Randy C-GRPY
Posted: Sat Feb 22, 2020 9:07 am Post subject: Power Duece Schottky diodes |
I want dual diodes to feed alternate power to critical components with only one power input. The ones sold by Perihelion Designs seem to fit the bill well but are quite pricey. Are they worth the cost or are there equally good, cheaper solutions to be considered?
Randy
ceengland7(at)gmail.com Guest
Posted: Sat Feb 22, 2020 10:11 am Post subject: Power Duece Schottky diodes |
On Sat, Feb 22, 2020 at 11:14 AM Randy C-GRPY <rpulis(at)shaw.ca (rpulis(at)shaw.ca)> wrote:
Quote: | --> AeroElectric-List message posted by: "Randy C-GRPY" <rpulis(at)shaw.ca (rpulis(at)shaw.ca)>
Randy
There are hundreds of choices on ebay, at prices all over the map (even for the same device). ex: The stps12045tv is a dual 60A 45V device with an electrically isolated base (simpler mounting) that can be found for as much as $75, or as little as 2 for $12, if you're willing to wait a few weeks for them to arrive from China. Mouser (major electronics supplier) has them for $20. If you spend more time searching, you might find some even cheaper; I did several months ago.
If you don't need that much current, you can get a whole bag of them for less than $10 in some cases. Do exercise caution when mounting any metal tabbed device, to be sure the tab isn't electrically common to one of the leads. When browsing, just look for voltage above ~20V, at whatever current you need. Remember that current ratings assume significant heat sinking; if you want to avoid mounting on a heat sink, just oversize the device significantly for the job. A legit heat sink will probably cost a lot more than upsizing the device.
https://www.ebay.com/sch/i.html?_from=R40&_trksid=m570.l1313&_nkw=dual+schottky+diode&_sacat=0&LH_TitleDesc=0&_osacat=0&_odkw=stps12045tv
jluckey(at)pacbell.net Guest
Posted: Sat Feb 22, 2020 10:32 am Post subject: Power Duece Schottky diodes |
Randy,
See if this meets your specs...
https://www.mouser.com/productdetail/stmicroelectronics/stth10002tv1?qs=Cak7mXXNf1WSROaFc2i88g%3D%3D
I'm using them to isolate my main buss in my RV-7.
-Jeff
On Saturday, February 22, 2020, 10:22:16 AM PST, Charlie England <ceengland7(at)gmail.com> wrote:
Randy
Randy C-GRPY
Posted: Sat Feb 22, 2020 11:00 am Post subject: Re: Power Duece Schottky diodes |
jluckey(at)pacbell.net wrote: | Randy,
-Jeff
On Saturday, February 22, 2020, 10:22:16 AM PST, Charlie England <ceengland7> wrote:
On Sat, Feb 22, 2020 at 11:14 AM Randy C-GRPY <rpulis> wrote:
Quote: | --> AeroElectric-List message posted by: "Randy C-GRPY" <rpulis>
Randy
https://www.ebay.com/sch/i.html?_from=R40&_trksid=m570.l1313&_nkw=dual+schottky+diode&_sacat=0&LH_TitleDesc=0&_osacat=0&_odkw=stps12045tv |
Thanks Jeff. That would probably work for my engine bus. It looks like that one has two power inputs with two discrete outputs. I was more thinking two power inputs with one power output.
I’m not too fussy about the 1V forward drop of that particular item. Also, no it might be oversized for what I need it for. I’m looking at components that draw 10 amps at 12v at most.
Randy
Randy C-GRPY
Posted: Sat Feb 22, 2020 11:36 am Post subject: Re: Power Duece Schottky diodes |
ceengland7(at)gmail.com wrote: | On Sat, Feb 22, 2020 at 11:14 AM Randy C-GRPY <rpulis> wrote:
Randy
Thanks Charlie. I will look into the link you provided.
Randy
Tim Olson
Posted: Sat Feb 22, 2020 11:45 am Post subject: Power Duece Schottky diodes |
That would work, but with a Vf of .7V, I think the idea that he
has is likely to use the Schottky for less voltage drop.
You can get similar Schottky diodes for similar prices and
only end up with .2 or .3V drop.
