Ceengland
Posted: Wed Mar 10, 2021 9:25 am Post subject: Milspec wire followup: PTFE vs ETFE |
Question for Bob N. or others who've used a lot of milspec wire:
I'm aware of the obvious differences between PTFE & ETFE; 'P' has higher temp rating but tends to 'cold flow'. I
I'm pretty sure I've encountered PTFE in pre-built harnesses from some avionics mfgrs, based on the way the insulation strips, vs known-ETFE wire I have on hand. If we install with reasonable care, is there any reason to fear using PTFE for wiring throughout the airframe?
_________________ Charlie |
Posted: Thu Mar 11, 2021 8:37 am Post subject: Milspec wire followup: PTFE vs ETFE |
At 11:22 AM 3/10/2021, you wrote:
| Quote: | Question for Bob N. or others who've used a lot of milspec wire:
I'm pretty sure I've encountered PTFE in pre-built harnesses from some avionics mfgrs, based on the way the insulation strips, vs known-ETFE wire I have on hand. If we install with reasonable care, is there any reason to fear using PTFE for wiring throughout the airframe? |
PTFE (Teflon) is not 'more' desirable than ETFE (Tefzel) and
it has some downsides.
Greg Richter and I had some lengthy discussions on this
about 17 years back after I reviewed his "Wiring for Smart People"
publication.
https://tinyurl.com/qxvr6nx
I'm aware of no manufacturer that uses Teflon
for general airframe wiring. Of perhaps 30000
feet of wire I have in inventory, I don't think
there is a hundred feet of Teflon.
Here's a copy of the Wire Bible which was
updated on the website this morning. This is
a searchable pdf file that will allow you to
quickly identify about any wire product by
specification.
https://tinyurl.com/ydgacclw
Having said that, Teflon is not 'evil'. If you
got a heck of a deal on some I would not discourage
it's use in avionics harnesses but it's kinda
finicky to strip.
https://tinyurl.com/bol9x2n
out of that stuff?"
Ceengland
Posted: Thu Mar 11, 2021 9:36 am Post subject: Milspec wire followup: PTFE vs ETFE |
On Thu, Mar 11, 2021 at 10:48 AM Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
publication.
specification.
finicky to strip.
| I'd agree that P is less desirable than E, because I'm not concerned about extreme temp ratings and had minor concern about cold flow. I had spotted a 'deal' on about 1K ft of P (IIRC, it was ID'd as M22759/9), but then found the same quantity of E (M22759/16) for about a penny more per foot. Not a big enough price delta for the hassle.
Many thanks for the info; if I run across some P with a bigger price delta in the future, I may well add some to my 'inventory'.
bobkuc(at)gmail.com Guest
Posted: Fri Mar 12, 2021 7:39 pm Post subject: Milspec wire followup: PTFE vs ETFE |
I was building a plastic plane. At sun-n-fun I while back ago, I bought wire from aren't vendor. It was labeled 20-3 uninsulated and was bundle in 100 ft rolls. Now I am building an rv7a and have some left over. Is there a way to tell if the wire I have is ok for use in airplane? Coating on wire is smooth and shiny and wire looks to be coated. Should I run.p and get fresh wire from spruce?
Another Bob K.
On Thu, Mar 11, 2021, 11:59 PM Charlie England <ceengland7(at)gmail.com (ceengland7(at)gmail.com)> wrote:
publication.
specification.
finicky to strip.
