		tonyrenshaw268(at)gmail.c Guest
				 Posted: Fri Oct 16, 2020 12:04 am    Post subject: VNE annual demonstrations. |
				Hi John,
 Are you or is anyone else familiar with the rationale why annual VNE dives are to be completed? I don’t understand the motive.
 Tony Renshaw
  	  | Quote: | 	 		   On 16 Oct 2020, at 5:40 pm, Europa-List Digest Server <europa-list(at)matronics.com> wrote:
  Today's complete Europa-List Digest can also be found in either of the
  two Web Links listed below.  The .html file includes the Digest formatted
  and Message Navigation.  The .txt file includes the plain ASCII version
  of the Europa-List Digest and can be viewed with a generic text editor
  HTML Version:
     http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 20-10-15&Archive=Europa
  Text Version:
     http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 20-10-15&Archive=Europa
                            Europa-List Digest Archive
                      Total Messages Posted Thu 10/15/20: 9
  Today's Message Index:
      1. 01:28 AM - Re: Vne and flutter explained - Australian Flying  (John Wighton)
      2. 01:31 AM - Re: Lighter tailwheel  (John Wighton)
      3. 01:56 AM - Re: Vne and flutter explained - Australian Flying  (clivesutton)
      4. 03:36 AM - Re: Vne and flutter explained - Australian Flying  (Remi Guerner)
      5. 03:42 AM - Re: Vne and flutter explained - Australian Flying  (clivesutton)
      6. 06:29 AM - Re: Re: Lighter tailwheel  (Richard Scanlan)
      7. 07:44 AM - Re: Re: Vne and flutter explained - Australian Flying  (D McFadyean)
      8. 09:53 AM - Classic  (MikeP)
      9. 10:19 AM - Re: Classic  (david park)
  ________________________________  Message 1  _____________________________________
  Time: 01:28:49 AM PST US
  Subject: Re: Vne and flutter explained - Australian Flying
  Pete,
  The article is 10 years old -a period which represents approximately 1/12 (or 8%
  ish) since Wright Bros made their mark.  Much can happen in a very short time,
  primarily due to the predictive tools we (as aeronautical engineers) have at
  our disposal.
  Jim's excellent article does, however, still contain good information.  The key
  elements being that there is a significant factor between Vne and Vd (typically
  1.3-1.4), and that flutter should not occur before 1.2Vd.  Hence no sane pilot
  should get anywhere near.  But that also assumes an aircraft is in tip-top
  condition.
  A simple route is to always fly using IAS.  Ensure you have calibrated your ASI,
  hence you are effectively flying CAS.
  This actually ignites a pet subject of mine - the LAA permit renewal flight test,
  which requires us all to be Test Pilots for the day - reaching Vne.  A little
  bit like cycling toward the edge of Beachy Head but (skillfully) avoiding plummeting
  over the edge.  We congratulate ourselves we are still alive - and then
  have to go and do it again next year..........
  John Wighton
  Europa XS trigear G-IPOD
  http://forums.matronics.com/viewtopic.php?p=498828#498828
  ________________________________  Message 2  _____________________________________
  Time: 01:31:09 AM PST US
  Subject: Re: Lighter tailwheel
  Not cheap by any means but a Ti leg and wheel is about as light as you will get.
  John Wighton
  http://forums.matronics.com/viewtopic.php?p=498829#498829
  ________________________________  Message 3  _____________________________________
  Time: 01:56:55 AM PST US
  Hi Peter, thanks for posting this link to an excellent article - that explains
  more clearly than i've ever seen anywhere, how Flutter is initiated and influenced.
  http://forums.matronics.com/viewtopic.php?p=498830#498830
  ________________________________  Message 4  _____________________________________
  Time: 03:36:47 AM PST US
  Great article on this critical subject. It would be interesting to find out how
  the Europa has been evaluated during flight testing of the prototypes, especially
  at what max altitude the Vd testing has been actually performed.
  BTW it is always instructive to look at certificated aircraft manuals and see how
  they handle any issue. The attached page is from the Cirrus SR22T POH. It shows
  how they handle the VNE/flutter issue at high altitude. The VNE IAS is reduced
  linearly above 17500 ft. from 205 kts to 175 kts at 25000 ft. Very few Europas
  are operated at such high altitudes, but it may be advisable for their
  pilots to consider reducing their VNE as Cirrus do.
