				 Posted: Mon Jun 15, 2020 8:45 am    Post subject: With Flooded cells, at what   discharge does damage start? |
				At 10:57 AM 6/15/2020, you wrote:
   	  | Quote: | 	 		  --> AeroElectric-List message posted by: "bcone1381" <bcone1964(at)gmail.com>
  Vic Syracuse has an article in this months Sport Aviation (June 2020) that deals with Batteries and Alternators.
  he says not to mistreat a battery by constantly leaving it on a non approved battery tender/charger between flight.
  Help me understand what an "approved charger" or what to avoid.  Specific products will be good.  May I assume maybe there are different chargers for different battery types?
   What Vic is referring to are 'battery maintainers' . . . which may
   also be a charger but with automatic step-down to a maintenace mode
   when the battery is topped off.
   If the advertising literature for the charger includes the
   word 'maintainer' then it's good to go.  Brands like Battery
   Minder, Battery Tender and Schumacher are several choices
   to consider.
   A battery maintainer holds the voltage on a stored battery
   at JUST ABOVE it's normal resting point. This means that
   very small, self discharge currents flowing INSIDE the
   battery will be supported from OUTSIDE instead of from
   the battery's own resources. It cannot even charge, much
   less overcharge a battery.
				 Posted: Mon Jun 15, 2020 8:46 am    Post subject: With Flooded cells, at what   discharge does damage start? |
				 	  | Quote: | 	 		  | May I assume maybe there are different chargers for different battery types? |
    Not really . . . there are some so-called, 'smart
    chargers' with front panel controls suggesting
    different charging modes for AGM, flooded and GEL
    batteries . . . but I've never been able to detect
    any useful differences in their charging protocols.
    If the battery is suited to run in a vehicle, then
    any charger suited to charge vehicle batteries
    is okay. CHARGING is not the critical feature . . .
    its what the charge does AFTER charging is complete
    so that overcharging damage does not occur and
    self-discharge currents are mitigated.
