Aircraft Tug
mike(at)vision499.com
PostPosted: Sat Apr 11, 2020 11:37 am    Post subject: Aircraft Tug Reply with quote
Hello all
I’m looking at building a 12v battery operated aircraft tug, not a ride on just a walk with. My max aircraft weight will be about 1800 lbs.
I am looking for advise on what size motor I will need. There are a few 12v motors for sale on ebay but they are not rated in hp so am not sure of what specs I’m looking at.
One thought was to use a car starter motor but that is not rated for continuous service but the farthest I will go with the tug is 100 yds and I’m not sure if it will cope with that distance. A friend has also suggested converting an alternator into a motor, not sure what that entails. Ebay has scooter motors with a speed controller that seems ideal but not sure if that will be powerful enough but it will be geared right down.
I look forward to hearing your thoughts and ideas
joemotis(at)gmail.com
PostPosted: Sat Apr 11, 2020 12:22 pm    Post subject: Aircraft Tug Reply with quote
Hi Mike,Ā  I built a tug out of one of the mobility scooters I found on CL for $100.00 bucks. Everything is already their just needs some creativity to make it work on your aircraft. Will look for pics but do not know if I have any. Joe Motis
On Sat, Apr 11, 2020 at 12:42 PM <mike(at)vision499.com (mike(at)vision499.com)> wrote:
Ā
Hello all
Ā
I’m looking at building a 12v battery Ā operated aircraft tug, not a ride on just a walk with. My max aircraft weight will be about 1800 lbs.
Ā
Ā
One thought was to use a car starter motor but that is not rated for continuous service but the farthest I will go with the tug is 100 yds and I’m not sure if it will cope with that distance. A friend has also suggested converting an alternator into a motor, not sure what that entails.Ā  Ebay has scooter motors with a speed controller that seems ideal but not sure if that will be powerful enough but it will be geared right down.
Ā
Ā
Ā
Ā
Ā
Virus-free. www.avast.com [url=#m_-8539690423255490022_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2] [/url]
skywagon185(at)gmail.com
PostPosted: Sat Apr 11, 2020 2:53 pm    Post subject: Aircraft Tug Reply with quote
Mike,
...one tip is: you have to gear way down the motor which will increase its final driving torque greatly. So, don't be afraid of smaller size motors. For heavens sake, don't use an auto starter type motor; way too powerful.Ā  First engagement would rip your whole tug apart.
On Sat, Apr 11, 2020 at 12:32 PM <mike(at)vision499.com (mike(at)vision499.com)> wrote:
Ā
Hello all
Ā
Ā
Ā
Ā
Ā
Ā
Ā
Ā
Virus-free. www.avast.com [url=#m_-4086849547896881672_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2] [/url]
ceengland7(at)gmail.com
PostPosted: Sat Apr 11, 2020 4:21 pm    Post subject: Aircraft Tug Reply with quote
Actually, a starter motor can work if properly geared down; I've got one in my hangar that a friend used to use to drag his C-170 around. It had a full size wet cell car battery for power (weight probably helped with traction) and a chain reduction to the wheels. Sprocket diameters were probably ~1.5" & ~6", but it's been a while since I really looked at it. IIRC, it had a simple forward/reverse switch & a pushbutton to activate it. A 100 yd continuous operation might be a bit much for a starter motor, but it might notĀ  be working as hard pulling the a/c on level ground as it is when starting the engine.
There's a recently created thread on VAF detailing a shop-built tug using a pair of scooter motors & wheels (purchased as a set on ebay). Uses an off the shelf SLA battery.
http://www.vansairforce.com/community/showthread.php?t=180676&highlight=tug
FWIW,
On 4/11/2020 5:49 PM, skywagon185guy . wrote:
Mike,
Ā
Hello all
Ā
Ā
Ā
Ā
Ā
Ā
Ā
Ā
Tim Olson
PostPosted: Sat Apr 11, 2020 6:50 pm    Post subject: Aircraft Tug Reply with quote
I actually have a MiniMax that I've got for sale right now.
