Engine Monitor P-lead question
farmrjohn
PostPosted: Wed Oct 07, 2020 7:17 pm    Post subject: Engine Monitor P-lead question Reply with quote
I'm installing an Electronics International CGR-30P engine monitor. For the tach function they have two leads that connect to the left and right P-lead on the ignition switch which are not shielded. The P-leads from the mags to the switch are shielded. Will this be an issue? Can those two leads be included in a wire bundle or should they have their on run away from other wires? Thanks, John
farmrjohn
PostPosted: Mon Oct 12, 2020 6:43 pm    Post subject: Re: Engine Monitor P-lead question Reply with quote
Well in the absence of any reply I installed the P-leads to the monitor in the wiring bundle with the other wires. So far there seems to be no adverse effects.