-Jeff
<mailto:rpulis(at)shaw.ca>> wrote:
<rpulis(at)shaw.ca <mailto:rpulis(at)shaw.ca>>
Randy
Posted: Sat Feb 22, 2020 11:53 am Post subject: Power Duece Schottky diodes |
On 2/22/2020 1:00 PM, Randy C-GRPY wrote:
> Randy,
> https://www.mouser.com/productdetail/stmicroelectronics/stth10002tv1?qs=Cak7mXXNf1WSROaFc2i88g%3D%3D (https://www.mouser.com/productdetail/stmicroelectronics/stth10002tv1?qs=Cak7mXXNf1WSROaFc2i88g%3D%3D)
> -Jeff
> On Saturday, February 22, 2020, 10:22:16 AM PST, Charlie England wrote:
>> Thanks
>> Randy
> https://www.ebay.com/sch/i.html?_from=R40&_trksid=m570.l1313&_nkw=dual+schottky+diode&_sacat=0&LH_TitleDesc=0&_osacat=0&_odkw=stps12045tv (https://www.ebay.com/sch/i.html?_from=R40&_trksid=m570.l1313&_nkw=dual+schottky+diode&_sacat=0&LH_TitleDesc=0&_osacat=0&_odkw=stps12045tv)
Randy
The part # I quoted, and the link Jeff sent, are the same package.
Jeff's version is 50A current handling instead of 60A and 200V instead
of 40V. Either one can do what you want by simply tying the cathodes
together. It'll cost you an extra ring terminal (and a butt splice, if
you feed the output through a few inches of 'ballast' wire off each
terminal).
Posted: Sat Feb 22, 2020 12:51 pm Post subject: Power Duece Schottky diodes |
Randy,
It's a 2 diode package. You can wire it any way you want.
Let me know if you have any questions,
-Jeff
On Saturday, February 22, 2020, 11:11:46 AM PST, Randy C-GRPY <rpulis(at)shaw.ca> wrote:
Quote: | See if this meets your specs...
Quote: | I'm using them to isolate my main buss in my RV-7.
Quote: | � � On Saturday, February 22, 2020, 10:22:16 AM PST, Charlie England wrote:�
Quote: | On Sat, Feb 22, 2020 at 11:14 AM Randy C-GRPY wrote:
Quote: | > --> AeroElectric-List message posted by: "Randy C-GRPY"
Quote: | > I want dual diodes to feed alternate power to critical components with only one power input. The ones sold by Perihelion Designs seem to fit the bill well but are quite pricey. Are they worth the cost or are there equally good, cheaper solutions to be considered?
Quote: | There are hundreds of choices on ebay, at prices all over the map (even for the same device). ex: The stps12045tv is a dual 60A 45V device with an electrically isolated base (simpler mounting) that can be found for as much as $75, or as little as 2 for $12, if you're willing to wait a few weeks for them to arrive from China. Mouser (major electronics supplier) has them for $20. If you spend more time searching, you might find some even cheaper; I did several months ago.
Quote: | If you don't need that much current, you can get a whole bag of them for less than $10 in some cases. Do exercise caution when mounting any metal tabbed device, to be sure the tab isn't electrically common to one of the leads. When browsing, just look for voltage above ~20V, at whatever current you need. Remember that current ratings assume significant heat sinking; if you want to avoid mounting on a heat sink, just oversize the device significantly for the job. A legit heat sink will probably cost a lot more than upsizing the device.
Randy
http://forums.matronics.com/viewtopic.php?p=494947#494947
_-= (And Get Some AWESOME FREE Gifts!)http://www.matronics.com/contributions.matronics.com" target="_blank">http://forums.matronics.com
_-= --> = � -Matt Dralle, List Admin.
Joined: 28 Mar 2008 Posts: 1938 Location: Riley TWP Michigan
Posted: Sat Feb 22, 2020 12:53 pm Post subject: Re: Power Duece Schottky diodes |
Mouser part: 511-STPS200170TV1Y
Mouser part: 78-VS-QA250FA20
Mouser part: 863-MBRF20L45CTG only costs $0.83
_________________ Joe Gores |
chaskuss(at)yahoo.com Guest
Posted: Sat Feb 22, 2020 2:41 pm Post subject: Power Duece Schottky diodes |
Jeff and Randy, The diode pack that Jeff supplied the link to is not ideal for our purposes. It's really designed for heavy duty welding equipment. It has a seven tenths of a volt dro forward. That means that when power is being supplied through that diode pack you lose seven tenths of a volt. You want to try and find one of these things that only has a 0.2 or 0.3 volt drop in the forward Direction. Pull up the product data sheet for any of these that interest you. Then look on the datasheet for VF. That is the forward voltage drop rating for that device.
