic jackets, and they contain no shielding. They only contain 4 twisted wire pairs that are held in close proximity to each other by the jacket.
It was determined by defense contractors back in the 1980s that twisted wires will accomplish two things.  First, each pair keeps its magnetic field to a bare minimum by ensuring that the twisted wires are in close proximity to each other.  As current flow in one direction on one wire, its mate carries the return current back to its source.  The resulting opposite magnetic fields from each wire cancel each other out due to their close proximity. This means that their twin magnetic fields do not interfere with the other twisted wire pairs' magnetic fields.  Second, if the twisted wire pair transmitters and receivers are differential instead of single-ended, they can reject offending magnetic fields, because the injected voltages are the same in the two wires, due to their proximity to each other. The differential receiver sees the offending voltages but rejects them due to its design.
The major defense contractors have known about this technique for a while now and have implemented them in both wire cables and printed circuit boards to reduce the chances of electromagnetic interference.  Minor defense contractors and commercial companies have taken a much longer time to discover how to transmit signals from point A to B and have made painstaking mistakes that have affected their schedules and reliability tremendously.  In many cases, they still haven't figured it out.
All of this came about because of increasing signal speeds.  Most people think of signal speeds in terms of clock speed.  The correct way of looking at it is the signal's rising and edge times. The true electromagnetic spectra of these rising and falling edges can be studied by use of the Fourier transform.  This transform will reconstruct the edges using discrete frequency spectra, whose frequencies extend harmonically beyond the clock speed. In other words, the frequencies generated by a simple clock or signal pulse go way beyond what you will see on the signal's oscilloscope waveform.  Then by using Maxwell's equations, one can study how the fields radiate out and come up with solutions.
Today's technology is much different than 1980s technology, with spectra going into the microwave region. In the commercial world, major companies like Intel have had to develop and rely on tools that study both motherboard and IC layouts to minimize interference from closely placed components.  They have developed techniques like microstrip and stripline to minimize electromagnetic interference, much like what twisted wire pairs do.  They do not rely on shielding, because they're keeping each signal's offending magnetic fields to a bare minimum, even when located microns from each other.  The two methods mentioned above were borrowed from the radar world. In other words, it took RF engineers to solve computer engineers' problems as speeds increased.
In my opinion, the EFIS manufacturers are behind the 8-ball, mostly because their engineers have not been exposed to what I say above.  Furthermore, these companies are really run by software engineers who are living in the ideal world and have no clue about signals and their spectra and how to control them. I've seen several examples of EFIS manufacturers solve "glitches" with software.  These software patches are only band-aids and continue to proliferate in future designs, because they don't truly understand the problem.  As band-aids accumulate, the EFIS functionalities become even more quirky.  I see this in many other products, and people explain them away as "just a glitch."
Shields are used by the "experts" for two reasons.  One is to provide a more uniform controlled impedance to transmit RF power and receive weak RF energy.  Two is for physical integrity such as the wire telling the ignition mag to turn on and off. That wire could easily be replaced with a twisted wire pair, but shielding provides better physical protection.  You could run it in a PVC pipe and accomplish the same thing.
I know this all sounds mysterious to most people, but I know for a fact that 3 defense manufacturers started looking at signal integrity problems starting in the 1980s when things started getting faster, and glitches started popping up.  These 3 companies wrote design manuals for their engineers to follow.  These books were cook books designed to avoid previously made mistakes. They actually have review boards that ensure the guidelines were followed.  If you don't follow them, you better have a damn good reason why you didn't. I know of several cases where design engineers actually came up with better ideas, and the design manuals were revised.  In all cases, reliability and problem free operation overrode other factors
PostPosted: Wed Aug 28, 2019 10:40 am    Post subject: ARINC Wiring Shield? Reply with quote
>This is not quite true, Bob. There are several examples of twisted wire cables that do not have shields. The most ubiquitous example is Ethernet, also >known as 10BASE-T, 100BASE-T and 1000BASE-T.
But where would we find Cat5 cable
on an airplane? I was speaking of wire
I might pull from inventory at Beech . . .
Kellym
PostPosted: Wed Aug 28, 2019 12:18 pm    Post subject: ARINC Wiring Shield? Reply with quote
Well, my Dynon Skyview screens use Cat5 wire between the 2 screens to
sync data updates and common data like altimeter setting, etc. Not
required but eases syncing of things. Otherwise, no, I don't think of
any uses for ethernet cabling in aircraft.
Kelly McMullen
KCHD
PostPosted: Wed Aug 28, 2019 4:11 pm    Post subject: ARINC Wiring Shield? Reply with quote
I used Ethernet cable as an example of twisted wire without a shield being in use.
For aircraft use, twisted wire pairs without a shield are easy to find - they're in in Beech inventory. All you do is twist 2 same length Tefzel wires by holding one end in a vise and putting the other 2 ends in a drill.  The drill will twist them together. Remember that the wires do not have to be tightly wound, which makes them awkward to work with and adds weight. They only have to be wound enough to keep them in close proximity. Also, you don't really need a drill. You can hand twist them, because they don't have to be tightly wound.
The trick to a well designed, highly reliable system is to run as many signals as possible using twisted wire pairs. This minimizes offenders that may induce voltages in signal wires that aren't twisted (stragglers). Even power wires to black boxes should be twisted, because power surges can also create magnetic fields.
Henador Titzoff
On Wednesday, August 28, 2019, 03:39:55 PM EDT, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com> wrote:
PostPosted: Wed Aug 28, 2019 6:54 pm    Post subject: ARINC Wiring Shield? Reply with quote
At 03:15 PM 8/28/2019, you wrote:
--> AeroElectric-List message posted by: Kelly McMullen <kellym(at)aviating.com>
Well, my Dynon Skyview screens use Cat5 wire between the 2 screens to sync data updates and common data like altimeter setting, etc. Not required but eases syncing of things. Otherwise, no, I don't think of any uses for ethernet cabling in aircraft.
. . . but of course. I've seen some
products exploit the value of crimp
on RJ series connectors. I've got
some transceivers that have RJ45
connectors on the microphone.
The logical extension of using
those connectors is to exploit the
constellation of off-the-shelf
connectors, wire and tooling.
jsajpf
PostPosted: Thu Aug 29, 2019 1:10 pm    Post subject: Re: ARINC Wiring Shield? Reply with quote
Do a web search for FAA Report DOT/FAA/CT-86/40, “Aircraft Electromagnetic Compatibility" and review discussions on shielding. Section 3.3.1 deals with shielding ARINC 429 signal wires.
The doc is somewhat dated now, having come out after the first generation of airplanes making heavy use of the ARINC 429 protocol were certified. Its been a foundational document in developing design and analysis assumptions (at least in large transport category airplanes). The principles remain valid even in the age of AFDX/ARINC 664 ethernet based protocols.
I personally wouldn't want to spend the energy justifying (if even only to myself) deviating from installation recommendations in this matter.
matronics(at)rtist.nl
PostPosted: Fri Aug 30, 2019 2:57 am    Post subject: ARINC Wiring Shield? Reply with quote
In addition, the shielding may help to gain mechanical strength and
chafing protection.
Rob
On 8/27/2019 3:34 PM, dj_theis wrote:
Hi Art,
Best regards,
Dan.
