jluckey(at)pacbell.net Guest
Posted: Tue Dec 29, 2020 12:08 pm Post subject: Firewall Penetration Redux |
BobN,
A couple of weeks ago you posted a picture of a Bonanza's firewall under construction. It shows a firewall pass-thru fitting with a 90 deg bend and some sort of flange attached to firewall. What is that fitting made of?
-Jeff
Ceengland
Posted: Tue Dec 29, 2020 1:35 pm Post subject: Firewall Penetration Redux |
On 12/29/2020 2:03 PM, Jeff Luckey wrote:
-Jeff
| I'm not Bob, but stainless grab bars work well. Just find versions that have the flange welded onto the bend. I needed a straight shot off the firewall for mine, so I cut it short enough that I just had a short stub left for clamping the fire sleeve. Ebay has had smaller (~1") stainless flanged stubs in the past, but I can't find the link now.
Charlie
_________________ Charlie |
Posted: Tue Dec 29, 2020 2:22 pm Post subject: Firewall Penetration Redux |
At 02:03 PM 12/29/2020, you wrote:
Quote: | BobN,
A couple of weeks ago you posted a picture of a Bonanza's firewall under construction. It shows a firewall pass-thru fitting with a 90 deg bend and some sort of flange attached to firewall. What is that fitting made of? |
Beech fabricated their fittings from stainless
steel.
out of that stuff?"
mikepienaar09(at)gmail.co Guest
Posted: Wed Dec 30, 2020 12:38 pm Post subject: Firewall Penetration Redux |
When I installed mine I put the pipe end of the fitting inside the cockpit This is purely cosmetic, the firesleeve and sealer clamp are then out of sight
From the engine side you only see the wires bundle going into the fitting
Mike
Quote: | On Dec 29, 2020, at 2:28 PM, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com> wrote:
steel.
out of that stuff?"
