dave(at)cfisher.com Guest
Posted: Sun Jul 23, 2006 5:25 am Post subject: Geo engine talk |
Hi guys,
There was some talk of a GEO install by Bradley the other week. I came
across this website and thought it might be some use to anyone that looking
at a Geo.
http://nessaaircraft.net/index.htm
http://nessaaircraft.net/enginesFrame1Source1.htm
"Why not the 3 cylinder. This engine has harmonic problems, it roc-n-rolls
at low end. Example; you will need to install a heavy flywheel; the 4 lb
flex plate from the automatic transmission will fail on you. If this lets go
at 5000 rpm it will cause damage. Even after separation if nothing else you
will poop your pants. You will not know what caused the entire racket, you
may decide to force land and because it is going to be a bad day, now you
also damaged the aircraft and if you did not get physical damage yourself,
your mind will! This will lead to lock of confidence in the installation.
One of my experiences, not the pooping."
Seems he has some good knowledge of this engine, and it looks like he is a
Transport Canada amatuerbuilt inspector of soem sort.
Should be an invaluabel asset to anyone look at a GEO install
http://nessaaircraft.net/builderFrame1Source1.htm
Good Reading,
Dave
jc(at)arcom.com.au Guest
Posted: Sun Jul 23, 2006 1:45 pm Post subject: Geo engine talk |
I came across his site after I had come accross the harmonics prob and had
decided to fit the 1.3 , 4 cyl, with gear drive, fitting up now and so far
looking good in my Aeropup in OZ his site is very informative and backed up
my decision, if it goe's really well I may make it a factory supplied
option.
rgds 2 all
John Cotton
Aeropup Aircarft Works
www.aeropup.com
