Hartzell service bulletin, plug to replace grease fitting
Tim Olson
PostPosted: Mon Oct 21, 2019 8:15 am    Post subject: Hartzell service bulletin, plug to replace grease fitting Reply with quote
Thanks for posting this, Tim.
If you hear of a non-Hartzell source, let us know. I don't really want
to call up Hartzell and order 4 plugs for $.74/each and pay shipping,
but if a place like ACS started stocking them, I'd buy them when I
order other parts.
On 10/21/19 9:18 AM, Tim Lewis wrote:
Hartzell has noted that grease zerks are sometimes seizing (and
breaking) when they are removed for the hub grease process.  This 2016
Service Instruction introduces a plug to replace the zerk that is
removed every year (one plug per side).  The plugs are stronger than the
zerk, less likely to break off.
https://hartzellprop.com/wp-content/uploads/HC-SL-61-354-R00-W.pdf
Hartzell's 2018 price sheet lists them as $0.74 each.  I've not tried to
order them myself - I bought a couple from a local A&P who had ordered
several.
https://hartzellprop.com/wp-content/uploads/2018-Price-List-Orig.pdf
