Attach rudder post
capedavis(at)yahoo.com
PostPosted: Thu Nov 12, 2020 9:04 am    Post subject: Attach rudder post Reply with quote
How is the rudder post on a firefly attached AN3bolts or 3/16 rivets
stuart(at)harnerfarm.net
PostPosted: Thu Nov 12, 2020 1:04 pm    Post subject: Attach rudder post Reply with quote
The rudder post is steel and welded to the tail boom ring assembly. The
vertical stabilizer slips over the steel post (tube) and is riveted to the
steel post. These and the rivets for the rudder hinge use longer rivets to
accommodate for the internal steel tube.
I can dig out my Firefly plans and look up the details if you would like.
Stuart
