CJ6 aileron bearings
Harv
PostPosted: Sat Jul 11, 2020 12:08 am    Post subject: CJ6 aileron bearings Reply with quote
Good morning all
Would anyone know the exact bearing size/spec needed for the cj6 aileron mount bracket?
Looks to be a common size one used all over the aircraft for pull rods, rudder hinges etc and I’d like to get one before we pull the old one out if possible.
Cheers, happy flying
Harv
 Filesize:  1.28 MB
 Viewed:  13049 Time(s)
Harv
PostPosted: Sun Jul 12, 2020 5:30 am    Post subject: Re: CJ6 aileron bearings - Part Number Update Reply with quote
Managed to remove said bearing with home made puller.
The part required is 126TV should anyone else need to do this, it’s a self aligning double row 6mm ID x 19mm OD x 6mm bearing
draftsjust417(at)gmail.co
PostPosted: Sun Jul 12, 2020 6:46 am    Post subject: CJ6 aileron bearings Reply with quote
Good news, thanks for the info...Justin
On Sun, Jul 12, 2020, 6:50 AM Harv <martin.harvey(at)kbr.com (martin.harvey(at)kbr.com)> wrote:
--> Yak-List message posted by: "Harv" <martin.harvey(at)kbr.com (martin.harvey(at)kbr.com)>
http://forums.matronics.com/viewtopic.php?p=497256#497256
List" rel="noreferrer noreferrer" target="_blank">http://www.matronics.com/Navigator?Yak-List
AlaskaChang801
PostPosted: Tue Aug 25, 2020 9:12 am    Post subject: Re: CJ6 aileron bearings Reply with quote
I just replaced my elevator bearings and from what I know they are the same as the rudder and ailerons. I don't know the spec size, but I can tell you this! They are the same bearings in the canopy rollers and therefore you can buy a set of them fairly cheap from Todd Bohlman, you can find him on Ebay as that's where he sells them or search for him on the Red Star Facebook page.
 Filesize:  1.35 MB
 Viewed:  12760 Time(s)
dsavarese0812(at)bellsout
PostPosted: Tue Aug 25, 2020 12:10 pm    Post subject: CJ6 aileron bearings Reply with quote
The bearings are 6x19x6 mm self aligning bearings. They are available all over the internet. Be sure to include “self aligning bearing” in your search.
Dennis
On Aug 25, 2020, at 1:18 PM, AlaskaChang801 <themilnes95(at)gmail.com> wrote:
http://forums.matronics.com/viewtopic.php?p=497975#497975
http://forums.matronics.com//files/cj_bearings_942.jpg
wamflight(at)gmail.com
PostPosted: Tue Aug 25, 2020 12:34 pm    Post subject: CJ6 aileron bearings Reply with quote
typed: 6x19x6 mm self aligning bearings- into google. Anywhere from $4 to $26 for the same thing.
On Aug 25, 2020, at 3:07 PM, Anthony Savarese <dsavarese0812(at)bellsouth.net (dsavarese0812(at)bellsouth.net)> wrote:
--> Yak-List message posted by: Anthony Savarese <dsavarese0812(at)bellsouth.net (dsavarese0812(at)bellsouth.net)>The bearings are 6x19x6 mm self aligning bearings. They are available all over the internet. Be sure to include “self aligning bearing” in your search. Dennis Sent from my iPhone
On Aug 25, 2020, at 1:18 PM, AlaskaChang801 <themilnes95(at)gmail.com (themilnes95(at)gmail.com)> wrote:--> Yak-List message posted by: "AlaskaChang801" <themilnes95(at)gmail.com (themilnes95(at)gmail.com)>I just replaced my elevator bearings and from what I know they are the same as the rudder and ailerons. I don't know the spec size, but I can tell you this! They are the same bearings in the canopy rollers and therefore you can buy a set of them fairly cheap from Todd Bohlman, you can find him on Ebay as that's where he sells them or search for him on the Red Star Facebook page.Read this topic online here:http://forums.matronics.com/viewtopic.php?p=497975#497975Attachments: http://forums.matronics.com//files/cj_bearings_942.jpg
http://www.matronics.com/Navigator?Yak-Listhttp://wiki.matronics.com
pennington.construction.i
PostPosted: Tue Aug 25, 2020 12:54 pm    Post subject: CJ6 aileron bearings Reply with quote
Dennis makes a real good point.  He gave me this information some time ago.  I wasn’t sure why self aligning was so important.
Found out you are pretty much guaranteed a smooth non binding rotation.  Probably important.  That is what the literature and the tech support person at 123 bearing shared with me.   He also suggested as many balls as possible.   (There is a joke in there for sure)
Those bearings are all over the plane.
The rigid bearing may be a mistake.
Mark
On Tue, Aug 25, 2020 at 4:15 PM Anthony Savarese <dsavarese0812(at)bellsouth.net (dsavarese0812(at)bellsouth.net)> wrote:
Dennis
http://www.matronics.com/Navig========================http://forums.matroni=              - NEW MATRONICS LIST WI=   --> http://www.matronics=====================
PostPosted: Tue Aug 25, 2020 1:09 pm    Post subject: CJ6 aileron bearings Reply with quote
No rigid bearing unless the original is rigid. Dennis
On Aug 25, 2020, at 4:56 PM, Mark Pennington <pennington.construction.inc.1(at)gmail.com> wrote:
Dennis makes a real good point. He gave me this information some time ago. I wasn’t sure why self aligning was so important. Â
Those bearings are all over the plane. Â
The rigid bearing may be a mistake. Â
MarkÂ
Dennis
http://www.matronics.com/Navig========================http://forums.matroni=Â Â Â Â Â Â Â - NEW MATRONICS LIST WI=Â Â --> http://www.matronics=====================
dougsappllc(at)gmail.com
PostPosted: Tue Aug 25, 2020 2:55 pm    Post subject: CJ6 aileron bearings Reply with quote
There are basically two sizes of self aligning bearings used in the CJ.  I normally have good stock on both.
Doug
On Tue, Aug 25, 2020 at 1:39 PM William Geipel <wamflight(at)gmail.com (wamflight(at)gmail.com)> wrote:
Dennis
http://wiki.matronics.comhttp://www.matronics.com/contribution
PostPosted: Wed Aug 26, 2020 7:05 am    Post subject: CJ6 aileron bearings Reply with quote
Absolutely! Make it easy on yourself if you're looking for bearings, or anything else for CJ's for that matter. Just call Doug. He should clearly your go-to guy.
Dennis
On Tuesday, August 25, 2020, 6:57:52 PM EDT, doug sapp <dougsappllc(at)gmail.com> wrote:
Doug
Dennis
kiwi679
PostPosted: Wed Aug 26, 2020 9:40 pm    Post subject: CJ6 aileron bearings Reply with quote
Dennis. Are these the same size bearings for the canopy of a Yak?
Kiwi.
On 25 Aug 2020, at 22:07, Anthony Savarese <dsavarese0812(at)bellsouth.net> wrote:
Dennis
regards Stephen
PostPosted: Thu Aug 27, 2020 3:53 am    Post subject: CJ6 aileron bearings Reply with quote
Yes, BUT they are fixed bearings. Not self aligning.
Kiwi.
> Dennis
> Sent from my iPhone
