maxe59
Posted: Sat Sep 05, 2020 2:17 pm Post subject: MGL EFIS and autopilot |
I have a Trigear classic with 914 and Arplast prop. I am considering installing an MGL Challenger EFIS and possibly autopilot servos.
Has anyone out there installed a similar set up? If so, any tips, tricks or pitfalls to be aware of?
I look forward to hearing from someone.
Cheers
Max Earnshaw
ZK-VMC
Christchurch, New Zealand
AirEupora
Posted: Sun Sep 06, 2020 5:39 am Post subject: Re: MGL EFIS and autopilot |
I had the MGL Vogager EFIS and used the Trio Servos. I could not get them to work correctly. MGL Torrance sold them to me, but they told me that Trio was the problem and Trio told me that the problem was with MGL.
Before you buy an autopilot system for the Europa you need to determine if your plane flies straight & level. How much force is needed to bring the nose up or down once it leaves altitude. For whatever reason by plane took more force to bring it back to lever than the Trio servo could deliver and would trip and shut down after a few minutes of trying. If you go back into this Forum you find a lot of question on how to get them set up. The roll axles worked and it was easy to install in the co-pilot seat area. The big problem is the pitch servo and how it connects to the pitch torque tube. I have to manufacture a clamp with a horn on it. Europa now makes a pitch tube with the horn welded to it.
I know that the MGL servos worked very well with the later model of the MGL EFIS . You might check out their forum.
AirEupora
Posted: Sun Sep 06, 2020 5:41 am Post subject: Re: MGL EFIS and autopilot |
Before you buy an autopilot system for the Europa you need to determine if your plane flies straight & level. How much force is needed to bring the nose up or down once it leaves altitude. For whatever reason by plane took more force to bring it back to level than the Trio servo could deliver and would trip and shut down after a few minutes of trying. If you go back into this Forum you find a lot of question on how to get them set up. The roll axles worked and it was easy to install in the co-pilot seat area. The big problem is the pitch servo and how it connects to the pitch torque tube. I had to manufacture a clamp with a horn on it. Europa now makes a pitch tube with the horn welded to it.
I know that the MGL servos worked very well with the later models of the MGL EFIS . You might check out their forum.
pestar
Joined: 11 Apr 2007 Posts: 61 Location: Auckland, New Zealand
maxe59
Posted: Tue Sep 08, 2020 4:31 pm Post subject: MGL EFIS and autopilot |
Thanks for the reply I will check out MGL forums. I was proposing to use MGL servos so maybe should work ok. My plane flies very true so hopefully that will be ok too.
Cheers
Max
On Mon, Sep 7, 2020 at 1:46 AM AirEupora <AirEupora(at)sbcglobal.net (AirEupora(at)sbcglobal.net)> wrote:
| Quote: | --> Europa-List message posted by: "AirEupora" <AirEupora(at)sbcglobal.net (AirEupora(at)sbcglobal.net)>
http://forums.matronics.com/viewtopic.php?p=498158#498158
