		Matt Dovey
  Joined: 13 May 2017 Posts: 48 Location: st albans, england
				 Posted: Thu Sep 26, 2019 10:17 am    Post subject: ASI Accurcay Dynon Pilot Head |
				Evening All,
 Has anyone fitted a Dynon heated pitot head and then performed the LAA's  ASI calibration. Using the heading method.Then inputted the data into their Excel spread sheet? If so what sort of accuracy did you get. The spread sheet is using certified aircraft standards for ASI error tolerances. I've had some leaks that I've sorted out. But I'm still fairly far outside the tolerance.
		carlp101
				 Posted: Mon Nov 04, 2019 3:51 pm    Post subject: Re: ASI Accurcay Dynon Pilot Head |
				Hi Matt,
 I've fitted the Dynon heated pitot and performed the calibration using the heading method. It was very accurate. Well within the requirements.
 Carl
		Matt Dovey
				 Posted: Mon Nov 04, 2019 10:18 pm    Post subject: Re: ASI Accurcay Dynon Pilot Head |
				Hi Carl,
 I've been working through the problem with the LAA. I've had to move my static source. I'm nearly there now.
 Where abouts did you fit you static port?
 Matt
		carlp101
				 Posted: Tue Nov 05, 2019 2:20 am    Post subject: Re: ASI Accurcay Dynon Pilot Head |
				Under the fuselage below the ADAHRS behind the rear parcel shelf.