  Surprisingly Cirrus also reduce the VNO above 17500 ft: obviously this has nothing
  to do with flutter, so why?
  Remi Guerner
  http://forums.matronics.com/viewtopic.php?p=498831#498831
  http://forums.matronics.com//files/v_limits_sr22t_120.png
  ________________________________  Message 5  _____________________________________
  Time: 03:42:40 AM PST US
  Good points John.
  RE: the LAA annual VNe dive- what is your understanding of the reasoning behind
  this LAA (supported by the UK CAA), requirement?
  http://forums.matronics.com/viewtopic.php?p=498832#498832
  ________________________________  Message 6  _____________________________________
  Time: 06:29:29 AM PST US
  Subject: Re: Re: Lighter tailwheel
  Hi John, can you give more details on this? Ti leg?
  Sent from my iPad
 > John Wighton
  ________________________________  Message 7  _____________________________________
  Time: 07:44:05 AM PST US
  Subject: Re: Re: Vne and flutter explained - Australian Flying
  I'm happy that my Europa is only cleared to 1300lbs MTOWA and therefore I only
  have to Vne-dive to 150knts, leaving the XSs to explore the class-envelope at
  a much higher speed!
  Duncan McF
 > On 15 October 2020 at 09:28 John Wighton <john(at)wighton.net> wrote:
 > Pete,
  8% ish) since Wright Bros made their mark.  Much can happen in a very short time,
  at our disposal.
  pilot should get anywhere near.  But that also assumes an aircraft is in tip-top
  condition.
  plummeting over the edge.  We congratulate ourselves we are still alive - and
  then have to go and do it again next year..........
 > John Wighton
  ________________________________  Message 8  _____________________________________
  Time: 09:53:08 AM PST US
  Subject: Classic
  Have just had one of the outriggers break, fortunately no damage.
  Anyone in the UK got one or two after a tri-gear mod or just have a spare?
  Mike
  http://forums.matronics.com/viewtopic.php?p=498837#498837
  ________________________________  Message 9  _____________________________________
  Time: 10:19:57 AM PST US
  Subject: Re: Classic
  Will search garage tomo
  Dave Park G-LDVO
 > Thanks
 > Mike
		Duncan McFadyean
				 Posted: Fri Oct 16, 2020 4:43 am    Post subject: VNE annual demonstrations. |
				To check there is no flutter?
 If there is, the test doesn't have to be done again. EVER!
 I suppose also to check that the controls haven't 'frozen' and that the aircraft can still be manoeuvred.
 Duncan McF
  	  | Quote: | 	 		   On 16 October 2020 at 09:03 Tony Renshaw <tonyrenshaw268(at)gmail.com> wrote:
  Hi John,
  Tony Renshaw
  > HTML Version:
  > Text Version:
  > From: "John Wighton" <john(at)wighton.net>
  > Pete,
  > our disposal.
  > condition.
  > John Wighton
  > John Wighton
  > From: "clivesutton" <clive.maf(at)googlemail.com>
  > From: "Remi Guerner" <air.guerner(at)orange.fr>
  > Remi Guerner
  > Good points John.
  > From: Richard Scanlan <aspenbuild(at)me.com>
  > Sent from my iPad
  >> John Wighton
  > From: D McFadyean <ami-mcfadyean(at)talktalk.net>
  > Duncan McF
  > do not archive
  >> Pete,
  > at our disposal.
  > condition.
  >> John Wighton
  > Subject: Classic
  > From: "MikeP" <mpotts(at)clara.net>
  > Thanks
  > Mike
  > From: david park <dpark748(at)me.com>
  > Dave Park G-LDVO
  >> Thanks
  >> Mike
		Matt Dovey
  Joined: 13 May 2017 Posts: 48 Location: st albans, england
				 Posted: Fri Oct 23, 2020 4:14 am    Post subject: Re: VNE annual demonstrations. |
				I usually just do it. Not really difficult. It is/was the same doing a C of A airtest. The aircraft was flown to VNE also. I suppose its for the reasons given above. Drop the LAA a line and ask the reasons why. There is a brief description on the VNE test in TL 2.06
