Insulating washers [was: Radio noise when transmitting]
jdubner
PostPosted: Tue Mar 17, 2020 12:39 pm    Post subject: Insulating washers [was: Radio noise when transmitting] Reply with quote
Robert L. Nuckolls, III wrote on 3/17/2020 10:07:
?? ... > ground loop caused by mounting the microphone
?? jack to airframe without and insulating washer.
https://tinyurl.com/t4kveee
Yikes, those are some expensive pieces of phenolic! Not in terms of other
airplane parts measured in AMU ($1000 bills) of course but certainly in terms of
dollars per ounce.
In the past a friend has turned some on his lathe from some phenolic stock I had
on hand. Like nearly all machining operations, the setup is time consuming but
"production" is quite speedy.
I have also used 0.062-inch printed circuit board material (after cleaning off
the traces) to fabricate a rectangular strip that would mount jacks through
oversize clearance holes. Image attached.
The latter technique works for 1/8-inch jacks where no insulated mount is
available AFAIK.
Joe
RV-8A
Independence, OR
 Filesize:  1.73 MB
 Viewed:  3415 Time(s)
Independence, OR