Sent from Yahoo Mail on Android
Quote: | � � On Saturday, February 22, 2020, 10:22:16 AM PST, Charlie England wrote: �
Randy
http://www.mat; &nb= - The AeroElectric-List Email Forum -oElectric-List" target="_blank">http://www.matronics.com/Navigator?AeroEl-========================sp; - MATRONICS WEB FORUMS -
http://forums - NEW MATRONICS LIST WIKI -
http://wiki.matronics.com
Randy C-GRPY
Posted: Sat Feb 22, 2020 3:04 pm Post subject: Re: Power Duece Schottky diodes |
Thanks fellas for chiming in. I'm on the steep part of the learning curve. I was thinking about using the DSS2X61-0045A although I'm still planning on browsing for less expensive alternatives that will do the job adequately. I like the style of the one referenced simply because it looks ready to connect and mount.
One question: For low current applications such as those in our aircraft, watts should be pretty low. How do I determine if a heat sink is required?
Also, how are the electrical connections made to the pins of the diode typically?
The diodes with the prongs look like there should be a matching plug.
Randy
Posted: Sat Feb 22, 2020 4:31 pm Post subject: Re: Power Duece Schottky diodes |
Most of the diodes discussed above will drop about 0.5 volts at 10 amps.
The power loss will be 0.5 x 10 = 5 watts. That will produce lots of heat.
Have you ever touched a 3 watt incandescent night light?
So yes, use a heat sink with heat conductive paste.
The aircraft structure can serve as a heat sink if it is aluminum.
If the diode mounting surface is not electrically insulated from the diode terminals, then some
type of dielectric heat conductive film must be used between the diode and mounting surface.
If a TO−220 diode is used, solder wires to the 3 terminals.
A coating of E6000 will insulate and protect the terminals from vibration.
johnbright
Joined: 14 Dec 2011 Posts: 166 Location: Newport News, VA
Posted: Sat Feb 22, 2020 4:43 pm Post subject: Re: Power Duece Schottky diodes |
Randy C-GRPY wrote: | Also, how are the electrical connections made to the pins of the diode typically?
Randy |
Hi Randy, those are TO-220 cases designed for circuit board mount. They have their very own Wikipedia page. https://en.m.wikipedia.org/wiki/TO-220
I suggest soldering to them like this: http://www.aeroelectric.com/articles/Solder_Lap_Splicing/Solder_Lap_Splices.html
Apply heat as quickly as possible to avoid damaging the diode.
_________________ John Bright, RV-6A, at FWF, O-360
Z-101 single batt dual alt SDS EM-5-F.
john_s_bright@yahoo.com, Newport News, Va
N1921R links |
Randy C-GRPY
Posted: Sat Feb 22, 2020 9:17 pm Post subject: Re: Power Duece Schottky diodes |
user9253 wrote: | Most of the diodes discussed above will drop about 0.5 volts at 10 amps.
A coating of E6000 will insulate and protect the terminals from vibration. |
Thank you Joe. I'm going to be mounting the diodes on the subpanel which is aluminium and most of the components will be less than 5 amps. Based on what you just said, I think that a heat sink likely isn't necessary other than using the panel.
Randy
Posted: Sun Feb 23, 2020 6:24 am Post subject: Power Duece Schottky diodes |
rv8iator
Posted: Mon Feb 24, 2020 5:19 am Post subject: Power Duece Schottky diodes |
Beware of counterfeit semiconductors on EBay...
https://www.electro-tech-online.com/blog-entries/watch-out-for-counterfeit-transistors.78
I purchased some 2N3055 power bipolors. cut them open and they were counterfeit. Tiny die compared to the original STMicro parts. This may be the case when you see bargain low ball prices for other semiconductors. The modus operandi seems to be to re label parts that look identical to the original but are of lower power higher noise spec.
Chris
RV-8 twice
On Sat, Feb 22, 2020 at 10:17 AM Charlie England <ceengland7(at)gmail.com (ceengland7(at)gmail.com)> wrote:
Randy
_________________ C. Stone (RV8iator) |
Randy C-GRPY
Posted: Mon Feb 24, 2020 7:15 pm Post subject: Re: Power Duece Schottky diodes |
rv8iator wrote: | Beware of counterfeit semiconductors on EBay...
Chris
RV-8 twice
Randy
Thanks for the heads up. I think I will stick to Digikey, Mouser, or Newark. I’m thinking they don’t buy from unknown suppliers.
