Testing a strobe tube ?
gilles(at)elixir-aircraft
PostPosted: Tue Feb 04, 2020 3:26 am    Post subject: Testing a strobe tube ? Reply with quote
Hi all,
Due to illness, one buddy is selling some hardware.
What would be a simple way to test a Whelen strobe tube he bought some
time ago ?
No strobe power supply available, unfortunately..
Thanks for any input.
Best regards,
Gilles
http://contrails.free.fr
http://lapierre.skunkworks.free.fr
PostPosted: Tue Feb 04, 2020 8:50 am    Post subject: Testing a strobe tube ? Reply with quote
At 05:24 AM 2/4/2020, you wrote:
--> AeroElectric-List message posted by: Gilles Thesee <gilles(at)elixir-aircraft.com>
Hi all,
What would be a simple way to test a Whelen strobe tube he bought some time ago ?
Used, new old stock? How does the
tube look? Any signs of darkening
glass at the electrodes within
the tube?
These are simply xenon filled tubes
and have a VERY long shelf life.
Unless there are obvious signs of
usage, odds are that the tube
is fine.
PostPosted: Tue Feb 04, 2020 9:34 am    Post subject: Testing a strobe tube ? Reply with quote
  the tube?
  is fine.
Hi Bob,
Thank you for responding.
Actually - I believe - new old stock.
Did not see the tube myself, however here is a link to the link he - actually his wife - put on the Web :
 https://www.leboncoin.fr/sports_hobbies/1724492264.htm
Thanks again,
Best regards,
Gilles
echristley(at)att.net
PostPosted: Tue Feb 04, 2020 10:23 am    Post subject: Testing a strobe tube ? Reply with quote
On Tuesday, February 4, 2020, 6:27:02 AM EST, Gilles Thesee <gilles(at)elixir-aircraft.com> wrote:
time ago ?
You need thousands of volts across the terminals. Do it wrong, and you might not wake up next week. You might be able to hook it into a spark plugs circuit, counting on the coil to limit the power. . .but I wouldn't do that unless I was willing to throw it away.
PostPosted: Tue Feb 04, 2020 2:53 pm    Post subject: Testing a strobe tube ? Reply with quote
throw it away.
Few xenon flash tubes operate at such
voltages . . . those are usually
industrial sources of UV light.
Our a/c strobes, vehicle emergency strobes,
camera strobes operated in the 250 to
400v range. To test them, you need both
a steady source of flash-voltage paralleled
with an energy storage capacity -PLUS- a
much higher (1 to 3 kv) trigger pulse
feed to the trigger electrode. In cameras,
this takes two transformers. One to provide
a 200-400v charge on a capacitor . . .
a second to develop the higher voltage
trigger.
One of the simplest strobe circuits was
used in low-cost, timing lights . . .
[img]cid:.0[/img]
My first one plugged into the wall and
developed about 350 volts on the energy
storage capacitor. The trigger pulse came
from connection to the engine's #1
plug.
There's no really quick/n/dirty way
to test these critters other than to
plug it into a functioning system.
Given that its an out-of-the-box offering,
the risks are low.
 Filesize:  43.04 KB
 Viewed:  5078 Time(s)
PostPosted: Wed Feb 05, 2020 3:16 am    Post subject: Testing a strobe tube ? Reply with quote
  the risks are low.
Bob and Ernest,
Thank you for answering.
Passing on the info to my buddy's wife.
Best regards,
Gilles
