mritter509(at)msn.com Guest
Posted: Fri Jul 21, 2006 5:32 pm Post subject: Inspection completed! |
DAR (Dick Dumbler) inspection went smooth as silk today even with an FAA guy following him around. No squawks. Hope to start flying off the 40 hours tomorrow.
Mark
40043
Deems Davis
Posted: Mon Jul 24, 2006 6:03 am Post subject: Inspection completed! |
C O N G R A T U L A T I O N S ! ! ! ! ! !
Best of luck with your fly-off. Please keep us informed of how it goes,
as this is an 'undocumented' part of the plan.
Deems Davis # 406
Fuse
http://deemsrv10.com/
Posted: Mon Jul 24, 2006 7:50 am Post subject: Inspection completed! |
Thanks. First couple of hours went great. Oil temp (217) and a couple of CHT's (430) a little higher than I would like but I understand they should come down with time. Plane is flying hands off.
Mark (N410MR)
sam.marlow
Posted: Mon Jul 24, 2006 8:49 am Post subject: Inspection completed! |
Just wondered if you have the wheel faring installed?
Mark Ritter wrote:
[quote]--> RV10-List message posted by: "Mark Ritter"
Mark (N410MR)
Posted: Mon Jul 24, 2006 10:54 am Post subject: Inspection completed! |
Sam,
Have not installed gear leg fairings or wheel pants. Per Vans "when engine break-in is a concern, you should perform flight testing without the wheel fairings and gear leg fairings. This will add around 15% to the airframe drag and thus cause higher engine temperatures at any given forward speed. Higher cylinder head temperatures, within limits, are necessary for seating piston rings (break-in)".
Mark (N410MR Flying)
| Quote: | Just wondered if you have the wheel faring installed?
Mark Ritter wrote:
| Quote: | --> RV10-List message posted by: "Mark Ritter"
Mark (N410MR)
sam.marlow
Posted: Mon Jul 24, 2006 2:08 pm Post subject: Inspection completed! |
Thanks!
Do not archive.
Sam,
Mark (N410MR)
dav1111(at)cox.net Guest
Posted: Mon Jul 24, 2006 2:42 pm Post subject: Inspection completed! |
I received my DAR signoff yesterday. Spent today getting most of the inspection panels put back on and hope to make first flight on Wednesday.
Russ Daves
N710RV - RV-10
N65RV - RV-6A Sold
Lubbock, Texas
Deems Davis
Posted: Mon Jul 24, 2006 3:47 pm Post subject: Inspection completed! |
C O N G R A T U L A T I O N S !!!!!!!!!!!!!!
This is getting to be an almost daily occurance, perhaps before OSH is
over, we will have 50 -10's flying!?. Must feel good (will feel even
better on Wed I suspect).
Keep us informed, and motivated
Deems Davis # 406
Fuse
Russell Daves wrote:
| Quote: | I received my DAR signoff yesterday. Spent today getting most of the
Russ Daves
N710RV - RV-10
N65RV - RV-6A Sold
Lubbock, Texas
Tim(at)MyRV10.com Guest
Posted: Sat Jul 29, 2006 3:52 pm Post subject: Inspection completed! |
Mark,
From what I've heard, 435 is near the max you'll see in a well
set up IO-540, in a full power climb. So you're probably fine
with your new engine. I've seen 217 once on a hot day long
climb, but usually my Oil temp is 185-195. Don't worry as
much until you put 5 hours on it and it's starting to break
in a little. Those first few will be hot from what I hear.
Mark Ritter wrote:
Mark (N410MR)
Posted: Sat Jul 29, 2006 5:19 pm Post subject: Inspection completed! |
Tim,
Appreciate your feed back. Flew today and the temps are starting to come down (100 degree Texas weather not helping). I'm feeling better. What a fun plane to fly! With the MT prop there is no need to use pitch trim on landing - plenty of elevator. Also no tunnel heat with Vans fix installed. Still working my way through all the capablities of the TruTrak Sorcerer auto pilot - so far it's amazing.
Thanks for all you do for the group.
Mark
Subject: Re: Inspection completed!
Date: Sat, 29 Jul 2006 18:51:59 -0500
[quote]--> RV10-List message posted by: Tim Olson <Tim(at)MyRV10.com>
Mark,
Tim Olson - RV-10 N104CD -
