frank3 Guest
Posted: Mon Jul 20, 2020 11:15 am Post subject: TypeS Lithium Jump starter |
I was considering including a Ground Power Jack (Z-31A or B) in my RV with a fuel injected engine.
After watching a fella use a TypeS Lithium Jump Starter.(12v with up to 8k mAh, 350A peak current) to jump start a GMC SUV, I wonder about its application to my RV. It is very light weight and measures 7x3x1"; marketed as "Safe Jumper Cable protects against polarity, over-discharge, low voltage, reverse charging, short-circuit, overheat, spark-proof, and timing out."
I wonder if I could have two terminals (maybe an ANL block) in the cockpit area, one wired to the battery/firewall ground and the other to the battery contactor (bat side), forgoing the ground power contactor? The 4 AWG wire length less than 2 ft. As needed the jumper cables from the TypeS could be applied internally in flight or on the ground. With this "smart" device, would it be safe to have these fat wires in the cabin and without circuit protection?
My thought is to have it available (especially on trip to isolated airstrips) as needed for jump start and possibly use as inflight backup battery???
My electrical system will be single battery & alternator with an E Buss.
Does any of this make sense?
Thanks in advance for your input.
Frank
user9253
Joined: 28 Mar 2008 Posts: 1973 Location: Riley TWP Michigan
Posted: Mon Jul 20, 2020 1:23 pm Post subject: Re: TypeS Lithium Jump starter |
A battery does not necessarily need protecting with a fuse. But the pilot
should have the means to shut off all sources of electrical power at the source.
_________________ Joe Gores |
rparigoris
Posted: Tue Jul 21, 2020 10:31 am Post subject: Re: TypeS Lithium Jump starter |
Hi Group
A note on jump starter packs. I purchased a 4,000amp 12 volt jump starter a while back. I was working on a project and needed 1,500 watts for 15 seconds (a little less than 140 amps) and not go below 10.9 volts. Although after speaking with mfg. they did indeed test and saw 4,000 amps, it was for some nanosecond at some way low voltage. Here's the real poop: it could hardly hold up 35 amps for 15 seconds!
https://www.northerntool.com/shop/tools/product_200676383_200676383
Their# is 216-464-8131
Their 4,000 amp unit can put out ~ 40 amps for 3 seconds at minimum of 10.9 volts, after 15 seconds down to ~35 amps and if it were cold probably 20 or 25 amps.
The battery is only 8aH.
Ron P.
Posted: Tue Jul 21, 2020 7:13 pm Post subject: TypeS Lithium Jump starter |
At 01:31 PM 7/21/2020, you wrote:
| Quote: | --> AeroElectric-List message posted by: "rparigoris" <rparigor(at)hotmail.com>
Hi Group
https://www.northerntool.com/shop/tools/product_200676383_200676383 |
Yeah, there's been a host of similar products
with similar track records. Some of you may
remember the sensational Bolder Technologies,
thin metal film jelly-roll cells that caused
a big stir about 22 years ago:
https://tinyurl.com/yyw6a6j6
https://tinyurl.com/y42v9ztj
https://tinyurl.com/mu8oe6c
We had a sample array of cells in a 12v
configuration test at B&C about a year
or so earlier. Yup, those 2 A.h. cells
would dump current at over 400A when
loaded down to 9v!
They had a boat load of manufacturing
process problems to solve and never quite
made it. I think the company has been
sold several times and presently languishes
in India?
But just because a cell is small does not
necessarily mean it's not up to the stated
task. Take the EarthX product I published
test data on a few days ago. After 6+ years
the battery still stores 10+ a.h. of energy.
When loaded to 9v this morning, it still
offered respectable 400+ amps of cranking
current.
The cell's robustness is exceedingly
sensitive to production and design variables.
The smaller the cell, the greater the
sensitivity. EarthX appears to have their
ducks marching along in good order.
But as Ron has illustrated, not everyone
is so talented.
