SteveIvell(at)pestproof.c Guest
Posted: Mon Mar 29, 2021 7:56 am Post subject: Vents |
[img]cid:eacc0cb5-db05-4d42-8ccd-66159d19050b[/img]
Hi Patrick
I only fitted this last night. It took a lot of deliberation!!
The position is quite limited once you sit in and consider where your legs go.
I'm hoping to get the port side fitted tonight........... fingers crossed.
Kind Regards
Steve Ivell
07971 128842
From: owner-europa-list-server(at)matronics.com <owner-europa-list-server(at)matronics.com> on behalf of Patrick Tunney <p1tun(at)yahoo.co.uk>
Sent: Sunday, March 28, 2021 2:05:37 PM
To: europa-list(at)matronics.com <europa-list(at)matronics.com>
Subject: Re: Vents
--> Europa-List message posted by: "Patrick Tunney" <p1tun(at)yahoo.co.uk>
I am just in the process of installing the round style air o vents.
could i please get feedback on the best possible location and what worked well before i comit to the hole in the fuselage.
Images would really help.
Pat
http://forums.matronics.com/viewtopic.php?p=501119#501119
st Email Forum -
pa-List">http://www.matronics.com/Navigator?Europa-List
p; - MATRONICS WEB FORUMS -
ums.matronics.com
p; - NEW MATRONICS LIST WIKI -
matronics.com
p; - List Contribution Web Site -
p; -Matt Dralle, List Admin.
153.98 KB |
9348 Time(s) |
paul.the.aviator(at)gmail Guest
Posted: Mon Mar 29, 2021 8:59 am Post subject: Vents |
Hello everyone,
I've been following the vent discussion and I wanted to share my approach to this. It's far from simple but it works really well. I put a standard heat box on the firewall. On the instrument panel side I fabricated a plenum with 4 outlets. Two were used for the windshield vents and the other two feed some eyeball vents on the panel. Â
The air feed on the firewall side comes from where I have my turbo charger intercooler air box so that is unique to my installation but finding a place to pull high pressure clean air shouldn't be difficult.
Needless to say the result is really good but it is a far amount of work. I do have some photos somewhere and if there is enough interest I'll post them.
Paul
Patrick Tunney
Posted: Mon Mar 29, 2021 11:54 am Post subject: Re: Vents |
Many thanks Bud for the great summary.
John i appreciate the drawing offer
Griffo
Joined: 18 Mar 2021 Posts: 70 Location: The Oaks, NSW, Australia
Posted: Mon Mar 29, 2021 5:53 pm Post subject: Re: Vents |
Bud: I may have missed it but did you address wind noise ? I have always been concerned about "things" that project into high speed air.
Paul: Yes please, on the offer of photos.
_________________ 46 |
BobD
Joined: 05 Jan 2016 Posts: 117 Location: Sheffield UK
Posted: Mon Mar 29, 2021 10:59 pm Post subject: Re: Vents |
Bud Yerly's excellent paper on Cockpit Ventilation has been added to the repository of his articles on the Europa Club website.
https://www.theeuropaclub.org/building/the-bud-yerly-notes
BobD
Treasurer
The Europa Club
_________________ Bob Dawson
Europa XS TG || 912 ULS || G-NHRJ || Dynon Skyview || PilotAware || SmartAss3 |
John Wighton
Posted: Mon Mar 29, 2021 11:59 pm Post subject: Re: Vents |
This is the sketch of the vent position.
The red boundary is the recommended zone.
The yellow boundary is generally considered too far back.
55.55 KB |
9291 Time(s) |
_________________ John Wighton
Europa XS trigear G-IPOD |
budyerly@msn.com
Posted: Tue Mar 30, 2021 3:40 am Post subject: Vents |
Griff,
NO, I did not address the noise level.
With headsets, addressing noise is a function of mic settings, air blast direction, ANR vs non, engine type and exhaust, propeller type and airspeed.
Anything allowing wind blast into the cockpit is going to make noise.
Those with NACA vents down by the leg or below the cruck of the knee won't hear much.
Those with piping from the rear (tail fin) up to the cockpit won't hear (or feel) much either.
The ultimate vents in my windows can be heard with non ANR headsets slightly when directed at the face.
The door style intake tends to be noisier than the ultimate style.
The in the glass hinged door is awful if placed near the face (about half way back on the door).
So not much help really. I am normally more concerned with the engine and prop noise.
I find the two blade props (older Whirlwind hydraulic, Sensenich blades in the Airmaster AP420) to be noisier due to the wide chord power pulses hitting the screen.
