Z14 with SDS EM5 ENG BUS
Goto page Previous  1, 2
PostPosted: Wed Nov 11, 2020 7:23 am    Post subject: Z14 with SDS EM5 ENG BUS Reply with quote
I'm not Jeff, but I plan on having the engine bus switch on whenever the engine is running, with the alternate power path coming through a diode from the main bus. My *logic* is that the dual active power paths minimize any potential 'operational issues' (failures in power delivery to the engine bus, for reasons ranging from device failure to inadvertent switch movement) that could come up at times when options/reaction time are limited, like shortly after takeoff or being forced to remain at low altitude due to 'airliner pattern' approaches flown by leading traffic. The core driver is to not based on calculated odds, but on being prepared as well as possible for what *can* happen.
Another motivator is that 'switchology' (actually, procedures), while unavoidably different from traditional a/c engine installations, will be as close as possible to decades of training, where in certain emergencies we're trained to shut down everything except the engine. Again, not probability driven, but for what *can* happen.
Obviously, proper functionality will be checked before takeoff.
Charlie
Point well taken sir . . .
out of that stuff?"
PostPosted: Wed Nov 11, 2020 8:20 am    Post subject: Z14 with SDS EM5 ENG BUS Reply with quote
Jeff and Charlie,
Why don't you guys work up a preflight checklist for a
full-up Z101 and publish it here. After due opportunity
for critical review, I'll add it to the Z101 notes
out of that stuff?"
Ceengland
PostPosted: Wed Nov 11, 2020 4:41 pm    Post subject: Z14 with SDS EM5 ENG BUS Reply with quote
Looks pretty good to me. I wish I had one to offer, but I'm far enough from flying that I have not yet created an actual checklist. I did give operations a lot of thought while laying out the architecture, though, and I suspect that I'll end up with something very similar to Jeff's.
Jeff, the one thing I noticed was:
"Aux ALT ON Check Bus amps"
Mine will almost certainly say 'check bus volts', because the low volts warning will instantly show up, and seems an easy  method of detecting alternator operation, to me. Perhaps my decision to use a 'traditional' SLA battery influences this, since an inactive alternator will show up as a quite obvious voltage drop. I don't know if the lithium tech batteries will have as obvious a voltage drop without the alternator(s) on line.
FWIW,
Charlie
On 11/11/2020 4:40 PM, Foghorn Inc wrote:
Here is what I have for my RV8 project.
Fire away!
Jeff Parker
On 11Nov, 2020, at 10:24, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
Jeff and Charlie, Why don't you guys work up a preflight checklist for a full-up Z101 and publish it here. After due opportunity for critical review, I'll add it to the Z101 notes
  Bob . . .   Un impeachable logic: George Carlin asked, "If black boxes   survive crashes, why don't they make the whole airplane   out of that stuff?"
Charlie
Page 2 of 2
