Cylinder head nut wrench HS6A
jlpartington(at)reagan.co
PostPosted: Fri Oct 18, 2019 4:03 am    Post subject: Cylinder head nut wrench HS6A Reply with quote
I need one! �
Anyone got one I can beg, borrow, steal or even buy? Actually. I prefer the latter.
Pooh
rhgalyen
PostPosted: Tue Oct 22, 2019 5:52 am    Post subject: Re: Cylinder head nut wrench HS6A Reply with quote
If you have a torch, you can make your own, using a box end wrench and long extension. I have used a 9/16" base wrench for Lyc, & Cont. with some success.
pennington.construction.i
PostPosted: Tue Oct 22, 2019 7:17 am    Post subject: Cylinder head nut wrench HS6A Reply with quote
I am sure you have done this.
Reach out to Kristina at M14
And Richard Goode.
Both of those folks have been very helpful for me in the past.
Mark
On Tue, Oct 22, 2019 at 9:57 AM rhgalyen <rhgalyen(at)hotmail.com (rhgalyen(at)hotmail.com)> wrote:
--> Yak-List message posted by: "rhgalyen" <rhgalyen(at)hotmail.com (rhgalyen(at)hotmail.com)>
http://forums.matronics.com/viewtopic.php?p=491900#491900
GeorgeCoy
PostPosted: Tue Oct 22, 2019 7:50 am    Post subject: Cylinder head nut wrench HS6A Reply with quote
And  Doug Sapp sells them as well!
From: owner-yak-list-server(at)matronics.com [mailto:owner-yak-list-server(at)matronics.com] On Behalf Of Mark Pennington
Sent: Tuesday, October 22, 2019 11:17 AM
To: yak-list(at)matronics.com
Subject: Re: Re: Cylinder head nut wrench HS6A
And Richard Goode.
Mark
fishmouth500
PostPosted: Tue Oct 22, 2019 8:04 am    Post subject: Re: Cylinder head nut wrench HS6A Reply with quote
https://www.theyakcollection.com/store/p146/Cylinder_Base_Nut_Wrench%2C_M14-P.html
Yak, Nanchang, Wilga
8 in stock
https://www.screencast.com/t/FyfW8gwC
JB Soar
PostPosted: Tue Oct 22, 2019 8:53 am    Post subject: Cylinder head nut wrench HS6A Reply with quote
This cylinder base wrench is a lovely work of art.  It looks great in one's tool box.  'Essential if one ever needs to remove/install a cylinder...
On Tue, Oct 22, 2019 at 11:10 AM fishmouth500 <john.warwick1(at)gmail.com (john.warwick1(at)gmail.com)> wrote:
--> Yak-List message posted by: "fishmouth500" <john.warwick1(at)gmail.com (john.warwick1(at)gmail.com)>
8 in stock
http://forums.matronics.com/viewtopic.php?p=491905#491905
wlannon(at)shaw.ca
PostPosted: Tue Oct 22, 2019 10:11 am    Post subject: Cylinder head nut wrench HS6A Reply with quote
Very good looking tool and sorely needed!
I have been welding nuts on the Chinese and Russian ones for years in order
to measure torque. I have also for some years been advocating a torque
value based on an evaluation of stud size and thread form as compared to the
Pratt & Whitney. In this I have assumed an equivalent material strength
which I firmly believe is a valid assumption.
As a result I been advocating a torque value of 300 to 320 lb/in (25 to 26.6
lb/ft.) LUBRICATED. It is heartening to finally see an "official" value
published, particularly when it seems to validate my own. I was not aware
of Termikas and I could find nothing in any of the M14 documents that I
could locate.
Only question I have is "does Termikas specify dry or lubed?" Just
curious, for me it will remain "lubed".
The next crusade here may be to throw away the torque robbing tab washers
and replace with P&W Palnuts for safety??
Cheers;
Walt
