kiss TR1
w.ryalls(at)gmail.com
PostPosted: Tue Oct 20, 2020 12:39 pm    Post subject: kiss TR1 Reply with quote
Hi Steve.I have decided to get windows made hear in nz ,as it would cost about half th y cost of yours, because of thy defference between our dollars.I had no probs with your price but by time I got them hear thy cost was quite a lot.thank you so much for going to thy trouble of getting the cost of sending them to nz. It would be nice to stay in touch.once again thank you for all your help.
Cheers Wayne.
On Wednesday, 30 September 2020, Wayne Ryalls <w.ryalls(at)gmail.com (w.ryalls(at)gmail.com)> wrote:
Thank you for doing that Steve.Cheers Wayne.
On Wednesday, 30 September 2020, Steve Thornburg <thornburgsd(at)gmail.com (thornburgsd(at)gmail.com)> wrote:
Wayne,I brought the two door windows home from my hangar last night. They are still in the original shipping plastic bags. They weight 10 lbs together. I plan to take them to the parcel shipping store this afternoon to get an estimate. Brace yourself!
On Mon, Sep 28, 2020 at 9:08 PM Wayne Ryalls <w.ryalls(at)gmail.com (w.ryalls(at)gmail.com)> wrote:
Hi Keith, it's good to get more history on my kr1 kiss.Kind regards, Wayne Ryalls.
On Tuesday, 29 September 2020, <Keith.Miller(at)esa.int (Keith.Miller(at)esa.int)> wrote:
Wayne,
  for information in case you didnt already  know, this Tr1 Kis started its build  life in Central England  ( midlands) in  1994, with a guy called Simon Barnard who had  a lot of the basic original construction done by the importer at that time Brian Davis. Eventually  Simon sold the Kit  to Steve Moret  in about 2005 . Who then  emigrated to New Zeeland ( Northland ) with the kit  in about 2009. I lost touch with Steve  just after that , so its good to know the KIT is still around and hopefully will be completed one of these days.
Keith
"Wayne Ryalls" ---26/09/2020 21:13:44---Hi Graham,yes it's construction is about 3/4 done.wings are constructed to, all needs filled and pre
From: "Wayne Ryalls" <w.ryalls(at)gmail.com (w.ryalls(at)gmail.com)>
To: "kis-list(at)matronics.com (kis-list(at)matronics.com)" <kis-list(at)matronics.com (kis-list(at)matronics.com)>
Date: 26/09/2020 21:13
Subject: Re: kiss TR1
Sent by: owner-kis-list-server(at)matronics.com (owner-kis-list-server(at)matronics.com)
Hi Graham,yes it's construction is about 3/4 done.wings are constructed to, all needs filled and prepared for painting yet.I have 0235 lycoming engine for it.
There is one other kr1 in nz,reg is, zk kiss.it has over  one k hours of flying on it now.
Cheers Wayne.
On Sunday, 27 September 2020, Graham Brighton <gbrighton(at)skymesh.com.au (gbrighton(at)skymesh.com.au)> wrote:
    So ... do i understand that Construction of the Aircraft is about 80% done ? ... or is the Kit wing not started and the Contents is about 80% present ?  .. Wondering is the Wing finished .. ?  and maybe mounted to the Fuselage or ?
    How about Engine Choice ... have decided .. not decided ?
    Sorry if thats a lot of questions .. just that im in Victoria Oz ... and there's not many TR1's in our region !! .. ( maybe NZ has a couple on your Registry ? )
    Graham.
    Sent: Saturday, September 26, 2020 6:38 PM
    To: kis-list(at)matronics.com (kis-list(at)matronics.com)
    I am in New Zealand,cheers Wayne.
    On Saturday, 26 September 2020, Wayne Ryalls <w.ryalls(at)gmail.com (w.ryalls(at)gmail.com)> wrote:
      Hi Graham, thank you for your help,i purchased kr1 kiss which was about 80 percent complete from New.It needs front gear leg with spring etc and just a free other bits an pieces.
