flysrv10(at)gmail.com Guest
Posted: Sat Sep 28, 2019 2:37 pm Post subject: NavWorx does not report |
No problem. I will figure it out with the help from Phil Yoder and hopefully Advance.
Rob Kermanj
Quote: | On Sep 28, 2019, at 5:19 PM, Bob Leffler <bob(at)thelefflers.com (bob(at)thelefflers.com)> wrote:
I believe so, but to be honest, I sold my box shortly after I got the AMOC approved through the FAA. It’s amazing how quickly you forget things that were once committed to memory. I went to look for the docs I submited to the FAA, but I couldn’t quickly find them.
From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) <owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)> On Behalf Of Rob KermanjSent: Saturday, September 28, 2019 4:51 PMTo: rv10-list(at)matronics.com (rv10-list(at)matronics.com)Subject: Re: NavWorx does not report
Bob, Checking the Installation manual, it looks like pin 34 is GPS position source RX. Are you able to verify that?
If so, I need to trace that pin back to IFD.
Do not archive.
Rob Kermanj
Quote: | On Sep 28, 2019, at 4:21 PM, Bob Leffler <bob(at)thelefflers.com (bob(at)thelefflers.com)> wrote:
No, it doesn’t go through the AFS for the ADSB function. It needs a dedicated serial out from your IFD. It needs to be set for the correct baud rate and ADSB+. The most common mistake is using ADSB instead of ADSB+ on the Garmin navigators. I do not know if IFD has the same options.
The schematics are well documented in the Navworx manual.
Have you complied with the AMOC yet?
From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) <owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)> On Behalf Of Rob KermanjSent: Saturday, September 28, 2019 4:06 PMTo: rv10-list(at)matronics.com (rv10-list(at)matronics.com)Subject: Re: NavWorx does not report
Avidyne IFD 540 with Advanced Flight Systems 5800. I am not sure if GPS position is passed through AFS or not. From my wiring diagram, it would seems so. But setting up NavWorx to IFD is straight forward. The dropdown menuin NavWorx software even names IFD 540.
I am with you; my wiring from Advance is top notch but I have nothing else to go by. Perhaps how the position info is routed to NavWorx might clear up how to go about trouble shooting.
Do not archive.
Rob Kermanj
Quote: | On Sep 28, 2019, at 3:51 PM, Phil Yoder <phil(at)philyoder.com (phil(at)philyoder.com)> wrote:
The correct protocol needs to be set on both your gps and the Navworx box. Wiring is the last thing I’d suspect if it was working prior. The issues Navworx has never had to do with communications between the gps and their box to my knowledge - but getting it set up properly took done work.
What gps are you using?
Phil Yoder.
On Sat, Sep 28, 2019 at 3:36 PM Joey Ferreyra <joeyferreyra(at)gmail.com (joeyferreyra(at)gmail.com)> wrote:
Quote: | I wonder if it’s affected with the issues that they were unable to resolve before closing shop?
https://www.aopa.org/news-and-media/all-news/2017/october/20/navworx-calls-it-quits
Joey
On Sat, Sep 28, 2019 at 1:53 PM Rob Kermanj <flysrv10(at)gmail.com (flysrv10(at)gmail.com)> wrote:
Quote: | Hi jesse,
Just installed your box and the issue remains. NavWorx software sez no GPS position. I guess I might have a bad connection; you agree?
Will FedEX your box on Monday. Thank you again for your help.
Rob Kermanj772-418-1417
Quote: | On Sep 20, 2019, at 5:09 PM, Jesse Saint <jesse(at)saintaviation.com (jesse(at)saintaviation.com)> wrote:
--> RV10-List message posted by: Jesse Saint <jesse(at)saintaviation.com (jesse(at)saintaviation.com)>I am in Marion County (X35). I have a couple of them on the shelf that you can test with.
| <IMG_2367.jpeg><IMG_2368.jpeg>
Phil Yoder phil(at)philyoder.com (phil(at)philyoder.com) \__________o-( )-o__________/ www.itsnotthatcomplex.com
Posted: Sat Sep 28, 2019 4:37 pm Post subject: NavWorx does not report |
I think you need the Time Mark line(s) and ADSB+ (G).
