bob.verwey(at)gmail.com Guest
Posted: Wed Mar 04, 2020 6:53 am Post subject: OV protection circuit design |
Excellent and succinct, thanks Joe!
Best...Bob Verwey
082 331 2727
[img]https://docs.google.com/uc?export=download&id=0B5d7rgAInTuTUUZsUjY4QmJsdVU&revid=0B5d7rgAInTuTdDJDaXRFZVh3b3lMa3FWL0s3MFdzc01YRlNvPQ[/img]
On Wed, 4 Mar 2020 at 16:42, user9253 <fransew(at)gmail.com (fransew(at)gmail.com)> wrote:
| Quote: | --> AeroElectric-List message posted by: "user9253" <fransew(at)gmail.com (fransew(at)gmail.com)>
I would not use 12 AWG because it is too big and hard to work with. It
might even damage components that are not designed for large wire.
I would rather use a fuselink, like Charlie said, than use #12 wire.
Electrical circuits require two types of protection, short circuit and
overload. A short circuit occurs when two conductors touch each other.Â
The current will be very high. An overload occurs when the load draws
more current than it was designed for. Fuses protect against short circuits.Â
Circuit breakers protect against overloads. Although sometimes only one
type (fuse or breaker) is used to protect a circuit against both types of faults.
 In the case of the alternator over-voltage module shorting to ground, we
are dealing with a short circuit. We want the circuit breaker to trip, but not
the fuse to blow. I would have suggested using a 35 or 40 amp fuse if it
would fit into the fuse block, but it won't. Normally we choose the fuse
sized based on the wire size. But in this case, we are not dealing with a
continuous load. We are dealing with a short circuit that only lasts a few
seconds at most. It takes time for a wire to heat up. The circuit breaker
will trip before that happens. Using smaller wire will add resistance to the
circuit, thus helping to limit the maximum current and helping to prevent the
fuse from blowing before the circuit breaker trips. Using 12 AWG wire in this
situation is actually counter productive because the current could be high
enough to both blow the fuse and trip the breaker.
 Search the internet for fusing current of wire. It will take over 40 amps
continuous to melt 22 AWG wire. In the time that it takes a 5 amp breaker
to trip, #22 will not even get warm. If 22 AWG wire, between the fuse and
breaker, shorts to ground, the fuse will blow and the wire will not be damaged.
Joe Gores
http://forums.matronics.com/viewtopic.php?p=495144#495144
Posted: Sun Mar 08, 2020 1:26 pm Post subject: OV protection circuit design |
This particular thread germinated from a query about the selection
of materials for EXTENDING a fuse-block bus up to a 5A breaker
on the panel. Normal operating currents flowing in this feeder
are not significant to the selection of components. The design
goal is to provide hard-fault protection for a BUS EXTENSION
such that an expected event that opens the 5A breaker will
not open the protection at the bus.
The N811HB accident had root cause in a failure to conduct the
necessary evaluation of components. Here’s a video demonstrating
a critical comparison of fuses vs. breakers:
https://tinyurl.com/r6bakrp
Another video demonstrating a consequence of failure to exploit
that comparison:
https://tinyurl.com/s4bfb3m
>the fuse to blow.
>I would have suggested using a 35 or 40 amp fuse if it would fit into the fuse block, but it won't.
But a 30A will fit and has been tested for the application described in the
drawing. By the way, you CAN buy ATC/ATO 40 fuses. I just discovered
this a few days ago. I think I'll upsize the recommended feeder extension
fuse to 40A.
https://tinyurl.com/tqg7bqb
>Normally we choose the fuse sized based on the wire size.
This is an over-simplification. The vulnerable feature of any wire
is generally not the wire itself but its insulation. Looking through
the wire catalogs we find a constellation of products with a range
of TEMPERATURE ratings combined with other qualities like abrasion
resistance, flexibility, chemical resistance, fire ratings, etc. etc.
The continuous operation design load for a wire is based
on temperature rise in wire due to loading, hotest ambient
expected and the rating for that wire's INSULATION. Of
course, there is the secondary but rare consideration
for voltage drop.
Selecting protection for any feeder is an engineering study
to meet design goals. Yeah, AC43-13 and similar documents offer
conservative guidelines that address the majority of your design
decisions . . . but as mentioned earlier, these are not
engineering texts. Information proffered does NOT go to full
understanding.
>But in this case, we are not dealing with a continuous load. We are
>dealing with a short circuit that only lasts a few seconds at most.
Actually, tens of milliseconds
>It takes time for a wire to heat up. The circuit breaker will trip
>before that happens. Using smaller wire will add resistance to the circuit,
>in this situation is actually counter productive because the current
>could be high enough to both blow the fuse and trip the breaker.
Not so . . . which I will explain
Most of the circuit protection found in vehicular DC power systems
are of the ‘heating’ variety. A calibrated, melting element within
an enclosure makes up a fuse . . . a thing that warms up in response
to a thru-current until the element melts, collapses and the
circuit is broken. Similarly, a mechanical switch spring loaded
to open up is held in a latched-closed condition by a mechanism
that opens the latch based on temperature rise in a heating element.
