Voyager
Posted: Sat May 29, 2021 2:07 pm Post subject: Z-14 question |
Bob, a question about Z-14. I am considering this architecture for my S-21.
The starter/cross-feed switch is listed as S700-2-7, but the figure looks more like a 2-5 and the function seems to make that switch the correct choice. I can’t see a reason why the non-starter cross-feed position would also be momentary. Is this just a typo on the switch designation?
Matt Whiting
Posted: Sat May 29, 2021 7:10 pm Post subject: Z-14 question |
At 05:06 PM 5/29/2021, you wrote:
| Quote: | --> AeroElectric-List message posted by: "Matthew S. Whiting" <m.whiting(at)frontier.com>
The starter/cross-feed switch is listed as S700-2-7, but the figure looks more like a 2-5 and the function seems to make that switch the correct choice. I can’t see a reason why the non-starter cross-feed position would also be momentary. Is this just a typo on the switch designation? |
Yes, be sure you're getting the latest revision
level of any Z-figure from the website. The
current revision for Z-14 dated 2013 is "P"
where the switch callout as indeed corrected to
S702-2-5.
out of that stuff?"
Voyager
Posted: Sun May 30, 2021 4:32 am Post subject: Z-14 question |
Hmmmm. I got it from the web site so I thought it was the latest. I got it here: http://www.aeroelectric.com/Books/Connection/AppZ_12A3.pdf
I just checked and this version is still incorrect. I am assuming there must be another location or maybe you only update the CAD files and I don’t have a CAD program to read those so I usually look at the PDFs. I will find a .DWG viewer and check the CAD version.
Matt
| Quote: | On May 29, 2021, at 11:13 PM, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com> wrote:
S702-2-5.
out of that stuff?"
david(at)carter.net Guest
Posted: Sun May 30, 2021 4:55 am Post subject: Z-14 question |
http://www.aeroelectric.com/PPS/Adobe_Architecture_Pdfs/
On Sun, May 30, 2021 at 6:33 AM Matthew S. Whiting <m.whiting(at)frontier.com (m.whiting(at)frontier.com)> wrote:
| Quote: | Hmmmm. I got it from the web site so I thought it was the latest. I got it here: http://www.aeroelectric.com/Books/Connection/AppZ_12A3.pdf
Matt
| Quote: | On May 29, 2021, at 11:13 PM, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
| Quote: | --> AeroElectric-List message posted by: "Matthew S. Whiting" <m.whiting(at)frontier.com (m.whiting(at)frontier.com)>
S702-2-5.
out of that stuff?"
David Carter
david(at)carter.net (david(at)carter.net)
johnbright
Joined: 14 Dec 2011 Posts: 167 Location: Newport News, VA
Posted: Sun May 30, 2021 5:03 am Post subject: Re: Z-14 question |
| Voyager wrote: | | Hmmmm. I got it from the web site so I thought it was the latest... |
I made a cheat sheet.
https://docs.google.com/document/d/1iR03DwNeHZy8hO7xBtALPb4_Tl0EY3OdZnAEIxpfMVY/edit?usp=sharing
_________________ John Bright, RV-6A
Single battery, wound-field alternator on main bus, MZ-30 PM generator on engine/essential bus.
N1921R links |
Voyager
Posted: Sun May 30, 2021 5:25 am Post subject: Z-14 question |
Thanks. I’d been in this directory once before, but somehow found my way to the older one this last time.
| Quote: | On May 30, 2021, at 8:58 AM, David Carter <david(at)carter.net> wrote:
Matt
S702-2-5.
out of that stuff?"
David Carter
Posted: Sun May 30, 2021 8:47 pm Post subject: Z-14 question |
At 07:30 AM 5/30/2021, you wrote:
This link is Rev 12 BOOK, not the page-per-system archives . . .
out of that stuff?"
Posted: Sun May 30, 2021 8:48 pm Post subject: Z-14 question |
At 08:25 AM 5/30/2021, you wrote:
| Quote: | Thanks. I’d been in this directory once before, but somehow found my way to the older one this last time.
These are the PPS archives where BOTH autocad
dwg and Acrobat pdf files are updated and
stored.
out of that stuff?"
Voyager
Posted: Mon May 31, 2021 9:36 am Post subject: Z-14 question |
Thanks, Bob!
Matt
| Quote: | On May 31, 2021, at 12:50 AM, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com> wrote:
stored.
out of that stuff?"
