Russian Radio Output Wattage
HawkerPilot2015
PostPosted: Tue Oct 13, 2020 12:46 pm    Post subject: Russian Radio Output Wattage Reply with quote
What is the output wattage of the russian radios?
markbitterlich(at)embarqm
PostPosted: Tue Oct 13, 2020 1:46 pm    Post subject: Russian Radio Output Wattage Reply with quote
Depends on the model. 10, 25 or 50 watts carrier. Multiply times 4 for PEP.
Mark
Date: 10/13/20 16:46 (GMT-05:00)
To: yak-list(at)matronics.com
Subject: Yak-List: Russian Radio Output Wattage
--> Yak-List message posted by: "HawkerPilot2015" <timsmiscaz(at)gmail.com>
http://forums.matronics.com/viewtopic.php?p=498803#498803
_-============================================================
_-= - The Yak-List Email Forum -
_-= Use the Matronics List Features Navigator to browse
_-= the many List utilities such as List Un/Subscription,
_-= Archive Search & Download, 7-Day Browse, Chat, FAQ,
_-= Photoshare, and much much more:
_-=
_-= --> http://www.matronics.com/Navigator?Yak-List
_-=
_-= - MATRONICS WEB FORUMS -
_-= Same great content also available via the Web Forums!
_-=
_-= --> http://forums.matronics.com
_-=
_-= - NEW MATRONICS LIST WIKI -
_-= Add some info to the Matronics Email List Wiki!
_-= --> http://wiki.matronics.com
_-= - List Contribution Web Site -
_-= Thank you for your generous support!
_-= -Matt Dralle, List Admin.
_-= --> http://www.matronics.com/contribution
HawkerPilot2015
PostPosted: Tue Oct 13, 2020 2:12 pm    Post subject: Re: Russian Radio Output Wattage Reply with quote
Whatever is the standard radio in a 1987 Yak-52. I am not near the airplane right now.
dsavarese0812(at)bellsout
PostPosted: Tue Oct 13, 2020 2:59 pm    Post subject: Russian Radio Output Wattage Reply with quote
The standard Russian radio in a Yak 52 is the Balkan 5.
Dennis
On Oct 13, 2020, at 6:19 PM, HawkerPilot2015 <timsmiscaz(at)gmail.com> wrote:
http://forums.matronics.com/viewtopic.php?p=498809#498809
kiwi679
PostPosted: Tue Oct 13, 2020 11:10 pm    Post subject: Russian Radio Output Wattage Reply with quote
I’m pretty sure it is 16 watt. Samen radio that was used in their commercial aircraft.
Steve
On 14 Oct 2020, at 00:57, Anthony Savarese <dsavarese0812(at)bellsouth.net> wrote:
Dennis
regards Stephen
PostPosted: Wed Oct 14, 2020 10:07 am    Post subject: Russian Radio Output Wattage Reply with quote
There are two Baklan (sp?) Models. One is 50 watt carrier and the other one I believe was 10 watts carrier, but could adjusted to 15 watts carrier. The lower power model was found in Yak 52's and such. Once in a very rare while, you'd find where someone had stuck the high power one in there. If you have 15 watts carrier, that's like 60 watts PEP, which is darn plenty.
Date: 10/14/20 03:09 (GMT-05:00)
Subject: Re: Yak-List: Re: Russian Radio Output Wattage
--> Yak-List message posted by: Stephen van Dijck <s.dijck(at)planet.nl>
Steve
--> Yak-List message posted by: Anthony Savarese <dsavarese0812(at)bellsouth.net>
Dennis
_-=
_-=
_-=
_-=
easy_driver
PostPosted: Thu Oct 15, 2020 10:36 am    Post subject: Re: Russian Radio Output Wattage Reply with quote
all russian specs everywhere say "output power" of Baklan-5 is ( you guessed it ! ) 5 W. how they define it is another matter. should be in their GOST standards library. most likely - carrier 100% AM, not PEP
Nino
Alexandria, VA
PostPosted: Thu Oct 15, 2020 1:10 pm    Post subject: Russian Radio Output Wattage Reply with quote
My power measurements came from a Bird watt meter Nino, not from a book sadly. I repaired them for a little while, but reverse engineering everything became too much of a pain in the rear. I'm sure your book values should be used instead of my watt meter measurement, so I'll stand corrected.
But .... There is a Baklan model with more power that had a different "-" number but the dimensions and connectors were identical. Perhaps your book mentions it? I'd like to know as I have only seen two.
In way of discussion, a 100% modulated AM transmission has a Peak Envelope Power of four times the carrier. So saying you have an unmodulated carrier of 5 watts means that at 100% Amplitude Modulation, your output power will be 20 watts "PEP."
Putting it more simply, an output value for an A.M. transmitter modulated at 100% should also equal the Peak Envelope Power, but to further confuse the issue, with no modulation an AM transmitter output and PEP are the same. That said normally AM transmitters are specified by the power of their unmodulated carrier output. Hence your book value of 5 watts for the Baklan-5. That's for pure carrier with NO modulation not at 100% modulation.
Yes, it can be confusing.
Mark
Date: 10/15/20 14:36 (GMT-05:00)
Subject: Yak-List: Re: Russian Radio Output Wattage
--> Yak-List message posted by: "easy_driver" <s_maikbox31-acc(at)yahoo.com>
Nino
Alexandria, VA
http://forums.matronics.com/viewtopic.php?p=498840#498840
_-=
_-=
_-=
_-=
jonboede(at)hotmail.com
PostPosted: Thu Oct 15, 2020 1:40 pm    Post subject: Russian Radio Output Wattage Reply with quote
I’m not sure what the output of the higher output radio is, but I think it’s similar to the radio in the Mi-24. With that one, if a car is parked next to the aircraft you can light up the headlights by pressing xmit. Wink
[quote]On Oct 15, 2020, at 4:17 PM, mark bitterlich <markbitterlich(at)embarqmail.com> wrote:
Mark
Nino
Alexandria, VA
easy_driver
PostPosted: Thu Oct 15, 2020 3:03 pm    Post subject: Re: Russian Radio Output Wattage Reply with quote
it's a free country. you can measure anything anyway you like, i'm not interested in arguing.
and i don't have MY little book. i cited manufacturer's specs published everywhere.
their GOST R 51742-2001 sec. 6.3.1 describes procedure for measuring power output of AM transmitter. schematics shows LF modulator ATTACHED . output power
is computed as U^2/R where R is resistance of antenna equivalent and U is measured voltage.
PostPosted: Thu Oct 15, 2020 3:55 pm    Post subject: Russian Radio Output Wattage Reply with quote
I was not debating dude, I was explaining.
Nuff said.
Mark
Date: 10/15/20 19:03 (GMT-05:00)
nough said
http://forums.matronics.com/viewtopic.php?p=498848#498848
_-=
_-=
_-=
_-=
