occom(at)ns.sympatico.ca Guest
Posted: Wed Jul 26, 2006 8:02 am Post subject: spar removal |
Those who responded may recall that I have been removing the rear spars from my wings for replacement. one has a slight dent/bend and the other was repaired with a splice and I was advised to replace both. I have several pictures of the removal, ignore the huge scratches on the insert I did that while removing it. The adhesive that is pictured cut away from the rib is the original 3M adhesive not Hysol which has proved somewhat more difficult to remove.
http://www3.ns.sympatico.ca/occom/Kitfox%20/
Float Flyr
Posted: Wed Jul 26, 2006 4:50 pm Post subject: spar removal |
Thanks for the pictures... I'm confident you made the right decision to replace those spars!
Noel [quote]
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