It's set up for an RV-10/RV-14 but I'm guessing it could
be customized for others.
On 4/11/20 6:34 PM, Gerry van Dyk wrote:
[quote] If I may suggest, have a look at Minimax Aircraft Tugs for ideas.
https://www.minimaxtugs.com/Ā  They've got a range of light tugs built
around cordless drills.
For the bottom end a commercial worm drive gear box would probably be a
good bet.Ā  Try searching Ebay forĀ  133ULR20A Browning Raider Worm Gear
Reducer.Ā  I'd post a link but it's about 7 miles long.Ā  That unit is
seriously overkill for the purpose, but perhaps there's lighter weight
similar units.
this might be another option, but you'd need a separate battery and
electrical system.
https://www.ebay.com/itm/DC12V-12rpm-Speed-Reduction-Worm-Gear-Motor-with-Cable-70kg-cm-High-Torque/163673951726?hash=item261bba4dee:g:QhkAAOSwOFFeAx2z
Just food for thought
Gerry
hilltopkid
PostPosted: Sat Apr 11, 2020 7:50 pm    Post subject: Aircraft Tug Reply with quote
Tim, what do you want for the MiniMax? And where do you live for shipping cost calculation to Dinwiddie County Airport (KPTB), Virginia.
Dee Whittington
804-677-4849 iPhone
> If I may suggest, have a look at Minimax Aircraft Tugs for ideas. https://www.minimaxtugs.com/ They've got a range of light tugs built around cordless drills.
> For the bottom end a commercial worm drive gear box would probably be a good bet. Try searching Ebay for 133ULR20A Browning Raider Worm Gear Reducer. I'd post a link but it's about 7 miles long. That unit is seriously overkill for the purpose, but perhaps there's lighter weight similar units.
> this might be another option, but you'd need a separate battery and electrical system.
> Gerry
DeWitt (Dee) Whittington
Richmond, VA
john(at)tipton.me.uk
PostPosted: Sun Apr 12, 2020 12:14 am    Post subject: Aircraft Tug Reply with quote
There’s a couple of ā€˜walk along tugs’ in our hangar which use rechargeable drills (the DeWalt brand seems ā€˜de rigueur’), which just goes to show what is required using the right gearing.
----x--O--x----
On 12 Apr 2020, at 12:08 am, skywagon185guy . <skywagon185(at)gmail.com> wrote:
Mike,
...one tip is: you have to gear way down the motor which will increase its final driving torque greatly. So, don't be afraid of smaller size motors. For heavens sake, don't use an auto starter type motor; way too powerful. First engagement would rip your whole tug apart.
Hello all
PostPosted: Sun Apr 12, 2020 12:01 pm    Post subject: Aircraft Tug Reply with quote
Her you go Mike[img]cid:ii_k8xguc380[/img] I could not find another picture but I mounted a trailer hitch ball on to of the frame right behind the batteries and fabricated a tow bar with a hitch connector on it. Works excellent.
Ā
Hello all
Ā
Ā
Ā
Ā
Ā
Ā
Ā
Ā
Virus-free. www.avast.com [url=#m_3616394520000165289_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2] [/url]
 Filesize:  16.99 KB
 Viewed:  13390 Time(s)
PostPosted: Tue Apr 14, 2020 10:57 am    Post subject: Aircraft Tug Reply with quote
Thank you very much, you have convinced me, I was looking forward to building a tug from scratch but it will be a lot cheaper and easier to adapt a mobility scooter
I am looking for a used one to convert, will let you know how it turns out
Thanks again
From: owner-aeroelectric-list-server(at)matronics.com <owner-aeroelectric-list-server(at)matronics.com> On Behalf Of Joe Motis
Sent: April 14, 2020 8:37 AM
Subject: Re: Aircraft Tug
With The lead acid batteries right where the trailer hitch ball was I think never had a traction problem. And that pulling my friends big twin 2 I would just pulling my Cherokee 180 with it and that thing would drag it all over the air Park the benefit to use in one of those old Mobility devices in my opinion was that everything was there it was geared down it was meant to drag around a 300-pound person it had proportional forward and reverse controls and a charger built in
On Mon, Apr 13, 2020, 9:36 PM <mike(at)vision499.com (mike(at)vision499.com)> wrote:
Just a quick question, why did you not keep the seat, would it not improve traction if you had the extra weight?
