RequesT SDS EFI info/advice
djohnston557(at)icloud.co
PostPosted: Wed Jul 08, 2020 12:15 pm    Post subject: RequesT SDS EFI info/advice Reply with quote
Hi all,
I am have a IO 540 with the SDS EFI , and electronic ignition. I would like to see the panel layouts of those of you who have installed this system on their engines, and any comments on the operation, including abnormal checklists recommendations. I would also be interested to know your thoughts on how to design the circuit layout to provide the safest, and most fail safe design.
Sent from my iPad
kearney
PostPosted: Wed Jul 08, 2020 1:52 pm    Post subject: Re: RequesT SDS EFI info/advice Reply with quote
Hi
I have the SDS EFI/EI system on my -10 and have been flying for a year (125+ hours).
What are your plans regarding batteries & alternators. My set up is a single Odyssey battery and dual alternators. If you are planning to go that route, I can send you a copy of my wiring backbone as well as my fuel pump wiring.
If you go to Ross's youtube channel you can see a number of RV10 videos - all shot using my -10. The latest video (#84) gives a good view of my panel as well as how I have handled some failure modes.
The SDS system has been flawless. I have taken my -10 to FL200 and it was still climbing when it go there.
Send me a PM if I can be of any help.
Cheers
Les
C-GCWZ - sold - now vacationing in Tulsa
C-GROK - flying in the Rockies
sportav8r(at)gmail.com
PostPosted: Sat Jul 11, 2020 3:21 am    Post subject: RequesT SDS EFI info/advice Reply with quote
Dual SDS CPi2 system in RV-10 build.  Single battery and dual alternators here, with backup SDS battery.  Not yet flying.
Les, can you post or send me privately the timing table you have settled on for MOGAS/AVGAS with your setup?
Thanks!
On Wed, Jul 8, 2020 at 6:00 PM kearney <kearney(at)shaw.ca (kearney(at)shaw.ca)> wrote:
--> RV10-List message posted by: "kearney" <kearney(at)shaw.ca (kearney(at)shaw.ca)>
Hi
Cheers
Les
http://forums.matronics.com/viewtopic.php?p=497211#497211
FORUMS -
WIKI -
b Site -
          -Matt Dralle, List Admin.