Jesse Saint
Saint Aviation, Inc.
352-427-0285
Sent from my iPad
Avidyne IFD 540 with Advanced Flight Systems 5800. �I am not sure if GPS position is passed through AFS or not. From my wiring diagram, it would seems so. But setting up NavWorx to IFD is straight forward. The dropdown menuin NavWorx software even names IFD 540.
Do not archive.
Rob Kermanj
Phil Yoder.
Joey
Quote: |
Hi jesse,
Just installed your box and the issue remains.� NavWorx software sez no GPS position. I guess I might have a bad connection; you agree?
Rob Kermanj
772-418-1417
Quote: |
Jesse Saint
C: 352-427-0285
F: 815-377-3694
Quote: |
On Sep 20, 2019, at 4:57 PM, Rob Kermanj <flysrv10(at)gmail.com (flysrv10(at)gmail.com)> wrote:
--> RV10-List message posted by: Rob Kermanj <flysrv10(at)gmail.com (flysrv10(at)gmail.com)>
Thanks Jessie. U are still in Sebastian, right?
Let me know when I can meet up with u. I appreciate everyone’s quick offer. I am speechless.
Rob
Phil Yoder�phil(at)philyoder.com (phil(at)philyoder.com) \__________o-( )-o__________/ www.itsnotthatcomplex.com
Posted: Sun Sep 29, 2019 2:14 am Post subject: NavWorx does not report |
HI Jesse,
What is the Time Mark Line? A dropdown setting in NavWorx?
Rob Kermanj
Quote: | On Sep 28, 2019, at 6:58 PM, Jesse Saint <jesse(at)saintaviation.com (jesse(at)saintaviation.com)> wrote:
I think you need the Time Mark line(s) and ADSB+ (G). Jesse Saint
352-427-0285
Sent from my iPad
Quote: | No, it doesn’t go through the AFS for the ADSB function. It needs a dedicated serial out from your IFD. It needs to be set for the correct baud rate and ADSB+. The most common mistake is using ADSB instead of ADSB+ on the Garmin navigators. I do not know if IFD has the same options.
Do not archive.
Rob Kermanj
Phil Yoder.
Joey
rleffler
Posted: Sun Sep 29, 2019 2:58 am Post subject: NavWorx does not report |
What version Navworx manual do you have?
There are two schematics in the appendix you should look at. ��One is for an AFS EFIS and the other is for your IFD.
Depending on the age of the manual, the external gps navigator info may not be there.
It’s a signal that syncs the time of the navigator and the Navworx. ��It’s a wire, not a menu choice.
Get Outlook for iOS
From: owner-rv10-list-server(at)matronics.com <owner-rv10-list-server(at)matronics.com> on behalf of Rob Kermanj <flysrv10(at)gmail.com>
Sent: Sunday, September 29, 2019 6:13:00 AM
To: rv10-list(at)matronics.com <rv10-list(at)matronics.com>
Subject: Re: RV10-List: NavWorx does not report �
HI Jesse,
What is the Time Mark Line? �A dropdown setting in NavWorx?
Rob Kermanj
I think you need the Time Mark line(s) and ADSB+ (G).� Jesse Saint
352-427-0285
Sent from my iPad
Quote: | No, it doesn’t go through the AFS for the ADSB function.�� It needs a dedicated serial out from your IFD.�� It needs to be set for the correct baud rate and ADSB+.�� The most common mistake is using ADSB instead of ADSB+ on the Garmin navigators.� I do not know if IFD has the same options.
From:�owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)�<owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)>�On Behalf Of�Rob Kermanj Sent:�Saturday, September 28, 2019 4:06 PM To:�rv10-list(at)matronics.com (rv10-list(at)matronics.com) Subject:�Re: RV10-List: NavWorx does not report
Avidyne IFD 540 with Advanced Flight Systems 5800. �I am not sure if GPS position is passed through AFS or not. �From my wiring diagram, it would seems so. �But setting up NavWorx to IFD is straight forward. �The dropdown menuin NavWorx software even names IFD 540.
I am with you; my wiring from Advance is top notch but I have nothing else to go by. �Perhaps how the position info is routed to NavWorx might clear up how to go about trouble shooting.
Do not archive.
Rob Kermanj
The correct protocol needs to be set on both your gps and the Navworx box.� Wiring is the last thing I’d suspect if it was working prior.� The issues Navworx has never had to do with communications between the gps and their box to my knowledge - but getting it set up properly took done work.�
Phil Yoder.�
Joey
Quote: | Hi jesse,
Just installed your box and the issue remains.� NavWorx software sez no GPS position.� I guess I might have a bad connection; you agree?
Will FedEX your box on Monday.� Thank you again for your help.
Rob Kermanj 772-418-1417
--> RV10-List message posted by: Jesse Saint <jesse(at)saintaviation.com (jesse(at)saintaviation.com)> I am in Marion County (X35). I have a couple of them on the shelf that you can test with.
Quote: | Jesse Saint Saint Aviation, Inc. jesse(at)saintaviation.com (jesse(at)saintaviation.com) C: 352-427-0285 F: 815-377-3694
Quote: | On Sep 20, 2019, at 4:57 PM, Rob Kermanj <flysrv10(at)gmail.com (flysrv10(at)gmail.com)> wrote: --> RV10-List message posted by: Rob Kermanj <flysrv10(at)gmail.com (flysrv10(at)gmail.com)> Thanks Jessie. ��U are still in Sebastian, right? Let me know when I can meet up with u.� I appreciate everyone’s quick offer. I am speechless. � Rob Sent from my iPhone
Phil Yoder�phil(at)philyoder.com (phil(at)philyoder.com)�\__________o-( )-o__________/�www.itsnotthatcomplex.com
_________________ Bob Leffler
N410BL - Phase I
Posted: Sun Sep 29, 2019 3:10 am Post subject: NavWorx does not report |
Hi Bob,
I have 2016-2-12.
Just found the Time Mark, Pins 21 and 2 on NavWorx. These two pins are not on my wiring diagram. Hmmm.
Rob Kermanj
Quote: | On Sep 29, 2019, at 6:56 AM, Bob Leffler <bob(at)thelefflers.com (bob(at)thelefflers.com)> wrote:
There are two schematics in the appendix you should look at. One is for an AFS EFIS and the other is for your IFD.
It’s a signal that syncs the time of the navigator and the Navworx. It’s a wire, not a menu choice.
Get Outlook for iOS
From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) <owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)> on behalf of Rob Kermanj <flysrv10(at)gmail.com (flysrv10(at)gmail.com)> Sent: Sunday, September 29, 2019 6:13:00 AM To: rv10-list(at)matronics.com (rv10-list(at)matronics.com) <rv10-list(at)matronics.com (rv10-list(at)matronics.com)> Subject: Re: NavWorx does not report
HI Jesse,
Rob Kermanj
352-427-0285
Sent from my iPad
From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) <owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)> On Behalf Of Rob Kermanj Sent: Saturday, September 28, 2019 4:06 PM To: rv10-list(at)matronics.com (rv10-list(at)matronics.com) Subject: Re: NavWorx does not report
Do not archive.
Rob Kermanj
Phil Yoder.
Joey
Quote: | On Sep 20, 2019, at 4:57 PM, Rob Kermanj <flysrv10(at)gmail.com (flysrv10(at)gmail.com)> wrote: --> RV10-List message posted by: Rob Kermanj <flysrv10(at)gmail.com (flysrv10(at)gmail.com)> Thanks Jessie. U are still in Sebastian, right? Let me know when I can meet up with u. I appreciate everyone’s quick offer. I am speechless. Rob Sent from my iPhone
