Tommy Walker
Joined: 12 Jan 2006 Posts: 442 Location: Anniston, AL 36207
Posted: Thu Jul 27, 2006 3:44 pm Post subject: Left-Right "Mags" |
Rotaxers,
I'm wiring up my kill switches on the 912. Which ignition module is Left
and which is right? In the drawings there is a reference to A and B
modules. I am thinking that A is left and B is right, but I have thought
before and been proven wrong.
I don't know if it is critical, but I would like to know.
Tommy Walker in Alabama
_________________ Tommy Walker
N25A - Anniston, AL |
Geoff Heap
Joined: 12 Jan 2006 Posts: 266 Location: Lindenwold, New Jersey
Posted: Fri Jul 28, 2006 4:17 am Post subject: Re: Left-Right |
Tommy. Try the rotax list. I was recently reading posts on this subject post by "jon(at)joncroke.com" part of what he wrote
"Note that the Rotax purists will probably scold you (using
an Austrian accent!) for saying left or right.? We have a
top (A) and a bottom (B) ignition module... regardless of
what the key switch says.? "
post subject is "912 rough running"...............Geoff
Mike Gleason
Posted: Fri Jul 28, 2006 4:20 am Post subject: Left-Right "Mags" |
Tommy:
Its not critical, Mine are wired A as right and B as left.
Mike G
701 awaiting inspection
zsmith3rd(at)earthlink.ne Guest
Posted: Fri Jul 28, 2006 4:28 am Post subject: Left-Right "Mags" |
Tommy,
You are right ....."A" & "B" probably should be 1 & 2 or Left & Right.
I ran into that same thing and decided that it really only mattered to the guy doing the mag check....if you need to troubleshoot later it just makes it easier if you know which Module is connected the Left/Right toggle switch or position on the key switch. I used white heat shrink over the two wires, on each end, and a fine-point Sharpie solved the labeling.
Zed
NYTerminat(at)aol.com Guest
Posted: Fri Jul 28, 2006 7:51 am Post subject: Left-Right "Mags" |
Tommy,
Rotax uses Ignition A and B. The A serves the top plugs of cyl 1 and 2 and the bottom plugs of cyl 3 and 4. The B ignition serves top plugs for cyl 3 and 4 and bottom plugs for cyl 1 and 2. It doesn't matter which you consider left and right as long as you know which is A and B for troubleshooting.
Bob Spudis
In a message dated 7/27/2006 7:45:55 P.M. Eastern Daylight Time, twalker(at)cableone.net writes:
| Quote: | --> Zenith-List message posted by: "Tommy Walker" <twalker(at)cableone.net>
Rotaxers,
Do Not ========================== he es Day
--> ================================================== - NEW MATRONICS LIST WIKI -
_-= sp; -> =========================p; - List Contribution Web Site ==================================================