      Cheers Wayne.
      On Saturday, 26 September 2020, Graham Brighton <gbrighton(at)skymesh.com.au (gbrighton(at)skymesh.com.au)> wrote:
        Hi Wayne,
                           Where are located ? ... TR1 Nose Gear Leg is not the same as the TR4 unit .. TR1 Leg has No Shocker .. Just a Spring . Lyle Hendricks supplies these units and is located USA .
        Gullwing door Plexiglass replacements are available ... and sourced in USA also .. supplier was identified in a Thread here not that long ago .. so a little back tracking needed as off hand i dont recall . Someone maybe can chime in with that info ?
        So are you doing Repairs ? .. or needing missing parts for a TR1 project or or ?
        Cheers
        Graham .. TR1 80
        Sent: Sunday, September 27, 2020 10:07 AM
        Subject: kiss TR1
        Hi, Would any one have a front gear legg with sping, shockstrut  and fittings to firewall for my TR1 kiss. I think same one is used on four seat kiss as well
        i would be keen on any other TR1 parts.including gullwing doors and plexyglass door windows
        .cheers wayne.
        [url=#m_-7480127659366192408_m_46322258395081297_m_-6492618071112006706_m_-8891272405322150251_m_8213985700185518387_m_-6832599336062864760_m_-8919343956307204847_m_5045009832245058055_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2][/url]
This message is intended only for the recipient(s) named above. It may contain proprietary information and/or
protected content. Any unauthorised disclosure, use, retention or dissemination is prohibited. If you have received
this e-mail in error, please notify the sender immediately. ESA applies appropriate organisational measures to protect
personal data, in case of data privacy queries, please contact the ESA Data Protection Officer (dpo(at)esa.int (dpo(at)esa.int)).
Steve Thornburg
Steve388Z
PostPosted: Wed Oct 21, 2020 4:24 am    Post subject: kiss TR1 Reply with quote
No problem Wayne. I am glad to know you have a good way to get the windows Made. Let us all know how your KIS TR-1 progresses. Best Wishes - Steve Thornburg
On Tue, Oct 20, 2020 at 4:41 PM Wayne Ryalls <w.ryalls(at)gmail.com (w.ryalls(at)gmail.com)> wrote:
Cheers Wayne.
Wayne,
Keith
Cheers Wayne.
    Graham.
      Cheers Wayne.
        Hi Wayne,
        Cheers
        Graham .. TR1 80
        Subject: kiss TR1
        .cheers wayne.
        [url=#m_5185680682070233136_m_-7480127659366192408_m_46322258395081297_m_-6492618071112006706_m_-8891272405322150251_m_8213985700185518387_m_-6832599336062864760_m_-8919343956307204847_m_5045009832245058055_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2][/url]
Steve Thornburg
Steve Thornburg
Steve N388Z
matthew.kuriger
PostPosted: Wed Oct 28, 2020 3:52 pm    Post subject: kiss TR1 Reply with quote
Hi Wayne
My father and I own and fly ZK-TEL here in NZ (TR4) based down in Hawera, Taranaki. Be good to catch up sometime and I'd be keen to see your TR1.
Cheers
Matt
On Wed, 21 Oct 2020 at 09:41, Wayne Ryalls <w.ryalls(at)gmail.com (w.ryalls(at)gmail.com)> wrote:
Cheers Wayne.
Wayne,
Keith
Cheers Wayne.
    Graham.
      Cheers Wayne.
        Hi Wayne,
        Cheers
        Graham .. TR1 80
        Subject: kiss TR1
        .cheers wayne.
        [url=#m_2324054872916050475_m_-7480127659366192408_m_46322258395081297_m_-6492618071112006706_m_-8891272405322150251_m_8213985700185518387_m_-6832599336062864760_m_-8919343956307204847_m_5045009832245058055_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2][/url]
Steve Thornburg
Matt Kuriger
New Zealand
