Garmin GAD 27 Brown-Out Booster
johnbright
PostPosted: Sun May 31, 2020 9:33 am    Post subject: Garmin GAD 27 Brown-Out Booster Reply with quote
If you are planning on Garmin.
For those who may not be aware... Garmin's GAD 27 (Flaps/Lights/Trim Controller) incorporates a Brown-Out Booster. They call it Voltage Stabilizer and it will deliver up to 3.5A at 12V if you feed it 5V or above.
"Voltage Stabilizer - Essential avionics receive stable power during engine start without the need for a back-up battery when integrating the GAD 27 adapter..."
John Bright, RV-6A
Single battery, wound-field alternator on main bus, MZ-30 PM generator on engine/essential bus.
N1921R links