While all such heat-operated devices have a current ‘rating’,
that number is but a small piece of the story. Each class of device
will have a dynamic (i.e. current/time dependent) quality significant
in selecting the device to do a task. I chose 14AWG in the bus-to
-breaker segment so as to minimize trip time for the breaker. In
typical crowbar ovm systems, the response time from trigger to trip
is on the order of 10 milliseconds. But sizing this segment
was as much 'seat of the gray matter' as it was a calculated
selection.
As mentioned above, our critical design consideration is
evaluate the DIFFERENCE between the upstream and downstream
protection devices.
For example: You may have some appliance that is fitted with a fuse.
Perhaps internally or part of the line-cord plug. Then there are
breakers in your breaker-box. The transformer on the pole behind
your house is fitted with a fuse in the primary supply feeder. High
voltage feeders to your transformer and that of your neighbors
will also be fitted with fuses. As we move toward the source
in the power distribution systems, there will be protective devices.
Each one carries more power as you move up the distribution chain.
The fuse in your household electro-whizzy is expected to operated
without opening the 15 or 20A breaker in your breaker-box.
Similarly, each feeder breaker is designed to open without
tripping the main breaker. The fuse on the pole outside will
open without tripping anything upstream thus only you and
your immediate neighbors are in the dark. So goes the design
task all the way up to the turbine-driven alternators that
effect the large scale, mechanical-to-electrical power conversion.
For this thread, a practical perspective says that if all wires along
the subject BUS EXTENSION were 20AWG, the risk for failure to perform
would be essentially zero.
>It might even damage components that are not designed for large wire.
M22759, 12AWG wire is made up of 37 strands of 28AWG wire
. . . quite flexible and user friendly . . . not necessary
to avoid if you really need its capabilities.
Fusible links were added to our toolbox in the early days
of fuse-blocks. Fusible links had a ring terminal on one
end . . . this could bolt down on the fuse-block's feeder
terminal. A FAT ATC/ATO fuse (30+ amps) can be used
to tap the bus with a fast-on terminal. For our purposes
the two techniques are technically interchangeable; The
fuse/fast-on being simpler to fabricate. The actual sizes
for the wires is nearly insignificant . . . it's
all about the characteristics of TWO protective devices
IN SERIES.
I picked up a handfull of ATC30 fuses and a few ATC40
fuses yesterday. I need to dig around in the test
equipment to find the 300A hall-sensor I used for
crowbar ovp performance studies some years ago.
I'll revisit the current vs trip characteristics of
a 5A mini breaker with ATC30 and ATC40 fuses. It's
a quick experiment to run and document if you've
got the tools . . . now . . . if you were a 300A
full scale HE sensor, where would you be hinding?
art(at)zemon.name Guest
Posted: Sun Mar 08, 2020 5:59 pm Post subject: OV protection circuit design |
Those are very instructive videos. Thank you for sharing them. I will be passing them on to some friends.
  -- Art Z.
On Sun, Mar 8, 2020 at 4:40 PM Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
| Quote: | Â This particular thread germinated from a query about the selection
 that comparison:
https://CheerfulCurmudgeon.com/Sooner meet a bereaved she-bear than a fool with his nonsense.  Proverbs 17:12
Posted: Mon Mar 09, 2020 4:32 am Post subject: OV protection circuit design |
At 08:55 PM 3/8/2020, you wrote:
| Quote: | Bob,
Those are very instructive videos. Thank you for sharing them. I will be passing them on to some friends. |
Very good sir. That was a sad case to work.
A very nice LA-IVP went down and people got
hurt . . . some for life. It's a modern
allegory to the "for want of a nail" proverb.
But if there is potential for a valuable lesson
learned, this is one of them.
jluckey(at)pacbell.net Guest
Posted: Mon Mar 09, 2020 8:12 am Post subject: OV protection circuit design |
At what fuse rating does the breaker pop before the fuse? 30A, 40A, 50A... ???
Just curious...
-Jeff
On Monday, March 9, 2020, 05:40:25 AM PDT, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com> wrote:
| Quote: | Bob,
Posted: Mon Mar 09, 2020 9:30 am Post subject: OV protection circuit design |
Jeff,
Watch the two videos and you will understand that there is no answer to your question.
  -- Art Z.
On Mon, Mar 9, 2020 at 11:27 AM Jeff Luckey <jluckey(at)pacbell.net (jluckey(at)pacbell.net)> wrote:
Just curious..
-Jeff
On Monday, March 9, 2020, 05:40:25 AM PDT, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
| Quote: | Bob,
Posted: Mon Mar 09, 2020 11:42 am Post subject: OV protection circuit design |
At 11:10 AM 3/9/2020, you wrote:
| Quote: | Bob,
Just curious... |
No hard and fast rule . . . both breakers and
fuses can be had in a range of trip profiles.
I've tested the ATO/ATC30 plastic fuses
against the miniature breakers popular in
aircraft with a goal of at least 3x head-room
with a 100A crowbar event.
I couldn't find my favorite 300A HE sensor
but did find a 400A that will let me repeat
the bench tests but I'll take a look at the
ATO40 fuse also.
Posted: Mon Mar 09, 2020 12:19 pm Post subject: OV protection circuit design |
| Quote: | Bob,
Just curious... |
ATO40 fuse also.
Posted: Tue Mar 10, 2020 3:43 am Post subject: OV protection circuit design |
| Quote: | Bob,
Just curious... |
ATO40 fuse also.