The windscreen in some planes acts like a drum skin so prop noise is noticeable.
Exhaust of a Jabiru or Rotax 912 series exited under the belly is noisy also.
Survival from heat stroke in the cockpit in summer means more to me than db level of the vent.
Just an opinion.
Bud Yerly
Gilles
Posted: Tue Mar 30, 2021 4:08 am Post subject: Vents |
Le 28/03/2021 à 19:16, Bud Yerly a écrit :
| Quote: | I've had many discussions over the years on cockpit ventilation and I summarized them in a pdf for you guys to look at. I'm always interested in how to make things work.
Bud and all,
Most interesting document, congratulations!
Just one point, I'm of the opinion that the Rotax engines generate
largely enough heat to make a functional heating.
Remember a reciprocating engine rejects about as much heat energy as
mechanical output on the prop shaft. That's a lot of calories (or BTUs)
The key point is having a sufficient flow of sufficiently hot air.
It only works with a proper cooling air nozzle behind the radiator(s) so
hot air is under pressure.
Here is an example of such a cockpit heating system, with a very
satisfactory efficiency.
http://contrails.free.fr/cellule_chauffage_en.php
Easily adaptable to an Europa.
FWIW
Best regards,
Gilles
http://lapierre.skunkworks.free.fr
_________________ Best regards,
Gilles
http://contrails.free.fr |
Remi Guerner
Posted: Tue Mar 30, 2021 7:39 am Post subject: Re: Vents |
The attached pictures illustrates what I did to improve the original Naca vents on my Europa. Works very well. For details read my article in EF84.
Remi
269.3 KB |
9273 Time(s) |
65.64 KB |
9273 Time(s) |
Patrick Tunney
Posted: Tue Mar 30, 2021 12:08 pm Post subject: Re: Vents |
Many thanks Steve
The location is pretty much in line with my thinking and also comments from other owners i have spoke to that felt the vents needed to be higher than the europa reference position.
Pat
Griffo
Posted: Tue Mar 30, 2021 2:04 pm Post subject: Re: Vents |
Hi Bus,
Thank you for your "noise" response - very much as I expected.
I have both ANR /passive headsets, however following the KISS principals, I prefer the passive. Where practical will try for cockpit noise reduction & treat the disease, not just the symptoms)
With regard to your prop/engine noise comments - I am hoping to have more experience in a Europa shortly - to date most of my LSA experience has been in a Rotax 912 ULS motivated ATEC Zephyr, using a 2 blade Fiti (ground adjustable) prop. Aircraft noise external/internal was very low - inflight, cockpit conversation, without headsets, was quite easy. I fitted an automotive security siren to alert my family when I was passing overhead. I appreciate differences in aircraft construction/design will effect noise generation and thus may not be applicable to another.
freddythek10(at)gmail.com Guest
Posted: Wed Mar 31, 2021 1:55 pm Post subject: vents |
NACA vent in vertical fin leads to adjustable overhead outlets…feeds thru overhead plenum...very effective; one can feel the fresh air at the outlet even during engine idle…kudos for idea from Jeff Behrnes.
[img]cid:ABFF33A0-E408-4109-935E-6CCEA619D1F5[/img]
[img]cid:FBAB1360-24AD-4898-AFF5-49685340C556[/img]
[img]cid:7B33607F-4F6E-4D7A-A577-DE1E2181D300[/img]
[img]cid:1D9FC0CA-4605-4261-83DB-B11AAE9F90B9[/img]
28.27 KB |
9206 Time(s) |
23.58 KB |
9206 Time(s) |
30.09 KB |
9206 Time(s) |
65.14 KB |
9206 Time(s) |
Rocketman
coatbeam(at)melbpc.org.au Guest
Posted: Wed Mar 31, 2021 9:32 pm Post subject: Vents |
For design of "NACA Submerged Inlets" (search this) - lots of reports
and drawings etc.
However the attached should be enough. Not the corners on the duct must
be sharp to force th eair stream to trip.
Graeme
Europa Tri-Gear
15.08 KB |
9196 Time(s) |
51.72 KB |
9196 Time(s) |
 Download |
| Filename: |
Installing_a_submerged_inlet_ventilation_system_EAA_Sport_Aviation_1981-12.pdf |
1.16 MB |
| Downloaded: |
852 Time(s) |
brian.davies44(at)gmail.c Guest
Posted: Thu Apr 01, 2021 3:31 am Post subject: Vents |
Or, you could put a sheet of tracing paper on a Concorde wing 😊
Brian Davies
2.41 MB |
9190 Time(s) |