From: owner-aeroelectric-list-server(at)matronics.com (owner-aeroelectric-list-server(at)matronics.com) <owner-aeroelectric-list-server(at)matronics.com (owner-aeroelectric-list-server(at)matronics.com)> On Behalf Of Joe Motis
Sent: April 12, 2020 12:56 PM
Her you go Mike
[img]cid:image001.jpg(at)01D611DA.185F74A0[/img]I could not find another picture but I mounted a trailer hitch ball on to of the frame right behind the batteries and fabricated a tow bar with a hitch connector on it. Works excellent.
Hello all
PostPosted: Tue Apr 14, 2020 12:06 pm    Post subject: Aircraft Tug Reply with quote
Certainly my pleasure good luck!
On Tue, Apr 14, 2020, 12:04 PM <mike(at)vision499.com (mike(at)vision499.com)> wrote:
Ā
Ā
Thanks again
Ā
Ā
Subject: Re: AeroElectric-List: Aircraft Tug
Ā
Ā
Ā
Ā
Ā
Ā
Her you go Mike
Ā
Ā
Hello all
Ā
Ā
Ā
Ā
Ā
Ā
Ā
Ā
Ā
Ā
kesleyelectric(at)iowatel
PostPosted: Sat Apr 18, 2020 7:35 am    Post subject: Aircraft Tug Reply with quote
Attached is a photo of an aircraft tug a friend built from a walk behind snow blower with a failed engine. The transmission allows speed control going forward plus reverse.
Works very well on his RV-6.
Tom Barter
From: owner-aeroelectric-list-server(at)matronics.com <owner-aeroelectric-list-server(at)matronics.com> On Behalf Of mike(at)vision499.com
Sent: Saturday, April 11, 2020 2:32 PM
Subject: Aircraft Tug
Hello all
 Filesize:  123.7 KB
 Viewed:  13337 Time(s)
billbear
PostPosted: Sat Apr 18, 2020 11:14 am    Post subject: Aircraft Tug Reply with quote
Tom,
What DC motor did he use to replace the gasoline motor?
On Apr 18, 2020, at 07:33, Tom Barter <kesleyelectric(at)iowatelecom.net (kesleyelectric(at)iowatelecom.net)> wrote:
Tom Barter
From: owner-aeroelectric-list-server(at)matronics.com (owner-aeroelectric-list-server(at)matronics.com) <owner-aeroelectric-list-server(at)matronics.com (owner-aeroelectric-list-server(at)matronics.com)> On Behalf Of mike(at)vision499.com (mike(at)vision499.com)Sent: Saturday, April 11, 2020 2:32 PMTo: aeroelectric-list(at)matronics.com (aeroelectric-list(at)matronics.com)Subject: Aircraft Tug
Hello all
[img]cid:94AD957F-9199-4BD3-B88D-2B222B7C2D38[/img]
 Filesize:  104.19 KB
 Viewed:  13335 Time(s)
ktup122(at)aol.com
PostPosted: Sun Apr 19, 2020 5:11 am    Post subject: Aircraft Tug Reply with quote
ktup122(at)aol.com
billbear
PostPosted: Sun Apr 19, 2020 8:11 pm    Post subject: Aircraft Tug Reply with quote
Thanks, Tom. Gotta add this one to my ā€œto doā€ list.
Bill Bear
[quote] On Apr 19, 2020, at 05:09, ktup122(at)aol.com wrote:
ktup122(at)aol.com
