JohnFrance
Joined: 17 Sep 2014 Posts: 83 Location: Grenoble France
Posted: Fri Feb 21, 2020 10:49 am Post subject: 912 oil return line in silicon |
Hello,
I am replacing the hoses on my 912 and I am thinking of using silicon hose for the oil return line. This is probably the hose that is the most affected by heat as just above the exhaust system. It works in a low over pressure environment of around 0,35 bar yet I have never seen a silicon tube used on this line. On the other hand the oil pump feed line (used in an under pressure environment) is often made of silicon.
Is there a reason for not using a silicon return line as the rubber ones harden due to heat?
John
| - The Matronics RotaxEngines-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
_________________ Europa mono Nr 192 |
rtoth4310(at)gmail.com Guest
Posted: Fri Feb 21, 2020 10:58 am Post subject: 912 oil return line in silicon |
I think silIcone is good just watch your routing!
Quote: | On Feb 21, 2020, at 1:53 PM, JohnFrance <77alembert(at)gmail.com> wrote:
Hello,
John
Europa mono Nr 192
http://forums.matronics.com/viewtopic.php?p=494929#494929
Posted: Fri Feb 21, 2020 11:01 am Post subject: 912 oil return line in silicon |
John I believe silicon is fine just watch the routing around the exhaust. I have them on my 912
Hello,
John
Europa mono Nr 192
SPURPURA
Posted: Fri Feb 21, 2020 1:37 pm Post subject: Re: 912 oil return line in silicon |
Silicone will work but I’d still fire sleeve it.
_________________ N951EU - Tri-gear & 912ULS, N77EU- Mono & 914
I'D RATHER HAVE A BOTTLE IN FRONT OF ME THAN A FRONTAL LABOTAMY. |
rickofudall
Posted: Sat Feb 22, 2020 9:15 am Post subject: 912 oil return line in silicon |
What is the manufacturer's recommendation? IF they say it's okay, you're good to go. I've only used the blue silicone hose on coolant lines and the stuff, though pricey, is amazing. After 15 years on a 582 install (with a lot of outside time) it's still as supple as new. Over time it pays off in replacement costs and time spent. For your application I would recommend you run fire sleeve over it though.Best of luck and safe flying,
Rick
On Fri, Feb 21, 2020 at 1:05 PM Robert Toth <rtoth4310(at)gmail.com (rtoth4310(at)gmail.com)> wrote:
Quote: | --> RotaxEngines-List message posted by: Robert Toth <rtoth4310(at)gmail.com (rtoth4310(at)gmail.com)>
> On Feb 21, 2020, at 1:53 PM, JohnFrance <77alembert(at)gmail.com (77alembert(at)gmail.com)> wrote:
> --> RotaxEngines-List message posted by: "JohnFrance" <77alembert(at)gmail.com (77alembert(at)gmail.com)>
> Hello,
> Regards,
> John
> Europa mono Nr 192
br> fts!)
r> > rel="noreferrer" target="_blank">http://www.matronics.com/contribution
-Matt Dralle, List Admin.
xEngines-List" rel="noreferrer" target="_blank">http://www.matronics.com/Navigator?RotaxEngines-List
FORUMS -
WIKI -
b Site -
“Blessed are the cracked, for they shall let in the light.” Groucho Marx
kenryan
Posted: Mon Feb 24, 2020 7:00 am Post subject: 912 oil return line in silicon |
The Rotax Installation Manual lays out the required specs on oil hoses. As far as heat, silicone is usually better than rubber ((at)500F vs (at)375F). Another spec is resistance to vacuum (hose collapse). I don't remember what else is discussed. Check the Installation Manual against the specs of the hose you are considering.
On Fri, Feb 21, 2020 at 9:53 AM JohnFrance <77alembert(at)gmail.com (77alembert(at)gmail.com)> wrote:
Quote: | --> RotaxEngines-List message posted by: "JohnFrance" <77alembert(at)gmail.com (77alembert(at)gmail.com)>
Hello,
John
Europa mono Nr 192
br> fts!)
FORUMS -
WIKI -
b Site -
